Author Topic: Locksmith help needed – broke key in Terex ignition switch.  (Read 8938 times)
Offline Bibbyman
    • Warden Sawmill
« on: February 20, 2010, 02:40:46 PM »
We managed to break the key off in the Terex ignition switch.  Due to the odd way the switch key is made and operates, the broken off part of the key is “down in” the tumbler and we can’t get at it to pick it out.
The switch is pretty complex.  First the key must push a little trap door open at the top.  Unless this trap door is pushed open, the switch won’t turn.  Then the whole tumbler pushes out about 1/10” once it’s off the “off” position.  To turn the ignition off,  the key must be turned back and pushed in.  The tumbler section of the switch does not start until about 1/4” under the trap door – giving the trapdoor space to swing open.
We took the switch to the local NAPA store with the hope that maybe there would be a generic switch we could get to replace this one.  The NAPA guy said no way unless we cut off the connector and put each wire on separately – no plug and play.
He did jump on the switch like a goose on a junebug.  We had noted a hole at the base of the tumbler but could not do anything by probing into it to get the tumbler out.  He NAPA guy was insistent that the tumbler should come right out if the pin in the hole was pushed.  He worked and wiggled on it for 5 minutes and made no headway.
Here is the ignition switch.  The arrow points to the hole that looks to be the key to removing the tumbler.
Any locksmiths out there?  Ever seen anything like this before?
Sawing since '94
Offline james
  • truck drivin fool
Re: Locksmith help needed – broke key in Terex ignition switch.
« Reply #1 on: February 20, 2010, 06:49:11 PM »
the hole is to release the tumbler , BUT it only works with the switch in one position , and that position is different with each machine
james
Offline Bibbyman
    • Warden Sawmill
« Reply #2 on: February 20, 2010, 07:44:27 PM »
james
I've tried it in every position but standing on my head!
In the "Run" position it looks like it aligns up with something but I can't push it by hand with a small screw driver.  Does it require a lot of force?
We’ve got a backup plan in the works.  I found one on E-bay and have it on order.  But if I can get this one fixed, I’ll use it.  If the other comes first, I’ll still try to get the old one fixed for a spare.
Sawing since '94
Offline dovetails
« Reply #3 on: February 21, 2010, 04:42:41 AM »
Just got to ask, how did you break the key off?
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
Offline Bibbyman
    • Warden Sawmill
« Reply #4 on: February 21, 2010, 09:13:06 AM »
That's right up there with "Well, where did you loose it?"  ;D
Let's see.  We've been running it for 8 years.  We don't let it run all day so every day it gets started and shut down at least a dozen times.  I don't have a picture of the key but it got a big rubber handle part and then the key itself is only about 5/8" long and about 1/4" wide - about as heavy as a briefcase key.  We don't take it out of the switch so that part didn't wear going in and out.
Also there is the actions that the key has to do - push and turn, etc.
This is the second key that broke. The first one broke not long after we got the machine.  But it off with some sticking out so we could get ahold of it.
Sawing since '94
Offline Faron
« Reply #5 on: February 22, 2010, 01:29:53 PM »
We broke one off in our Ford 276 bi directional tractor.  It broke off quite a way in the keyhole, so for a while we could just stick the broken off key in and start the tractor.  Seems to me we took the switch out and used a magnet and gravity to get the key out.  It was the only key we had, so we glued it back together so we could use it to make a new one.  The way you describe yours, I am not sure you can get it out with a magnet.
Democracy is two wolves and a lamb voting on what to have for dinner.  Liberty is a well armed lamb contesting the vote. - Ben Franklin
Offline Bibbyman
    • Warden Sawmill
« Reply #6 on: February 22, 2010, 01:58:08 PM »
I think its brass.  ::)
Sawing since '94
Offline LAZERDAN
« Reply #7 on: February 22, 2010, 09:28:28 PM »
I've hade this happen to me. on the gen set.   did you try a medical tweezers ( you may have to grind it narrower)  they usually have the little spikes that dig in.  If you can tap and pull and again and some luck.. good luck   Lazerdan
Offline trim4u2nv
« Reply #8 on: February 22, 2010, 10:05:30 PM »
Try to put the broken piece back in by pressing the shutter and tumblers aside.  If you can get both pieces aligned properly the key will turn and you can press the release ring through the acess hole you showed in prior posting.   The plug will pull out and you can replace it or remove the broken key fragment.
If you cant get the plug to turn you can pull the fragment and the head of the key together using guitar strings,  welding tip cleaners, or small fret saw blades.  This might take some dexterity and some previously mentioned medical tweezers or hemostats.  Just slide your tools down the millings in the key fragments and use a good light to see the inner workings.
Offline Bibbyman
    • Warden Sawmill
« Reply #9 on: February 22, 2010, 10:38:34 PM »
Thanks for the help.
The tumbler will turn to all positions.  The "run" position there looks to be something in the hole.  But I can't get it depressed using a paper clip or jeweler’s screwdriver and hand pressure alone.
Do I need to use more force?  As in drive a nail into it?
