Author Topic: Stihl 021 will not start  (Read 9124 times)
Offline Gary_B
  • Live to saw and saw to live
« on: May 26, 2010, 10:06:54 AM »
Fellows this one has me stunt.....The saw is getting fuel, and seems to be pretty of fire and will not make a pop. All I did was remove clutch for inspection and replaced sprocket...now the saw will not start..I changed the gas to make sure of no water, I put a teaspoon of fuel in carb, nothing, when I pull the plug it has fuel on it, so with it getting fuel and fire I cannot figure out whats going on, I even pulled the flywheel to check the key, perfect. I think the saw has enough compression..I am going to try and put alittle oil in the cylinder and try starting fluid or carb cleaner. Any ideas out there would be appreciated.
Gary
Offline Gary_B
Re: Stihl 021 will not start
« Reply #1 on: May 26, 2010, 11:27:46 AM »
removed the muffler, the saw started up and ran, removed the muffler guts and put back on wont start, removed muffler again, saw started up....now I am thinking if I might have a compression problem, the piston walls looked alittle suffed up, on the exhaust port.
Offline JohnG28
« Reply #2 on: May 26, 2010, 07:05:40 PM »
With the saw assembled and muffler on, can you hold the saw up by the starter rope, or does the saw slide down?  This is a quick compression test.
Offline Gary_B
« Reply #3 on: May 26, 2010, 09:10:27 PM »
No if you hold the saw up, it does slide down, not fast, but the compression is not strong enough to hold the weight of the saw.
Offline JohnG28
« Reply #4 on: May 26, 2010, 09:54:48 PM »
I think thats a bad sign, you probably have low compression.  Are the rings in good shape?  You said the cylinder looks in rough shape, maybe new rings could get you enough compression to get it running.
Offline Gary_B
« Reply #5 on: May 26, 2010, 11:08:17 PM »
Well the saw is around10 years old and is used primary firewood every season, its a nice light saw for cutting limbs and smaller trees, I use a 28 for larger trees. I have only been able to view thru the openning where the muffler is located. The pistion and rings look a little worn. Might be best to replace piston and rings, I need to tear the saw down and really inspect everything.
Offline JohnG28
« Reply #6 on: May 26, 2010, 11:25:53 PM »
Ya it sucks to have to tear it down just to have a look. Its weird that it will run without the muffler, but not with the gutted muffler though.  It would seem that they would have a pretty similar effect of the engine.
Online Al_Smith
« Reply #7 on: May 28, 2010, 05:57:19 AM »
What has been descibed are the classic symptoms of a completely blown crankshaft oil seal .Although it seems odd it should go by just removing a clutch . ???
If you get one that has blown itself to kingdom come you can pull the rope until you are blue in face and maybe only get a putt every so often .One that is partialy blown might start up cold and run fine for a few minutes then lean out and the saw either run lousey or just die on the vine .
Fact is as I type I have two in my shed with bad seals .Both Macs ,a 10-10 super and a 700 .The very last of the run from the Mac prior to going out of business which surprises me because I've got some 40 years old that have no seal problems .These two are maybe 20 years old give or take and look like new ones . Then come to think of it maybe that's why they look new,bad seals from day one . :D
Offline joe_indi
  • The older I get the more I learn
« Reply #8 on: May 29, 2010, 06:46:32 AM »
Gary,
How did you remove that clutch and put it back?
Could you describe how you did that?
Joe
Offline Gary_B
« Reply #9 on: May 29, 2010, 07:18:53 AM »
I removed the clip holding the sprocket and needle bearing than in order to break the nut loose, I used a small piece of rope act as a piston stop, I am almost sure I kept it out of the exhaust port and applied pressure and the nut came loose. Removed the clutch, and reinstalled in same manner. I aligned the notch for the oil pump in the clutch housing. The saw is still doing the about the same thing, it will start and run now with the muffler on, but not very well, cannot get it to idle down, without cutting off. Tried adusting carb, but when it does run on its own , the chain continues to move.
Online Al_Smith
« Reply #10 on: May 29, 2010, 08:12:41 AM »
It might be just coincidental and nothing you did caused it.However it appears you have some type of air leak some place . Might not be the seals. Could be the boot . Could be a screwed up carb,stranger things have happened .
I know one guy of whom I won't mention any names but a great mechanic who files fast chains and lives in Ohio .He had one that was giving him fits so he pressurized the engine with air and tossed it in a tub of water .He found the leak . :D
o31 stihl won't start
Started by joe13 on Chainsaws
Last post March 09, 2013, 03:54:29 AM
by Al_Smith
Stihl HT 101 Ext c-saw, will start, won't run?
Started by tstex on Chainsaws
Last post June 04, 2011, 05:41:13 PM
by fuzzybear
stihl 025 won't start
Started by ronaldlee on Chainsaws
Last post April 19, 2007, 02:16:57 AM
by windthrown
Stihl BG 86 won't start
Started by JohnG28 on Chainsaws
Last post March 27, 2013, 07:13:54 PM
by JohnG28
