Arborwear
Author Topic: Thanks for help Forum Members  (Read 864 times)
Offline groundguy
  • Keep it simple man,, keep it simple
« on: January 17, 2010, 03:14:02 PM »
Quick thank you note.  Thanks to members responses, I am making some headway with getting my 550 into shape bit by bit.  The website www.roadranger.com  was great for the axle assemblies etc.
The tire issue I initially asked about turned out to be nothing more sinister than low air,, tires are OK and the one has now reseated it's bead out the edge of the rim where it belongs!
Had to add 10 litres to get my front diff back up to full, so the next challenge is to determine the cause of fluid leaking from the axle seal or wherever.  Front right wheel.  I will try retorquing the bearing, and if that doesn't work, then I imagine seals are the next thing to pursue.
Thanks again
groundguy
Offline bushmechanic
  • Someone else has it worse than you.
Re: Thanks for help Forum Members
« Reply #1 on: January 17, 2010, 06:07:35 PM »
I would imagine that is why most of us are on here to help others and get help when we need it. 8)
Thank you to the Forum and all its members
Started by lawyer_sawyer on General Board
Last post November 20, 2005, 03:52:48 AM
by lawyer_sawyer
a big thank you to all forum members
Started by Polly on General Board
Last post February 24, 2009, 10:14:09 PM
by DanG
smiley
How many forum members does it take...
Started by Ianab on General Board
Last post May 25, 2004, 08:37:00 PM
by ARKANSAWYER
Forum Members
Started by Autocar on General Board
Last post November 09, 2011, 07:28:37 PM
by Tom_Averwater
