KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Log Grab  (Read 10205 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Re: Log Grab
« Reply #20 on: February 13, 2010, 10:09:04 AM »
I've used Tom's method and it worked great.   Almost never dropped a log in the wrong place.   However, I have to agree with  jimparamedic  on the forks.  With forks you don't even have to get on and off the tractor.   I don't know how I got by before I bought my pallet forks.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log Grab
« Reply #21 on: February 13, 2010, 11:33:41 AM »
But if you load and unload a trailer with sides, you'll need to use the suspended method at times.
Offline captain_crunch
Re: Log Grab
« Reply #22 on: February 13, 2010, 01:23:41 PM »
I need to buid me a set like M_M's. but with my A frame set up anything less than 12ft I resemble a heilicopter getting to mill ;D ;D
Offline Gilman
  • !eliforp ym tide ot deen I
Re: Log Grab
« Reply #23 on: July 08, 2017, 09:43:23 PM »
Here's a pair of End Hooks I found today.  Made by Young.  I don't know how old they are.  A lot newer than the tongs though.
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Log Grab
« Reply #24 on: July 09, 2017, 07:27:40 AM »
Congrats on your find.  It was also nice to read through this old topic.   :)
Offline Gilman
Re: Log Grab
« Reply #25 on: July 14, 2017, 12:19:49 PM »
Used the lifting hooks for the first time today.  I had a log in the back of some lumber I needed and couldn't reach.  Normally I would have choked the log and lifted the mast to 20'.  They're heavy.  I was going to get a mallet to drive the spikes in but they are heavy enough I just swung them at the ends of the log.  The point buried itself enough to hold it in place until I applied some tension.  I think these hooks were intended to be hung from a log/beam.  There are release holes in the body of the hooks that if pulled would release the tongs from the log if they were rigged correctly.
Make sure to test all lifting devises over your sawmill.  ;)
Online bandmiller2
Re: Log Grab
« Reply #26 on: July 14, 2017, 07:57:51 PM »
Be they tongs or end hooks none are 100% reliable, in other words don't have them hanging logs over anything you wouldn't want to loose. Frank C.
makin a log grab
Started by weisyboy on Forestry and Logging
Last post March 18, 2011, 08:28:11 PM
by Ironwood
Going to grab my chainsaw in the morning!
Started by Woodhauler on Forestry and Logging
Last post April 09, 2015, 03:49:33 PM
by Woodhauler
