tk 1600-elec clutch
Started by dge74, November 18, 2009, 02:47:48 PM
dge74
just dusted off my 1600 after a year, greased it ,new fuel, ect. fired rite up - stared to cut and the clutch keeps kicking out even with no load. any ideas. - Never mind,had to jump start .battery not taking a charge so not enough energy to engage clutch.-new battery
James P.
dge74 , welcome to the forum,I can't help you with clutch problem. I am sure someone is more familiar with your mill and will have a suggestion
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
1938farmall
dge,  mine has an electric clutch with the switch wired to the ground side of the clutch.  if it's been stored, i would look for a dirty / loose connection at the switch or the clutch.  al
aka oldnorskie
T Red
Also check low voltage.  If the battery is weak the alternator may not be able to keep the voltage high enough to keep the clutch engaged.
As farmall stated dirty connections/ contacts will compound the problem.
Tim
mrnero
Hi dge74, if everything else fails, try this troubleshooting/diagnosis method to your electric clutch. Run a positive jumper wire from the battery to the (+) side of the clutch and run a negative jumper wire from the battery to the (-) side of the clutch. If the clutch don't kick out (slips out) anymore, Then you have a electrical problem from the clutch back to the power source. check the wires and switch/relay back to original power source for loose/bad connections or bad switch/relay. If kicking out (slippage) still persist with jumper wires on, you have clutch problems. Some electric clutches are adjustable & needs cleaning and some electric clutches becomes throwaways. Be sure your battery is up to max voltage and or full charged during this troubleshooting method. good luck
P.S. if you find that its electrical problems, let me know and I can help you out further in detecting if its the negative feed side or postive feed side thats effecting your clutch problem.
Most likely, if you hear a clicking noise while the elect clutch is engaged/running its usually electrical. If the elect clutch is slipping, its mostly out of adjustment/cleaning or its junk.
dge74, Welcome to FF..... 8)  There are several TK'ers on here that will help you.
dge74
Quote from: dge74 on November 18, 2009, 02:47:48 PM
thank all of you for replying- hope i can return the favor some day.
T Red
Let us know how it turns out.
Tim
backwoods sawyer
Backwoods Custom Milling Inc.
T Red
Thanks for pointing that out.  I must be getting old and senile.  :-\
Tim
backwoods sawyer
Quote from: T Red on November 20, 2009, 07:23:23 AM
Or it was just edited after you had read that part.
