Author Topic: Sawing a $50 sheet of Oak Veneer  (Read 2279 times)
Offline D._Frederick
« on: February 08, 2010, 02:55:01 PM »
My project requires me to saw up a 4 x 8 sheet of veneer. I will saw it on my Powermatic with a 72 tooth blade, but the bottom of the cut always have some splinters.
I suppose a $200 - $300 blade would help, but it won't happen. Any suggestions to get a better cut?
Offline SwampDonkey
  • Large Tooth
Re: Sawing a $50 sheet of Oak Veneer
« Reply #1 on: February 08, 2010, 03:05:25 PM »
The insert on the table top around the blade might not be flush with the table and possibly not close as it could be to the blade on all 4 sides. Try making a home made one from a 1/2" sheet of plywood and cut the hole out by raising the blade up through it. See if that works any to cut down on tear. Maybe even score the pencil line with a utility knife before ripping.
Helps with stacked daddo blades.
Move'n on.
« Reply #2 on: February 08, 2010, 03:21:28 PM »
I've heard it recommended to place a backer board of scrap against the good board to stop splintering too.
Perhaps another sheet of plywood beneath the  expensive veneer, if you can keep it tight. You might even experiment with gluing one to it temporarily.
Offline SwampDonkey
  • Large Tooth
« Reply #3 on: February 08, 2010, 03:28:37 PM »
I must say, that's pretty cheep veneer compared to here. Shop grade 1/2" Oak alone is $80 a sheet.  But so isn't yellow birch. :o
Move'n on.
Offline bedway
« Reply #4 on: February 08, 2010, 03:35:41 PM »
Put masking tape on the bottom side of the cut. This helps reduce the tearout greatly.
Offline pigman
« Reply #5 on: February 08, 2010, 03:39:41 PM »
What the others have said plus only raise the blade just high enough to cut through the material.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #6 on: February 08, 2010, 04:09:30 PM »
Do two passes per cut. The first pass is a scoring pass with the blade raised just enough to score the substrate, The second cut is thru' and thru'. A sharp blade is just assumed.....
cheers
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline beenthere
« Reply #7 on: February 08, 2010, 04:43:19 PM »
Plywood does need a sharp blade, as well as a virgin insert in the table top. Sawing across the grain on the face plies will be the hardest ones to make without some splintering.
How thick is the panel?
Offline Larry
« Reply #8 on: February 08, 2010, 04:49:31 PM »
Brand new zero clearance insert for the saw and masking tape on the top.  Use the blue kind and when you remove it pull at a angle slowly.  Also make sure your rip fence is aligned to the blade...if it is pinching a bit at the back it will pull splinters on the crosscut no matter what you do.  I normally also run a splitter.
« Reply #9 on: February 08, 2010, 06:13:30 PM »
The Sheet is 3/4 - and bought from home depot, it is red oak and cost $40 + two 3/4 inch dowels for a total of $50 when I looked at the recipt. Other hard wood were in the $55 -$60 range. Prices are down because there is no building.
I have a new insert that I haven't cut the blade a thru, will give it a try on some scrap.
I forget the article I was reading, but some guy had wrote in saying to spray rubbing alochol on the cut line were the saw comes out and that it soften the wood fiber so that it cuts better. Has any one tried this?
I know that scoring works, has anyone bought a scoring blade add on for the Powermatic or Delta? Which way would run the board thru to score, teeth coming out or into the board?
Offline Don_Papenburg
  • I need money
« Reply #10 on: February 08, 2010, 10:07:31 PM »
I think that the scoring blade turns in the opposite direction of the main blade.
« Reply #11 on: February 18, 2010, 01:18:23 PM »
I cut-up my sheet of veneer and used my new zero clearance saw insert, found that a better job was done on the bottom of the sheet than on the top. I had the saw raised about 3/8 of an inch above the cut. The quality of the cuts require no further work.
Sawing a crotch for veneer
Started by peterduncan on Sawmills and Milling
Last post July 26, 2008, 07:24:39 PM
by Tom
Sawing cherry veneer cores- photos
Started by Dana on Sawmills and Milling
Last post February 01, 2006, 10:29:27 AM
by Dana
Bid sheet sent out.
Started by gizmo on Forestry and Logging
Last post August 18, 2018, 08:48:09 PM
by gizmo
Cheat sheet
Started by dean herring on Sawmills and Milling
Last post July 06, 2018, 08:01:22 AM
by moodnacreek
