Author Topic: Stihl ms460 compression  (Read 3615 times)
Offline 732hess
« on: February 14, 2010, 01:28:12 PM »
Just purchased used saw, and have run a couple of tanks of fresh fuel mix. Saw seems to start, run and cut well. I checked compression, 5 pulls, showed 165# with snap on gauge with hose, then drops to 155 # and will hold that pressure, is this in the normal range ?. Saw probably has quite a few hours running time would be my guess.
Offline chevytaHOE5674
Re: Stihl ms460 compression
« Reply #1 on: February 14, 2010, 06:41:44 PM »
150 is a good number. One of mine 460's didn't have much more than that from the factory.
Offline tlandrum
« Reply #2 on: February 14, 2010, 07:13:39 PM »
i have them from 150 to 195 depends on saw and how old and whats been done to them.
www.wickedworksaw.com
wickedworksaw@gmail.com
Husqvarna and jonsered dealer
chainsaw porting for high production work saws
4233465399
Offline 732hess
« Reply #3 on: February 14, 2010, 07:25:08 PM »
I checked it cold, is that correct ? or should saw be warm ?  Does it matter how many times the starter rope is pulled ?
Offline Cut4fun
« Reply #4 on: February 14, 2010, 07:31:34 PM »
I keep at it till the needle on the gauge quits moving, depends.
Offline Al_Smith
« Reply #5 on: February 14, 2010, 08:24:43 PM »
You have to remember that a gauge reading is static pressure .Because of the way two cycle piston rings seal under pressure the dynamic or under running conditions will be higher .
MS460 Compression 120 psi
Started by terrifictimbersllc on Chainsaws
Last post July 06, 2010, 09:23:25 AM
by Michael
WTB- Stihl MS460
Started by blueberrymuzik on Wanted
Last post January 14, 2014, 08:45:47 PM
by SquareG
Stihl MS460
Started by Good Feller on Chainsaws
Last post July 21, 2008, 09:30:22 PM
by jokers
New MS460 Stihl
Started by magic on Chainsaws
Last post January 06, 2004, 07:17:55 AM
by smokechaser
