Arborwear
Author Topic: Off w/ the Screw Clamps,, On W/ the Cam Clamps  (Read 6958 times)
Offline robnrob2
  • Always striving to make the tree proud.
    • Wood Crafting Woodworks
« on: February 03, 2010, 08:10:42 AM »
Well now that I have the hydrolic feed working well, and the board return is an added plus, I still had the screw type clamps for securing the logs,, and they worked as expected, but you gotta wind them in to hold the log, and when done un-wind them, which may only seam like a few seconds or so each way, but as the day wears on you do start to realize how much time you spend, turning and then turning again,,
There were 3 like this, that actually needed to go,, there are really 4 but the one I kept doesnt get used much, it's down at the front of the mill for doing short stuff as short as 24-30",, hobbiest wood..
Heres another one.
,, After much, much studying this style, and looking at lots of pictures and stuff,  Here all the parts ,,
 All the parts have been fabricated, painted and assembled,
Since the original clamps are of 1 1/2' square tubing, I used 1/4 x 1 1/2" faltbar for the main body,, The cam was cut from 1" round bar, 1" long and a 5/16" hole drilled way off center,, the handle is 1/2" round bar cut at 6 1/2" long,, the clamping bar is 1" square tubing cut at 6" long w/ 1" x 3/4" bar for the spike and welded on top.
Welded on,,Now the new cam clamp has been added, works very nicely, and actually has much more clamping force then you really need.,, in fact thiis photo half clamped,, the handle will go all the way down.
closer up,,
I reckon as time goes on I may some day  as the pocket book allows, do a hydrolic clamp and truner,,
Offline bandmiller2
Re: Off w/ the Screw Clamps,, On W/ the Cam Clamps
« Reply #1 on: February 03, 2010, 08:59:33 PM »
Good job Rob,What does that cam assy. slide on at its base.Does it slide on square tube and bind when you cam it??Frank C.
Offline TJB
    • TJ'S Wood Shop
« Reply #2 on: February 03, 2010, 09:05:45 PM »
I like those!!!  I think I need to upgrade to a set of them.
TJ
Offline robnrob2
« Reply #3 on: February 04, 2010, 07:37:26 AM »
Thats it  the square tubing is 1" and so is the cam,, so it mainly pushes or applies the preasure on the 2 corners,, I thought about sliding a piece of 1/6" or 1/8"  in there and letting it slide on that, but we'll see how it wears,, I did put a spot of grease on it before use..
Thanks Robert
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: February 04, 2010, 09:13:13 AM »
I love to see the fine examples of craftsmanship that are displayed here on FF..... 8)
It makes us all proud..... :D
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #5 on: February 05, 2010, 06:39:00 AM »
I have the same frustration - what a well executed solution and good workmanship. That will be my next sawmill mod. 8)
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline bandmiller2
« Reply #6 on: February 05, 2010, 07:25:42 AM »
Everything on a mill should be quick and easy to operate,if something is owkward hard to reach or just not handy you tend to not use it.Screws are ok if they have a fast forward like a half nut so all you need is one twist to tighten.Alot of circular mill dogging systems work well on a bandmill just lay them down,such as the Belsaw clamps.Frank C.
Offline kelLOGg
« Reply #7 on: February 10, 2010, 12:47:03 PM »
How much throw do you have on the clamp?  (or how far does the spike travel?). I'm making my own after your idea and am trying to decide just how much I need. (I tried to PM you but it got kicked back).
