Author Topic: On the road again  (Read 2960 times)
Offline Kevin
On the road again
« on: November 08, 2003, 02:55:25 PM »
Argo and LT15
Head'n for Giver Hell Hill
It's a jungle out there...
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
Re: On the road again
« Reply #1 on: November 08, 2003, 03:18:08 PM »
Kevin When you get to Fulton Ky take State Line West two mile Im on the left.  8)
Jim Holloway
Offline Kevin
« Reply #2 on: November 08, 2003, 03:20:37 PM »
Keep a light on!
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #3 on: November 08, 2003, 06:27:54 PM »
Did ja pack da skies?
Offline Kevin
« Reply #4 on: November 08, 2003, 07:31:23 PM »
Got em waxed and packed.
Offline Bro. Noble
« Reply #5 on: November 09, 2003, 06:31:43 AM »
So Kevin,
You've shown us bits and pieces (maybe I've missed part of the story) but I wanna know more about what's taking place.
Are you building a cabin out in the boonies?  How far off the beaten path do you go?  When you go back in there to saw,  is it just for the day or do you spend more lengthy periods?
Do you take some crackers and pickled balogna with you?
Offline Kevin
« Reply #6 on: November 09, 2003, 07:08:40 AM »
It's a short story.
My wife makes me a lunch.
The trees get cut.
The logs get milled.
The lumber gets stickered and stacked.   :)
Depending on the trail, the mill gets hauled on skis or wheels  early in the Spring and stays in the bush for about a month.
The property is about a kilometer from decent roadway.
I go in on the weekends and mill.
It's my own very wet,woodlot.
I don't sell the lumber as a rule but use it for my own needs.
I have the mill set up in the driveway now at home, similar to what Mark is doing.
We'll be getting some heavy snow and cold weather soon so the mill will be under tarp until Spring.
Offline Ed_K
« Reply #7 on: November 09, 2003, 08:49:25 AM »
 Kevin, Do you use the argo to skid logs? If so, hows it work?
Ed K
Offline Kevin
« Reply #8 on: November 09, 2003, 01:25:06 PM »
I winch the logs out to the trail then hook em to the log arch in the picture.
No problem skidding with the Argo.
Offline WoodChucker
    • The WoodChucker
« Reply #9 on: November 09, 2003, 03:35:39 PM »
Kevin, is an argo about the same thing as a Gator? And is one better then the other? Also, how are they on hilly terrain when dragging a large log? Thanks!
R.T.
If a Husband & Wife are alone in the forrest fighting and no one is around to hear them, is he still wrong anyway?
Offline Kevin
« Reply #10 on: November 09, 2003, 03:55:00 PM »
I'm not familiar with the gator.
The Argo is amphibious, comes in 6 or 8 wheels.
http://www.argoatv.com/
I have the 6 wheel and the problem pulling a heavy load on a hill is getting traction as it has plenty of power.
When pulling the LT-15 up the one steep muddy hill I have to use the winch because I can't get traction.
You can also get tracks for it.
On the flats it will pull a good load and works well on wet ground where an ATV can't.
It has skid steering and will turn on a dime which makes it nice to operate in the woods.
Offline music_boy
  • Lt40HD28 Jumping in with both feet !
« Reply #11 on: November 09, 2003, 04:06:11 PM »
woodchucker,
    I've had some experience with both. Not necessarily in the Forestry end of it. Each has it's application. You can get an Argo with 6, (3 on each side) high ride tires which gives you higher clearance. Additionally, they make a set of tracks that fit over the tires like a dozer, almost unstoppable. It floats, , has a winch option, and a outboard motor mount for those really deep puddles. Drives like a dozer with hand brakes. I've driven them over some tough , wet, hilly terrain and pulled ATV stuck up to their seats, outa mud.
     Gators, in my opinion, aren't as versatle. Certainly have their application. I use a 6x4 with a dump body. Plenty of power. But when it comes to the wet stuff,don't hold a candle to the Argo. Argos will hump logs that a gator will not.If you can get the front tires on it, it will usually climb and go over it. Tough on the kidneys sometimes. Argos are more expensive. So, it boils down to your needs and application. BTW, an Argo will literally, turn on a dime.
     Hope that helps.
Rick
It's not how much YOU love, it is how much you ARE loved that matters. (Wizard of OZ)
Offline Kevin
« Reply #12 on: November 09, 2003, 04:50:05 PM »
I can winch some pretty big logs with it.
I'll start the winch and feel the pull on the machine.
When the log gets stuck the machine starts to pull ahead letting me know the log is stuck and I stop winching and free it.
Offline Mark M
  • Wilton, ND
    • Some of My Pictures
« Reply #13 on: November 09, 2003, 05:00:22 PM »
Someday I hope to get one of those Agros. Right now there is one in the paper for sale. It is an 8 wheel unit with cab, heater, winch, and has 37 hours on it. The asking price is $9900.
Offline WoodChucker
    • The WoodChucker
« Reply #14 on: November 09, 2003, 11:52:30 PM »
Kevin and Rick, thanks for all the info!  I've been thinking about getting a Gator, never seen an Argo before so I'll have to look around and see who carries them. Thanks again!
R.T. .
Offline Kevin
« Reply #15 on: November 10, 2003, 06:13:58 AM »
I was looking for a dual purpose machine, a machine I could use for hunting and general access to my camp and at the same time a machine that would tow my mill and skid logs.
The Argo fit and serves my purpose.
They are slow and rough riding but are well suited for crawling through the woods.
Suzuki Street Bike on the road.. then the Dirt Road.. Then trail
Started by weimedog on The Outdoor Board
Last post August 01, 2014, 03:41:17 PM
by weimedog
The road to....
Started by Ianab on General Board
Last post September 18, 2010, 09:28:08 AM
by Ianab
On the Road, Again
Started by PC-Urban-Sawyer on General Board
Last post June 26, 2014, 07:34:28 AM
by thecfarm
On the road
Started by rjwoelk on General Board
Last post April 01, 2019, 10:02:18 PM
by trapper
