Author Topic: What size wire to run to power my 8500# winch off my pick-up truck???  (Read 4643 times)
Offline LandfillLumber
Hello, want to power my #8500 super winch off off my pick-up truck what size wire/cable should I run?Any information would be great,or just any tips you might have that may save me time/money.Thank You very much,Victor
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Welding lead wire works well.  I just go to my local welding supply.  They have a spool and will cut the exact length that I need and put lug terminals on the ends.
Offline scsmith42
    • Whispering Pines Farm
+1 on Magicman's recommendation of welding cable.  I use 2/0 welding cable for both power leads to my 8000 lb Ramsey winch, and even a cable that large gets warm on the longer pulls.
Tom's 3638D Baker band mill
Online pineywoods
Depending on how far you need to run the cables, it may be cheaper and better to mount another battery close to the winch and run heavy short cables. Welding cable is $$$ expensive. Also lessens the chances of having the winch pull your pickup battery down so far it won't start. Been there, done that, right in the middle of a big mud hole.  >:(
Offline scsmith42
Very good advice.  I have two banks of batteries on my GMC with the winch.  Both banks are kept charged via a battery isolator, but the winch does not draw from the primary truck battery.  There are actually two batteries on the bank feeding the winch, and there have been times that I've run the winch bank almost totally dead.
Offline Ed
Go to your local heavy truck parts outlet, they will have battery cable "in bulk", cheaper than welding cable and you can get the size/length you need.
The manual or website for the winch mfgr should recommend the correct cable size.
Ed
Offline Ironwood
    • http://www.branchandburl.com
The heavier the better and ditto on the extra batteries.
 Ironwood
question
Road legal Pick-Up Truck size log trailer
Started by dgdrls on Forestry and Logging
Last post June 19, 2018, 10:58:03 AM
by Dave Shepard
question
What wire size do I need?
Started by Vermonter on General Board
Last post July 17, 2005, 11:32:01 PM
by Vermonter
Electrical Wire Size, Voltage and Amp Drop?
Started by Corley5 on General Board
Last post November 25, 2016, 07:01:00 PM
by TimRB
question
Wire gauge for 12V winch
Started by Delawhere Jack on General Board
Last post January 04, 2013, 01:36:38 PM
by Tom the Sawyer
