Indentation on veneered plywood
Started by D._Frederick, April 05, 2010, 12:03:34 AM
D._Frederick
I have an indentation that occurred during sawing on my oak veneered plywood. I don't think that I want to try to sanding it out, its about .005 to .010 deep and it runs the width of the board.
If it was on solid wood, I would steam it out. Any suggestion on this veneer?
LeeB
Ernie
I'd try water first then steam, depends on the glue used for the laminations----I think.
CHARLIE
I'd put a moist towel on it and iron it out.  If the glue let go, I'd inject some back under the veneer with a needle.
Charlie
