Author Topic: Bridge Deck ??  (Read 1503 times)
Offline wannabeonetoo
Bridge Deck ??
« on: August 27, 2010, 10:46:35 PM »
Not to sure if this is the correct place to ask but here goes......... I just put a small ATV/FOOT bridge across a little river (thats what it is designated  :D) ,approx. 40 ft. I now need to put a deck on it , what wood could I use ? I have plenty of EWC on my property.
The "bridge" consists of two cribs built out of RR. ties filled with fieldstone spanned with old utility poles.
Do any of you guys have pics of similar structures ??
Steve
Offline paul case
  • Original wearer of the PCM.
Re: Bridge Deck ??
« Reply #1 on: August 27, 2010, 10:49:56 PM »
 here in oklahoma and sw missouri the choice would be oak. we have a lot of it and it gets hard and lasts quite a while out in the weather .  is ewc rot resistant? pc
pc
Offline Chuck White
  • Sawing Mobile since 2005
Re: Bridge Deck ??
« Reply #2 on: August 28, 2010, 08:15:54 AM »
I agree with Paul, White Cedar is rot resistant!
It is also quite soft, so, if I were going to use EWC, I'd saw it at 8/4x6 or 8.
Some ATV's are quite agressive on the terrain, so you want to keep an eye on the condition of the bridge planks!
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Bridge Deck ??
« Reply #3 on: August 28, 2010, 08:49:03 AM »
I use 8/4 White Oak for my bridge decking.
2" White Oak bridge decking.
Re: Bridge Deck ??
« Reply #4 on: August 28, 2010, 09:07:02 AM »
Thanks guys, white oak would be great,however it is not very common here. Looks like cedar it will be 2" thick.
Steve
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Bridge Deck ??
« Reply #5 on: August 28, 2010, 12:42:28 PM »
I have milled out a bridge package for a 70’ ATV bridge and everything was milled at 3”x 12” 10”x 10”. (White Oak)
 This last week I milled out another bridge package which consisted of sixty 8”x 14”x 12’ and twenty 3”x 12”x 20’ It was milled out of Doug fir and was shipped out to be pressure treated.
The down side to cedar is that it is soft and if you use the bridge a lot, the wood will wear. Nevertheless, if that is what you got then that is what you got. Mill out a few extra pieces so that you have some on hand if you need to replace any and enjoy your new bridge.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Bridge Deck ??
« Reply #6 on: August 28, 2010, 05:51:04 PM »
You are going to be OK for a foot/ATV bridge.
Offline bandmiller2
Re: Bridge Deck ??
« Reply #7 on: August 28, 2010, 09:32:47 PM »
White cedar is fine you could always make the deck a little thicker and leave a little space between planks for drainage.Frank C.
Rough cut lumber bridge deck
Started by nay-aug on Timber Framing/Log construction
Last post July 20, 2009, 11:46:34 AM
by nay-aug
Entry deck/Bridge replacement
Started by Planman1954 on General Woodworking
Last post October 30, 2015, 09:44:38 PM
by POSTON WIDEHEAD
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Bridge help
Started by Splinter on Forestry and Logging
Last post January 15, 2011, 09:34:14 AM
by Mark K
