Tally-I/O
Author Topic: Huskys are tough!!!!  (Read 1947 times)
Offline treefarmer87
« on: August 31, 2010, 05:26:57 PM »
had a poplar tree about 16" diameter fall on my new 576Xp yesterday :'(. all it did was bend the handle and crack some plastic. i bent the handle back in place last nite. i ran it today and it was like nothing happened to it, huskys are just plain tough!
1990 Ford F-800
1974 Ford L 9000 Self Loader
2004 Tigercat 718
1998 Barko 225
1992 Treefarmer c6f
1994 John Deere 648E
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline LeeB
Re: Huskys are tough!!!!
« Reply #1 on: August 31, 2010, 07:26:39 PM »
Dropped a 8" diameter branch on my 372 from about 15ft up. Broke the spark plug off and customized the plastic a little. Everything else survived just fine. That was 6 years ago. Still running like a champ.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: August 31, 2010, 08:33:37 PM »
I ran over mine with the tractor  :).  I managed to wire most of the cover back together, but the chainbrake was toast.
Offline quietrangr
« Reply #3 on: September 01, 2010, 07:42:07 AM »
Hasn't happened for quite a few years, but I used to get saws stuck while the tree was going over. Then the tree sat on the saw. Stihls usually broke the back handle/tank. That happened to quite  a few 66s. I once sat a 30 inch hard maple on a 394. It broke the rewind cover bent the handlebar, and cracked the fuel tank where the front handlebar attaches. The dealer replaced the handlebar and rewind, and used some kind of putty to close the crack in the tank. I never had a problem with it.
Offline sawguy21
« Reply #4 on: September 02, 2010, 11:55:21 PM »
You guys really know how to test saws   Maybe you should get jobs in quality
assurance  :D
Offline LeeB
« Reply #5 on: September 03, 2010, 12:40:23 AM »
I just needed to learn what I was doing.  :D
Offline ArcFault
« Reply #6 on: September 03, 2010, 12:51:31 AM »
I dropped my little husky yesturday from about 7 inches off the ground into the grass. Now I know I am not beating my saw llike you guys but I am starting small.
Watch, in no time at all I will be abusing them just like a pro. :D
Offline Ironwood
    • http://www.branchandburl.com
« Reply #7 on: September 03, 2010, 05:50:54 AM »
All depends what gets hit first. I have,had a bad week here with saws, I won't go into it but have three out of five headed,to shop I guess  my years of trouble free operation caught up with me. I am a husky guy but I think the stihls are a bit tougher in this category.
Ironwood
Offline pallis
« Reply #8 on: September 03, 2010, 03:08:51 PM »
Thank goodness I've not damaged my 372, but my oldest son once dropped a 28 inch pinon on my 7900.  He got it pinched, and the tree came over on it.  I ran (what passes for running with me) up the hill thinking the saw was gone, and found it buried in the dirt, still idling.  After cutting it out, the only damage was a dent in the muffler and a bent bar.   They make some tough plastic these days.
Does anyone still have one of these Huskys
Started by joe_indi on Chainsaws
Last post October 06, 2009, 06:43:38 PM
by Al_Smith
New Huskys, now what??
Started by Coastal Gun on Chainsaws
Last post March 30, 2015, 01:32:55 AM
by LeeB
Huskys bad rep
Started by Sawyerfortyish on Chainsaws
Last post July 11, 2008, 07:07:53 AM
by Sawyerfortyish
Anyone running 298 xp and 272 xp huskys!
Started by Hawkin50 on Chainsaws
Last post February 23, 2004, 08:31:22 PM
by Hawkin50
