Author Topic: Cupping and end grain  (Read 2339 times)
Offline TLahti
« on: April 29, 2010, 06:52:39 PM »
Hi All:
I am new to bandsaw milling, and I am not experienced at fine wood working.
After squaring up a log, I usually start cutting boards from one side, and continue down thru the beam until it is too thin to cut anymore, usually about 2 inches thick.
  With this method, the first few boards have broad widely spaced growth rings, and as I get closer to the center, they get closer together, and more square to the face of the board.
I see from a book about lumber, that the first few boards are called "slash cut" and the boards that are cut close to (and thru) center are called "rift cut". The book also mentions "quarter sawing", which keeps the grain similiar to the "rift cut". I have heard of quarter sawing, but it seems nearly impossible with a bandsaw mill.
   My question is, how does the grain orientation affect cupping and warpage?
Do the outer boards warp more than the center cut boards?
   If either warps more, should an effort be made to cut thicker stock from this area of the log?
   Thanks to all the contributers of this great forum.
Terry
Offline woodmills1
  • the truth shall set you free
Re: Cupping and end grain
« Reply #1 on: April 29, 2010, 10:52:28 PM »
I have seen many boards cup, but the most have the pith, center of the tree, in the middle.  Some species of tree are more forgiving, but for the most part any board cut that has  the middle of the tree in it will bend up around that center
now, I think hickory will bend no matter what just to spite you, as well as small white oak.  Pine up here tends to be flat no matter what but don't try for a 22 inch board through the center
just for grins cut a nice 8 inch wide pine from the outside of a good log and just throww it on the ground........2 days later mr sun will curl it like you can't amagin....then turn it over...2 days later...flat...2 days later...o well you get it
Offline SwampDonkey
  • Large Tooth
« Reply #2 on: April 30, 2010, 04:03:28 AM »
This thread on quartering may lead to others on the same subject. A little searching (search function) can find you lots of information. ;D
http://www.forestryforum.com/board/index.php/topic,27916.0.html
Move'n on.
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
« Reply #3 on: August 18, 2010, 11:04:43 PM »
So when you are sawing a log, what do you do with the pith? Most videos I've seen, people saw right through it and keep going.
Also, I am looking forward to finding ways to do quarter sawing on the bandsaw mill after we get it set up and get the hang of using it the regular way.  :P
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Offline SwampDonkey
  • Large Tooth
« Reply #4 on: August 19, 2010, 03:43:00 AM »
I have some cherry cants here from juvenile and pith and every one busted apart from checking. Pretty much firewood.
I don't think they're sawing right through it unless it's a small operation and a well behaved species of wood that there is a demand for. With softwood like spruce they use pretty much the whole log, but hardwood I think they dry it for posts if they have the facilities or make firewood. Most small operators do saw it, but any I've had done are not stable, such as cherry, ash, maple and yellow birch. They all warp and check when air dried. But, with the nature of sawing you don't follow the true heart all the way down the log, you run out of it, so maybe you get a 4 foot piece of clear.
Move'n on.
« Reply #5 on: August 19, 2010, 07:10:36 PM »
Just to make other info available and to save some typing time, this link on another recent thread might be informative.
http://www.forestryforum.com/board/index.php/topic,41916.0.html
face grain vs end grain drying rates
Started by kelLOGg on Drying and Processing
Last post January 24, 2019, 07:50:58 PM
by Don P
Board cupping
Started by fishfighter on Sawmills and Milling
Last post August 12, 2016, 10:22:51 PM
by YellowHammer
Preventing Cupping on Red Oak
Started by fstedy on Drying and Processing
Last post May 15, 2006, 07:10:18 AM
by woodmills1
Cupping Band Blades...Too much Tension?
Started by logwalker on Sawmills and Milling
Last post December 19, 2008, 09:40:13 AM
by MartyParsons
