TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Looking for recomendations on a pole saw  (Read 8766 times)
Offline g_man
« on: August 06, 2010, 08:24:13 PM »
I think I want to retire my manual pole saw. I'm not getting the job done anymore.
I'm not a professional user but I spend alot of time in my woods trimming several miles of trails and branches on promising young hardwood trees. I probably don't need the best saw but I hate junk tools. I'd like recomendations on what would be a reasonable choice. My manual saw is 18 feet with my home made extension so I can reach over 20 feet when I have to but I've not seen any pole saws that long.
gg
Offline beenthere
Re: Looking for recomendations on a pole saw
« Reply #1 on: August 06, 2010, 08:38:50 PM »
I've had good performance out of my Stihl pole saw. Not always long enough, but then holding it up there has its limitations too.  ;D
Last I used it was to saw off a 6" dead walnut limb about 20+ feet up. Could reach it ok from the bucket raised high as it would go.
Too big in diam for the shotgun method.
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #2 on: August 06, 2010, 08:46:09 PM »
I have a Silky Hayuchi 21' from Bailey's.  I think this is still the same one at this link:
http://www.baileysonline.com/itemdetail.asp?item=17939&catID=205
It is a fantastic saw and I would not hesitate to buy it again.  Cuts very fast and is very well built and can buy replacement parts from Bailey's.   I think I dropped it or dropped something on it which made a little ding along the shaft.  Since there are 3 telescoping sections this made it a little harder to open but still satisfactory with WD 40 on it.  Just don't drop something on it.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Al_Smith
« Reply #3 on: August 07, 2010, 12:28:12 AM »
Now laugh,giggle ,roll on the floor or call me dirty names but I have a cheapy Poulan power pruner .Light weight,not of professional quality and cost me all of 2 hundred bucks 3 or 4 years ago .
Now let me tell you though that little cheap thing has saved me tons of work .In all that time I haven't ran it long enough to even needing to  sharpening the chain but it has saved me countless hours of time .An idea perhaps or an option if you choose .
Offline sharkey
« Reply #4 on: August 07, 2010, 12:03:47 PM »
If your looking for a power model, we have an older telescoping type Echo power pole saw with a 5ft extension.  The regular reach is a standard 8-12ft + the extension is 5ft for a total of 17ft, plus whatever half your height would be.  Add another foot for the bar and chain.  You can stand on the bed of a truck for another couple ft.  Its been a good unit always starts easy and hasnt needed anything.
Offline g_man
« Reply #5 on: August 07, 2010, 06:10:08 PM »
Thanks for the replies. I'm not against inexpensive I'm against stuff that when you look at it you immediately know it won't stand up to normal use. Like some chinese screw drivers whose bits twist before the screw is even tight. I'll check the Poulan out.
Sharkey how do I learn more about your Echo? I saw them in a Bailey's catalog.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: August 07, 2010, 06:21:01 PM »
I have an Echo, but If I was in the buying market, it would be a Stihl.  I haven't had any trouble with the Echo, but.
Offline g_man
« Reply #7 on: August 07, 2010, 07:26:12 PM »
Sharkey,
I may have interpreted your post wrong. At first I thought you had one for sale but maybe you were just giving a subtle plug for Echo.
Offline Left Coast Chris
  • A day sawing is always a special day
« Reply #8 on: August 07, 2010, 08:29:27 PM »
I do alot of pruning on my english trees which are 40'-50' in height.  I use the 8' Husky pole saw from a bucket lift and can only reach 30' or so.  From the ground I have a Fanno hand saw with a fiber glass pole that is about 18' long.  I do use it from the bucket from time to time to reach 45' or so.    I would not like the manuverability of a gas saw with the weight of the head out even 12' if you are cutting very much.   It simply wears you out not to mention tweeking your back.   A good sharp hand saw (pole saw) is really fast and easy......
