Author Topic: Brand new mill, brand new 'sawyers' updated w/ pics!  (Read 15220 times)
Online pineywoods
Re: Brand new mill, brand new 'sawyers' updated w/ pics!
« Reply #60 on: December 16, 2009, 11:32:50 PM »
OK, I am now an official member of the forum. I discovered today what the log posts do to you blade when they try to resist one another. It's not a nice sound. The blade came out with less teeth than that Italian prime minister guy.
It was not on purpose. I had just done the final cut on a log, and gave the mill a little push to pass the log end. Uh-oh, that post at the other end was just high enough to touch the blade. Woops.
Planman
That didn't take long, guarranteed you will do it again ;D
Offline bandmiller2
« Reply #61 on: December 17, 2009, 07:59:08 AM »
Planman, your dues are paid now,we all seem to do it, the smart ones only once.Sometimes it helps if you make a mark on the scale just above where the band will hit iron when you get near that mark double check before the cut.Frank C.
Offline IVANX71
« Reply #62 on: December 17, 2009, 10:49:27 AM »
I also plan to buy LT 15 following the spring. :)
How many board feet can be the max cut with a one saw blade (without hitting a stone, metal or mud in the logs) ?
Excuse me on my English, English is not my stronger side
Offline firefighter
« Reply #63 on: December 17, 2009, 05:13:43 PM »
Hye Piston nice pictutes ann congrats on the new mill ,I like the way Jim-Rodgers showed how to make the stickers and cut and stack them I will try that again good luck and a merrt Christmas.
Offline Kevin
« Reply #64 on: December 17, 2009, 05:51:45 PM »
For your own scales...
http://www.forestryforum.com/board/index.php/topic,3439.0.html
use the search feature  ;D
Here's another old one ...
On the LT if you tighten the clamps too much you can force the cant off the bed on one side.
I have a feel for it now and just snug them up, wiggle the handle on the clamp when in doubt checking for any movement.
The other problem I just ran into was when checking the dogs I found them to be square but when I applied pressure to the cant it would move about 1/8" back until the dogs moved back to the stops.
A quick adjustment to the stops and everything is perfect, and I mean dead on corner to corner on the cant.
I level the bed, string it, check the band height on both sides against the bed, check the dogs for square and I'm good to go!
On the second cut of the cant the finished side goes against the dogs and I look for any space between the wood and the steel dogs, there shouldn't be any space.
For the third cut, with one finished side on the bed and one finished side on the dogs and without using the clamps the cant should be square to the dogs and bed.
If I loosen the clamps after the cut and the cant moves I have something out of adjustment.
I can mill all day long without rechecking for square.
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #65 on: December 17, 2009, 07:13:32 PM »
On my LT15, I get from 500 to 600 BF on a blade, but I wash off the logs using a spray nozzle on a water hose before sawing.
Anyone know what brand mill this is?
Started by Nikd on Sawmills and Milling
Last post January 19, 2019, 10:14:47 PM
by homesteader shane
Does anyone here use a Brand X Mill?
Started by farmhand on Sawmills and Milling
Last post April 01, 2005, 06:38:04 AM
by Fla._Deadheader
Last post February 15, 2019, 07:21:05 AM
by thecfarm
Trying to decide what brand of mill to buy
Started by MesquiteSawyer on Sawmills and Milling
Last post May 17, 2011, 11:43:40 AM
by Bandmill Bandit