The broken key fills the hole completely and flush to the top of the tumbler.  We’ve used such items as a straight pin and not been able to get past the top of the key.
I have another switch unit on the way.  Once I’ve got it and the machine back up running.  I’ll find some way to get the key out of this one – even if I have to destroy it in the process!
Sawing since '94
Offline trim4u2nv
« Reply #10 on: February 22, 2010, 10:47:07 PM »
If the key fills the hole completely then turn it to the off position (otherwise the key wont come out.)  Take a dremel tool or similar item (pc board drill or dental drill) and cut into the soft brass and make a toehold and pull the key out with a dental pick.
Offline Paul_H
« Reply #11 on: February 23, 2010, 12:01:42 AM »
trim4u2nv
That's what my next door neighbour did for me when the key broke off in our Case 1840.He was a locksmith a few years back and had a knurled or jagged pick that dug into the key enough that he could snag it out with a few tries.
Bibbyman,
The way you describe the key,I think ours are the same.The keys weaken over time and then snap,it's gone.
eg  tregar  meste  pε  Tulla, for  ho  var  krulla  i  ulla.
Online beenthere
« Reply #12 on: February 23, 2010, 12:17:39 AM »
Possibly try a very small coping saw blade, shoved down alongside the broken part with the teeth angled back.
If too little room, grind the set off the teeth on one side opposite the key.
Years ago managed to get one out that way. But don't know if there is room on yours to do that.
Offline trim4u2nv
« Reply #13 on: February 23, 2010, 12:21:16 AM »
If you want the good stuff call these guys for a replacement
http://www.colehersee.com/pdf/C-Ignition.pdf
Offline DanG
« Reply #14 on: February 23, 2010, 12:44:43 AM »
Put a tiny drop of Super Glue on the part that ain't in there and stick it to the part that is in there.  Better yet, replace the switch with a toggle switch and a button.  I sure as heck wouldn't put another key switch like that one in there.
Offline ely
« Reply #15 on: February 23, 2010, 07:05:42 AM »
my bobcat key is broke now, been broke for awhile. waiting for a replacememnt key. so i been using a small screwdriver to crank it.
Offline Bibbyman
    • Warden Sawmill
« Reply #16 on: February 23, 2010, 09:34:01 AM »
We used the Terex for days by sticking the broke off part back in the switch.  But we didn't want to go on living that way.  We have two extra keys but they do little good with the one broken off in the switch.  I never had an idea it'd be this difficult to get the borken key out.
Sawing since '94
Offline pineywoods
« Reply #17 on: February 23, 2010, 10:17:50 AM »
The last time I had to extract a broken off key, I pried the electrical switch part off. Then drilled a small hole, about 1/8 inch in the back of the tumbler block and ran a small pin punch through the hole. Pushed the broke off key out from the back..I'm with Dang, I'd replace the whole thing with a toggle switch and a push button switch.
Offline DanG
« Reply #18 on: February 23, 2010, 11:11:55 AM »
Ya know, as I think about this more, I'm gettin' plumb mad!  Just what the heck are those people thinking?  I mean, they build a big fine heavy duty machine like that and sell it for big bucks, and then equip it with a rinkydink toy key that habitually breaks off in the switch!!  For cryin' out loud, the key for our minivan is stout enough you could open oysters with it and you can have a new one made for a buck!  A lousy DOLLAR!  Can you imagine being a building contractor and having six redi-mix trucks lined up waiting on that machine, just to have it disabled by a broken key? :o :o :o  And the real sad thing is that Terex knows about the problem and has known about it for a long time, and hasn't done a DanG thing about it.  All the while, their CEO is "earning" million$ a year to run a tight ship!  I'd like to ask one of those people how they manage to sleep at night, or swallow their filet mignon without choking!
Offline Bibbyman
    • Warden Sawmill
« Reply #19 on: February 23, 2010, 02:11:43 PM »
DanG!  You're madder'n I am about it.   :-\
Add ADCO to the list then because I had a switch go out on our tractor.  That was some time back.  It cost over $60 for a new one.  At least we were able to find one for $28.17 on e-bay.
The way we used the Terex is probably not like most people.  We start and stop it at least a dozen times a day.  If it were used in some application where it had one driver using it until noon break and then again after noon, then the key would be used far less.
The same thing with our mill.  Being electric, we turn the motor off and start it a lot more than we would if it were an engine.   We've got 8 years and about 5,000 hours on that switch.  Its probably been cycled a couple 100,000 times by now.  But it appears to be a simple generic switch we could probably find in town.
Sawing since '94
Ignition Switch
Started by bradandrose on Chainsaws
Last post December 01, 2003, 10:43:32 AM
by Viking
new ignition switch.
Started by ely on Sawmills and Milling
Last post December 23, 2014, 08:49:47 AM
by ely
ignition switch for honda gx630
Started by horseman on Sawmills and Milling
Last post September 21, 2010, 11:33:44 PM
by horseman
Must the ignition switch be off when compression testing?
Started by zoltar on Chainsaws
Last post November 20, 2017, 05:41:55 AM
by zoltar
