sawmill to firewood processor
Started by woodmills1, February 12, 2010, 08:18:12 PM
woodmills1
needed to cut something after the feed roller change so put on some firwood logs too large for the processor.  I was thinking to quarter or otherwise pare them down to fit the multitek.  It went just fine, the thing must have had bad rollers since I got it, don't know why with so few hours.
here are some shots
a lumpy oak needing trimming
cutting off the nubbins
quartered and ready for the mutitek
It worked out well though the crooked ones still didn't feed into the processor too well
Bibbyman
I do the same things with big firewood logs.  Often I'll just cut off the top third and then turn up the big half and split it.
Sawing since '94
dovetails
Quote from: Bibbyman on February 12, 2010, 08:29:23 PM
I do about the same with gum logs,but I make 6x6's or4x6's,they stack great, dry faster, and fit the stove nice too.Also, no bark all over the place.The mill cuts them a lot easyier than using the log splitter!
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
Wood burning and milling key togather well.I'am never afrade to slab hardwoods on the heavy side not much better than a good hardwood slab to burn plus you get the lumber.We would cut for oak logs,tops and slabs for heat nothing wasted especially with firewood as valuable as the boards. Frank C.
