Author Topic: hand-sharpening w/ file & guide  (Read 14155 times)
Offline beenthere
Re: hand-sharpening w/ file & guide
« Reply #60 on: January 12, 2010, 10:39:24 AM »
...........  Is there a guide that allows you to use the full length of the file?
Yes
And for all the comments about filing, be it by hand or by sharpening wheel.....one still has to know what the tooth should look like when it is filed correctly, and and then adjust the sharpening method to make it correct, if necessary.  Same goes if sending the chains out for sharpening. If they come back and are not right, don't want to have to find that out when in the woods cutting.
Offline farmer mark
« Reply #61 on: January 16, 2010, 10:46:24 AM »
Not sure if some one else covered this but.  On oregon chain box said file @ 10 degrees.  UNLESS using file guide then file flat across.  Not sure why but does seem to work better.  Only took about 5 years to read fine print on box
Offline Al_Smith
« Reply #62 on: January 16, 2010, 11:25:24 AM »
Well this will probabley sound like nonsense but I just checked out three chains Oregon ,Arbor Pro and Stihl .
The Arbor pro and Stihl had thicker tops plates and a less square transition from top to side plate on the underside of the cutter than Oregon .In addition the side appeared to be slightly thicker near this transition than Oregon .
The Oregon as has been stated is designed to use a 10 degree up while the other two are straight . It would be my assumtion that possibley this 10 degree would form a better working corner on that slightly different chain design .
One must keep in mind the side of the cutter is what does the work and the top plate removes the chip but the key to it all lies in the corner of the tooth .If that corner is not correct the chain will not cut as well as it should .
To reiterate from my own experiance a chain that's supposed to have a compound angle will cut okay straight .A chain that's supposed to be straight doesn't do well with a compond angle .One of lifes little lessons I learned along the way .
Dexter File Guide
Started by Tripp on Sawmills and Milling
Last post March 30, 2010, 08:43:51 AM
by Chuck White
Dexter file guide
Started by Jgreen on Sawmills and Milling
Last post March 20, 2018, 04:50:26 PM
by Bobby R
Oregon file guide
Started by Danny_S on Chainsaws
Last post April 09, 2004, 01:23:00 PM
by Oregon_Rob
Back to the Basics....file guide
Started by otto81494 on Chainsaws
Last post July 28, 2017, 06:50:28 AM
by khntr85
