Author Topic: mill shed  (Read 2566 times)
Offline Ed_K
mill shed
« on: November 05, 2003, 05:56:22 PM »
 Well I finally have a roof over the mill 8).
Now I wish it was bigger an higher :'(. But it's better than being in/under the snow like last year ;D.
Ed K
Ed K
Offline SawInIt CA
  • I need to eat sawdust
    • Logs to Lumber
Re: mill shed
« Reply #1 on: November 05, 2003, 06:00:02 PM »
Ed,
How big is it?
Offline Steve_M
Re: mill shed
« Reply #2 on: November 05, 2003, 07:31:38 PM »
I am in the process of planning a shed for my electric WM and Edger.  I am having all kind of trouble deciding how big to make it, where to place doors and how big to make them, how best to set up the equipment to be run by myself or with one helper, and how to place the building on may land.
I know Bibbyman and ElectricAl have simmilar equipment and are under roof---I am going to see Al and Linda on Saturday to see there setup, and pick there brains if I can afford  Al answers.
If anyone can offer advice I could use it---pictures would be great too.
Steve
2001 WM Super LT40 Electric and WM Twin Blade Edger, just a part timer custom sawing and cutting salvage logs.
Offline chet
Re: mill shed
« Reply #3 on: November 05, 2003, 07:56:07 PM »
From past experience I would say built it at least twice as big as you think you'll need.   :-/  Then you'll find it is probably still too small.    ::)
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline Norm
Re: mill shed
« Reply #4 on: November 06, 2003, 04:51:06 AM »
Well Steve if your going to Al's place according to Patty Al is just window dressing and Linda's the one you need to talk to.   :D
We are also considering what to do with our mill. Right now it's in a 3 sided shed and is no fun to use when it's cold. Al and Linda have a nice setup with heat in the floors.
Al do you also have an exhaust fan to keep the dust down our does your dust collector get rid of most of it?
Offline Kevin_H.
  • my two boys
Re: mill shed
« Reply #5 on: November 06, 2003, 03:16:29 PM »
Steve,
I ordered a carport, it is 18' x 26', The woodmizer will just fit under it. It was an inexpensive way to go, kinda temp. but I plan on using it for an air drying shed later in it's life.
The only down side so far is that the company was to be out here yesterday to put it up, so far no show, The nice lady at the 800 # tells me that they are running just a little behind.
Well I guess everyone deserves to get a little behind now and then. If you know what I mean.  ;D
Got my WM lt40g24, Setworks and debarker in oct. '97, been sawing part time ever since, Moving logs with a bobcat.
Offline Haytrader
Re: mill shed
« Reply #6 on: November 06, 2003, 04:54:47 PM »
Kevin,
I know xactly what ya mean. I am shootin for now as then is past tense.
Haytrader
Offline Ed_K
Re: mill shed
« Reply #7 on: November 06, 2003, 05:06:06 PM »
 I totally agree with Chet, my shed is 10' x 32' and the carring beam in front is only 5' 6". Forgot to add the 6x6 under the floor, height should have been 6' 6"  :'(.
Looking towards the next building, thinking either pole building at 50 x 100 or one of them steel huts (half shell).
Need to be fully enclosed and ability to move forklift around inside.
Ed
Ed K
Offline WoodChucker
    • The WoodChucker
Re: mill shed
« Reply #8 on: November 07, 2003, 06:49:36 AM »
If a Husband & Wife are alone in the forrest fighting and no one is around to hear them, is he still wrong anyway?
Offline ElectricAl
  • 1993 LT40HDE15 2012 LT50HDE25
Re: mill shed
« Reply #9 on: November 07, 2003, 06:52:56 PM »
Steve,
Chet is right.......Figure out what size you need then double it. Then leave 60' of clearance all the way around for future expansion ;)
Norm our dust collector removes most of the dust, but some does float around. During the winter all we have to do is open the door and all the dust races out with the heat ::) During the summer we use a 48" high CFM fan to blow the dust out.
When are you going to build that 60 x 105 saw shop for Patty ;D
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
Offline Percy
  • Resident trouble maker
Re: mill shed
« Reply #10 on: November 07, 2003, 11:36:59 PM »
What Chet said ;D ;D. I built this shed in two or three phases over the last couple of years  and will probably add more next year. One thing Ive found  invaluble is having complete 360 degree access to your mill, especially when cutting beams ties etc. You can have logs comming from one side and beams picked up with tractor/bobcat/helper from the end or side. Makes for easy sawdust removal.
shed for mill
Started by cpm on Sawmills and Milling
Last post February 26, 2004, 07:23:28 PM
by bull
Mill Shed for Jr.
Started by wvwoodbutcher on Sawmills and Milling
Last post August 22, 2016, 10:31:37 PM
by wvwoodbutcher
New shed for the mill
Started by Deere80 on Sawmills and Milling
Last post October 03, 2018, 09:58:28 PM
by PAmizerman
New Mill Shed
Started by aniakhenry on Sawmills and Milling
Last post October 16, 2006, 03:13:25 PM
by OneWithWood
