Author Topic: Got my bandmill today  (Read 5932 times)
Offline dtody
  • Back into sawing!
Re: Got my bandmill today
« Reply #20 on: October 28, 2003, 12:41:07 PM »
"Wanting" is a mild way to describe the manual.  A line-drawn picture of a set-up mill would have been nice, at least.  Do you have the Carter guides?  Adjust them in/out if the log is irregular, it keeps the blade more level.  My little sack had the bolts, no nuts and I still haven't figured out where the double headed nails go, except to nail the 90angle to hold the track down???
This site is great about everyone respecting the type of mill someone has.  There seems to be a sense of community with a similar interest that some other sites lack.  The kidding around on this site always seems positive. Group Hug time!
Offline music_boy
  • Lt40HD28 Jumping in with both feet !
« Reply #21 on: October 28, 2003, 06:02:29 PM »
You got a sack of nuts ? I got the standard roller bearing guides. Figured they'd be o.k. I played around adjusting the bearings today. I finally just took the whole bearing assembly off and started from scratch. I think it is a good mill, but why didn't they use square stock instead of round. You get one bearing set, then tighten and evrything moves. Abit frustratng. I think I have it figured out though. I can't play with it til Thurs. I have a sears laser level that I think Ican rig up to this mill. If it wirks, I'll piture it and post it.
keep in touch
BTW, this is a great forum. Has really helped.
Rick
It's not how much YOU love, it is how much you ARE loved that matters. (Wizard of OZ)
Offline dtody
  • Back into sawing!
« Reply #22 on: October 29, 2003, 11:33:33 AM »
A sack of six bolt, no nuts, must be the "eunuch model."  The frame that holds the engine and blade apparatus is on square 1 1/8" steel, is yours round?
I'm going after logs this weekend, should have plenty to post.  Pictures too.
Offline music_boy
« Reply #23 on: October 29, 2003, 03:31:04 PM »
The steel holding the blade guides is round. I think square there would make life better. Hopefully will have my guides adjusted tomorrow. Supposed to pick up a Persimmon log tomorrow that being held for me from the Hurricane. Might have some pics myself. Looking forward to yours ;D
Rick
Offline HUNTER700
  • EARTH FIRST we can log the other planets later
« Reply #24 on: October 29, 2003, 06:47:13 PM »
Hey read your posts about getting your mill. I think you will enjoy working with Hud-son's bandsaws. They really are a lot of fun to work with. I have had a Hud-son bandmill for about 8 months now and they are really the way cut wood. They are great mills ,one thing you will want to do is put some washers on the blade guards they have a bad habit of rattling off in the middle of a cut which is a big pain. It sounds like you were to do this from some of the previous posts. I had to work with  mine a bit to get the saw its self  level with the track system.  Well good luck. And straight cutting.       HUNTER700
Offline DanG
« Reply #25 on: October 29, 2003, 07:54:37 PM »
Hey HUNTER700.  Good to see another Alaskan poster on board.  Funny how you folks tend to post here when the weather gets cold, then disappear in the summer. :D  Sounds like you've been having fun with your mill. How about some details?
Offline Norwiscutter
  • Have a nice day!
« Reply #26 on: October 30, 2003, 12:47:47 PM »
got the oscar 36 and for what I'm doing it is great.  I didnt get the trailer package because i do most of the cutting by myself and would have a hard time getting the logs on the carrage. Good advice on the lock nuts. In reality my saw really only cuts about 30-32 inch diameter without trouble. After that it gets tricky rotating the logs. Hopefully you got the most horsepower available as it seams to really make a difference.  You will find that pushing the saw during the cut is a non issue as the saw roles extreamly well. I found that lubing the blade with anything with more viscosity than water or rv antifreeze tends to increase the occurance of throwing blades.  I love my Hud Son and boughtit with the understanding that my sawing was going to be a weekend hobby.  I have more than paid of the 7 grand it cost me in the 7 months I have thus far had it.  My only experience with blades so far are the woodmizer blades recomended by the company and have let to have any problems.  The worst part about having the mill is that i cant seam to find enough time to run it.  I now have about 10-12 thousand bd/ft stickered but dont really know what I am going to do with it. I guess thats a problem that alot of people would like to have though.