Thanks,
Bob
Offline robnrob2
« Reply #8 on: February 11, 2010, 08:06:35 AM »
Well I just went out and measured it, the throw, and it is a good 1 1/4"  and leme tell ya, ya dont need that much,, I didnt consider throw, I just wanted to make sure it worked,, so with the piece of 1" round bar, I  1st drilled a 1/4" pilot near the edge, but with plenty of room to redrill to 5/16 and not be to close to the edge,,when I welded the handle on, as the whole assembly was just loosely sbolted together, and on the bench, I rotated the cam till it was just past center, and then glued, er welded the handle on,,  You cannot lock these if you ram them up against a log or cant,, to much throw,, so we actually have to pull back a lil bit,,,But I would say I think more throw is better then not enough,,
Now my bottom clamps,, you know the ones,, the ones ya use when you wanna cut down to within 1",, there a screw type,,they will be next, but on those I have to have a lil bit different handle config, as those bottom clamps slide on a 1" round bar, and the handle cannot hit the round bar slide,,
Offline kelLOGg
« Reply #9 on: February 11, 2010, 07:02:57 PM »
I drilled a 3/8" pivot hole for my 1" cam and got a little more than a 1" throw. I think I will go with that. I can change the cam easily if its necessary to to get more throw but I don't I will need it.
I think my spike shape (1/2" x 2") will allow me to use the same spike for the last cut but that remaine to be seen.
Thanks,
Bob
Offline papow22
« Reply #10 on: June 24, 2014, 01:07:00 PM »
I would have applied that to "the useful sawmill mods".Nice idea even though. ;)
Lives to do sawdust,run a trapline,hunt big game,live life to it's most.Got 4 mills a circle mill,(2 band sawmills) Norwood's 2000, Trim Saw,Beam Machine (chainsaw mill).
Offline coastlogger
« Reply #11 on: April 05, 2017, 08:13:51 AM »
hopm could you explain the railroad spike thing a bit more. Sounds like something I could use.
clgr
Offline brewdog
« Reply #12 on: April 17, 2017, 05:40:02 AM »
would like to see what its sliding on[bottom]  thanks
Offline kelLOGg
« Reply #13 on: April 17, 2017, 07:31:24 AM »
Mine slides on a 1" solid rod.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #14 on: April 17, 2017, 09:02:20 AM »
I made mine really different. I used part of a rack and pinion.
I only used the the rack. with a slide almost like the picture above.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Quebecnewf
« Reply #15 on: April 18, 2017, 04:41:07 AM »
KelLoGg
Anywhere one could buy the one like you made. My long clamp slides on a one inch round rod as the the one you made but it is screw type . While it works fine and I have used it for many years (25) I would switch to the lever type if I could get one . I don't do any welding so fabbing one up myself is not an option .
Know of any mills that come with type of long clamp maybe I could buy one from them .
Thanks Quebecnewf
Offline kelLOGg
« Reply #16 on: April 18, 2017, 06:11:34 AM »
I looked on CookSaw web page under sawmill videos and found this:
It's similar to what Robnrob2 and I made.
Bob
Offline kelLOGg
« Reply #17 on: April 18, 2017, 06:15:26 AM »
oops, I didn't know I posted the whole video. Skip to 30:50 minutes to see the clamp.
Bob
Offline ljohnsaw
« Reply #18 on: December 13, 2017, 04:50:17 PM »
When I made my mill, I made these (though both had a longer section of 2" x " tube).
But they are a bit difficult to use.  So when I found this thread, I knew what I wanted to do!  So here is the replacement:
There is about 1" of throw.  If I decide I need more, I can lower the cam closer to the spike pivot.  The bolt are 5/16" Grade 8.  Note the bright orange so it is easier to aim the blade...
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline kelLOGg
« Reply #19 on: December 14, 2017, 07:29:18 AM »
Nice work - post a pic when they are installed, too.
Bob
Using clamps?
Started by WoodChucker on Sawmills and Milling
Last post September 07, 2003, 08:37:19 PM
by Lickskillet
What clamps?
Started by Brad_bb on Timber Framing/Log construction
Last post July 22, 2008, 09:07:08 PM
by moonhill
Clamps
Started by Norm on General Woodworking
Last post January 13, 2010, 02:56:23 PM
by scsmith42
Log clamps
Started by Arkyrick on Sawmills and Milling
Last post April 05, 2017, 03:57:29 AM
by addysdaddy
