Author Topic: Naarva Felling Head?  (Read 1910 times)
Offline JDeere
« on: April 28, 2010, 08:07:45 PM »
Has anybody ever used a Naarva felling head on their excavator. I am researching what is available for a 16 ton excavator and came across that brand. I would like to put a head on my machine for winter but don't really want to buy an un-tested unit. Thanks for any info.
2013 Western Star, 2012 Pelletier trailer, Serco 7500 crane, 2007 Volvo EC 140, 2009 John Deere 6115D, 2002 Cat 938G, 1997 John Deere 540G, 1996 Cat D-3C, 1995 Cat 416B, 2013 Cat 305.5E
Offline DDW_OR
Re: Naarva Felling Head?
« Reply #1 on: September 01, 2016, 03:41:44 PM »
what did you get?
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline Big Rooster
« Reply #2 on: September 01, 2016, 11:24:19 PM »
If you want just a felling head try Ryans DS-20 or DS-28.  It is a straight felling head (dangle style) and built really tough
Offline Big Rooster
« Reply #3 on: September 01, 2016, 11:24:37 PM »
Offline DDW_OR
« Reply #4 on: September 02, 2016, 01:43:06 AM »
What i want is a Harvester head that will fit on a 2008 Bobcat 331 excavator.
Naarva S23 = 518 pounds
Arbro 400 = 616 pounds
or a pull through delimber i can use with the Bobcat 331
Bobcat 331, year 2008
Bobcat specs
Horsepower - 41.8 hp
Operating Weight - 7,756 lb
Rated Lift Capacity - 2,416 lb
Auxiliary Std Flow - 15.9 gal/min
Auxiliary Pressure - 2,600 psi
Hours - 2,045
Offline DDW_OR
« Reply #5 on: January 11, 2018, 12:17:52 PM »
getting an Arbro 400 stroke harvester for the Bobcat E80 to cut and delimb the trees.
then a turbo saw for the Bobcat 331 to cut the small trees and the brush.
then use the Brushhound 30EX on the 331 to mow the area
the tree size difference between the Arbro 400 and 1000 is 4 inches and $25,000.
Tracked or 6 Wheel Harvester? Fixed Head or Dangle Head? Pros and Cons Please
Started by danbuendgen on Forestry and Logging
Last post September 07, 2016, 06:29:17 PM
by danbuendgen
440c, head gasket or cracked head?
Started by 5akman on Forestry and Logging
Last post June 30, 2011, 01:41:24 PM
by 5akman
pro and con's fixed head compared to dangle head.
Started by turkytrk on Forestry and Logging
Last post August 23, 2014, 07:10:14 PM
by turkytrk
Poulan Pro 5020 av and Stihl MS 271 head to head
Started by SasquatchMan on Chainsaws
Last post September 26, 2012, 10:10:46 AM
by SasquatchMan