Si vis pacem, para bellum.
Offline music_boy
« Reply #27 on: October 30, 2003, 04:01:41 PM »
Thanks Norwiscutter;
     Actually, I asked for the 8 hp engine. They told me the 5.5 was plenty and the 8 wouldn't fit anyway. 5.5 outa be o.k. Appreciated the info on the blades and lube. There seems to be a myriad of formulas and advice there.hudson told me soapy water but most everyone else suggests mix of diesal and oil. Maybe Hudson knows the belt will fly.I'm already begining to think I should have gone with the 28. At the time I was "squeaking" across the decision line. I figure if things go like alot of others. I'll upgrade to a larger mill. Shoudn't have trouble selling this mill.
Rick
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
« Reply #28 on: October 30, 2003, 04:44:59 PM »
Before you start mixing that diesel and oil, try the water and soap, or just plain water.  In real sappy wood, I use a lot of water, but it's cheap and leaves no odor and is not hazardous to the environment.  The exception is when it is below freezing, then water becomes a problem.
  • Have a nice day!
« Reply #29 on: October 30, 2003, 05:34:48 PM »
The reason I got the bigger model was because I have a lot of trees that are over 20 inch.  Everthing I have cut so far has been pine and cedar.  The smaller sticks that you will be dealing with should be no problem with the 5.5 as long as you watch the feed rate. Did you get that handy dandy trailer package?  I like the idea of being able to pull it with a four wheeler.  Should be able to get it back in to some of those places reserved for an alaskan mill. Will be interested to see what kind of production rate you can get with that saw.  Good luck.
Offline music_boy
« Reply #30 on: October 30, 2003, 06:15:29 PM »
I didn't get the trailer package. I have a set of boat trailer axels that plan to cut down to fit. with a tow hitch and level . A small ramp with a boat winch outa take the back strain out of loading logs.
    Got the bearing guides set today and set the track up. Fired the engine up and all looks good so far. Gota get me a log.
    I like the soapy water deal best. Hate the smaell of diesel on wood. Try to be as environmentally oriented as I can.
Thanks all
Rick
Offline UNCLEBUCK
  • Life out on the prairie !
« Reply #31 on: October 30, 2003, 08:40:19 PM »
hello music boy, just wanting to say howdy and my experience here at the forum started early this spring and I had a whole farm full of trees and a head full of ideas and with the help of everyone here I was able to saw my own logs and it is a blast ,even when I have something go wrong I know I got the forum for support, I got a big grizzly shop bandsaw but I got a circular mill that I saw logs with. Been playing a Gibson 5 string bluegrass banjo for 20 years and a Fender Telecaster for the same doing the rock-a-billy thang ! Lookin forward to seeing your pictures and hearing your sawing stories, lots of luck !
Offline dtody
  • Back into sawing!
« Reply #32 on: November 03, 2003, 10:40:10 AM »
I used my little saw last Thursday, four hours, couple hundred board feet.  I'll have to figure out a cleaning method for the dirt.  Blade rises when it gets dull.  Re-cutting the length of my wood, 9' max now.  Log dogs limit smallest cut to about 3" high.  A lot of adjusting for a good cut, but I haven't found it yet.  A toe board might help.  Cutting stickers was a challenge, but I got some.
We went back to felling trees Friday and Saturday, around 30+, got a spalted maple log, 2' by 10"/12" wide, nice pattern and one doe early.
I'll work on pictures later.
Looking to buy a Bandmill
Started by Gitrdone64 on Sawmills and Milling
Last post March 03, 2017, 06:08:20 PM
by BigDogTreekillr
New Bandmill
Started by MikeZ on Sawmills and Milling
Last post September 22, 2013, 09:54:52 AM
by WmFritz
Tru-cut bandmill
Started by dunit on Sawmills and Milling
Last post May 10, 2019, 04:18:18 PM
by hacknchop
New Bandmill
Started by beerguy on Sawmills and Milling
Last post August 24, 2003, 09:23:35 PM
by D._Frederick