Suggest trying the power saw before buying is possible to see if it is really practical.  Food for thought.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Offline g_man
« Reply #9 on: August 07, 2010, 09:11:38 PM »
Thats a great suggestion - I should rent one and use it for a day. Maybe I'll find out the hand saw isnt so bad.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: August 08, 2010, 02:34:46 PM »
At the end of the first day, you will never buy one.  They will give you a workout.   ;D  :D
Offline underdog
« Reply #11 on: August 08, 2010, 02:37:11 PM »
Offline Rocky_J
« Reply #12 on: August 08, 2010, 02:52:08 PM »
You don't need to spend a fortune to use what the pros use. Look beyond the cost of the initial unit and look at the cost of replacement blades. Some of those fancy aluminum extendable jobbies use blades that cost $75 each. I own one and it sits in the shed unused. I use a standard polesaw head like this one http://www.baileysonline.com/itemdetail.asp?item=FM+U1R&catID=205 with a standard blade like this one. http://www.baileysonline.com/itemdetail.asp?item=FM%20S20 I use the fancy fiberglass pole sections http://www.baileysonline.com/itemdetail.asp?item=21661 but that is because I work around power lines a lot and my storage boxes on the truck are only so long. You can make a pole handle whatever length you like using 1¼" dowel rod. The wooden dowel rod is actually stiffer than the fiberglass sections and many wise old tree guys use them instead of paying through the nose for bright fancy stuff. Shave the end to fit the polesaw head tightly and then paint the whole thing with a couple coats of polyurethane.
Buy a few extra blades so you can replace them when they get dull or bent. They are cheap so it doesn't hurt to put a fresh blade on once every 6 months.
Offline D._Frederick
« Reply #13 on: August 08, 2010, 05:18:24 PM »
When I was looking at power pole saws, I fast came to the conclusion that the extended ones would be too heavy for this old man to use. When they are fully extended and horizontal, it takes all my strength to lift it to vertical.
I ended up buying a fixed length  Husqvarna that I can reach to about 12+ ft and I just love it. It will zip thru  a 5inch limb real fast and I can use it to cut fire wood lengths. I use it to cut up old fruit trees, you can just about stand in one spot with no bending or stooping. It will also make short work of eliminating blackberry bushes.
Offline g_man
« Reply #14 on: August 08, 2010, 08:06:58 PM »
Thanks for all the comments and suggestions.  They were not at all what I expected.
I am really curious now about power pole saws and will rent one very soon.
Maybe I'll find out all I really need is a new blade on my hand pruner  :D
That would be nice.
gg
Offline bill m
« Reply #15 on: August 08, 2010, 09:17:26 PM »
I have 2 each of both the Stihl and Echo power pruners and the Echo is the best. They both have the same reach and weigh the same but the Stihl has some drawbacks. The splined shaft inside the Stihl is weak and will twist. It's happened 3 times to me so far. When that happens you can no longer extend or retract it. Also the outer shaft is smaller in diameter, so when it is fully extended it is a lot more flexible and can bend real easy compared to the Echo.
Offline g_man
« Reply #16 on: August 09, 2010, 08:43:24 AM »
Thanks Bill - Thats the kind of info that is real useful
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: August 09, 2010, 04:49:12 PM »
Made me glad that I have an Echo after all.   :)
Offline Al_Smith
« Reply #18 on: August 09, 2010, 08:51:31 PM »
It's not so much the twist but if they get dropped in will warp the shafts .
I did a thread on another forum of attempting to un warp  out an HT 75 Stihl ,if that's the right model number .As it turned out the job was only partly successful .It would extend and retract part way .The cost of new shafts exceeded the value of the pole saw .Eventually some low life stole the thing any way so my work was in vain .My only hope is they drop a limb on their head or something . >:(
Offline Dancing Bear
« Reply #19 on: August 10, 2010, 08:58:08 AM »
I have the same one and for the fairly light duty I need it for I've been happy with mine too. I got mine used pretty cheap because the original owner said it didn't cut for beans. I guess the kids at Home Depot don't know  which direction the chain is supposed to go. I changed it around and got a winner.
I use the weedwacker attachment on a weekly basis.
How does the HT 131 Stihl Pole Saw compare to other Pole Saws?
Started by JOE.G on Chainsaws
Last post May 29, 2012, 01:36:36 AM
by Dixie Feller
axe recomendations
Started by Redbark on Forestry and Logging
Last post February 22, 2014, 11:34:07 AM
by M_S_S
Winch recomendations
Started by dgrover13 on Forestry and Logging
Last post May 14, 2017, 04:08:08 PM
by John Mc
recomendations for motor
Started by obcexp on Sawmills and Milling
Last post April 13, 2017, 09:13:28 PM
by obcexp
