Author Topic: arch build help  (Read 2353 times)
Offline bedway
arch build help
« on: February 02, 2010, 04:15:47 PM »
Im in the process of building a logging arch. As is the case with everything im over building it,not only for my use but for possible sale in the future. Ive studied several of the factory and home built versions, and im trying to incorporate different ideas. Currently a hank crank winch is what im thinking for lifting the logs. Does anyone have any brands or recommendations.
Offline sprucebunny
  • Gender: Female
Re: arch build help
« Reply #1 on: February 02, 2010, 05:08:49 PM »
The hand crank winch on my Future Forestry/Logrite arch works well but the hub of the winch is too small a diameter for the wire so the wire ALways springs loose.
I keep meaning to buy a length of Amsteel Polyester winch line for it and that would make it perfect.
Just something to think about.
I don't think there are very many hand crank winches available with a 2000-2500 pound rating.
Offline BARPINCHER
Re: arch build help
« Reply #2 on: February 02, 2010, 07:22:30 PM »
Graingers sells several differnt kinds with that rating and more.  Better have lots of extra scratch tho..$800 and way up from there.
Serving hunters and the hunted with science based; non-traditional resouce management methods
Offline Quebecnewf
Re: arch build help
« Reply #3 on: February 02, 2010, 08:01:54 PM »
I have no winch on mine just a sloped pipe with a ring on it with a hook hung on the ring. I choke the log(s) with the chain hook the chain in the hook hanging in the ring and foward movement forces the ring to slide up the pipe and this lifts the ends of the logs of the ground. When you arrive just back up and the logs lower to the ground. Less fussy than a winch I find.
Quebecnewf
Offline Onthesauk
  • Still learning!
Re: arch build help
« Reply #4 on: February 02, 2010, 08:44:53 PM »
Kind of like this:
John Deere 3038E
Sukuki LT-F500
Donít attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Offline jander3
    • Anderson TimberWorks
Re: arch build help
« Reply #5 on: February 02, 2010, 09:38:51 PM »
I installed this hand-winch from northern tool Note:Please read the Forestry Forum's postion on this company.  I was not too sure about the auto brake set up.  But after I've used if for a couple of years, I wouldn't go with any other hand winch.   This set up handles 25 foot 900# logs...no problem.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_28674_28674
I chain the log to the clevis hooks on the arch for moving it so that I don't rely on the winch.
Offline Quebecnewf
Re: arch build help
« Reply #6 on: February 03, 2010, 06:32:31 AM »
Onthesauk your setup is about the same as the one I built. I see you have a flat section on the top end of your slope. I wish now i had done that to mine. It still does what I use it for fine. I use mine at the mill to haul logs up a ramp onto the log deck. The winch idea is good to but it seems maybe you can do the same work with no winch and unhooking is just a matter of backing up
Quebecnewf
Offline sprucebunny
  • Gender: Female
Re: arch build help
« Reply #7 on: February 03, 2010, 02:35:46 PM »
Here's a link to a company that makes a wide variety of hand winch models at reasonable prices. I've seen this brand at lower prices in a catalog so, shop around !
Dutton-Lainson
Offline bedway
Re: arch build help
« Reply #8 on: February 05, 2010, 01:05:19 PM »
Well, i was going to post some pics of the arch im working on because i was able to put them in my gallery. For some reason i cant seem to put them in a post. Its no surprise though because im not the sharpest tool in the computer woodshed.
Online Hilltop366
Re: arch build help
« Reply #9 on: February 05, 2010, 01:41:25 PM »
Did you close the photo album and reopen it if not you can try to go back and try again
Offline Onthesauk
  • Still learning!
Re: arch build help
« Reply #10 on: February 05, 2010, 08:45:13 PM »
Bedway,
That's a sturdy looking arch!  Going to use it behind a ATV or tractor?
John Deere 3038E
Sukuki LT-F500
Log arch build (first try)
Started by Vautour on Sawmills and Milling
Last post Yesterday at 09:38:50 AM
by Crusarius
A log arch build...
Started by ljohnsaw on Sawmills and Milling
Last post March 20, 2014, 11:46:04 PM
by ljohnsaw
Want to build a log arch
Started by wvwoodchuck on Forestry and Logging
Last post February 11, 2012, 06:38:57 AM
by Lud
log arch build
Started by Revival Sawmill on Sawmills and Milling
Last post June 11, 2019, 07:29:57 AM
by kelLOGg
