Author Topic: Wavy Cuts  (Read 9339 times)
Offline woodman58
Wavy Cuts
« on: September 03, 2010, 08:41:22 AM »
 I have a guy that saws for me on occation. He has a Woodmizer LT40. The last few times he cut for me the cuts have been very wavy. What can I tell him to do to fix this problem with out insulting him. He has been cutting for 15 years.
The other person that cuts for me has a Baker 3665. The cuts are always true. He is moving futher away in 2 months and semi retiring, so I'm going to have to use the other guy. Thanks
i LOVE THE SMELL OF SAW DUST IN THE MORNING.
Timberking 2200
Offline Burlkraft
  • Professional survivor......Still a wooodturner
Re: Wavy Cuts
« Reply #1 on: September 03, 2010, 09:01:23 AM »
Boards like that turn your planer into a skip planer  ;D  ;D  ;D
Why not just 1 pain free day?
Offline ronwood
  • Enjoy Making Sawdust !!
Re: Wavy Cuts
« Reply #2 on: September 03, 2010, 09:16:50 AM »
woodman58,
Sounds like he is trying to cut to fast and using blades that are dull. Could be a issue with the mill also. Has he always cut wavy lumber.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
Re: Wavy Cuts
« Reply #3 on: September 03, 2010, 10:49:22 AM »
My experience is this:
1 - bands that are dull but properly set for the type of wood, will cut slowly and will load the engine down. They also seem to gather the most dust and pitch.
2 - bands that are under-set for the type of wood they are cutting, will almost always produce a wavy cut, regardless how sharp they are.
3 - bands that are over-set will produce more sawdust then is necessary, but if they are sharp, they will cut just as well as a properly set and sharpened band.
that's all I got...
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Offline Bro. Noble
Re: Wavy Cuts
« Reply #4 on: September 03, 2010, 11:03:01 AM »
In addition to John's list,  a dull blade runs warm and picks up sap from the wood.  If you don't run enough water, the sap buildup has the effect of removing set, causing wavy cuts.
I feel my blade for warming (not while it's running ::)) and start thinking about changing it when it begins to feel warm.
Offline dkyle
Re: Wavy Cuts
« Reply #5 on: September 03, 2010, 12:02:48 PM »
what do you mean by "over-set", "under-set"?
I suspect the guy is running the blade too long.. it is dull, and running hotter than it should.  It expands and is now running is looser.
Offline woodman58
Re: Wavy Cuts
« Reply #6 on: September 03, 2010, 02:15:23 PM »
One thing I forgot to mention is that he does not run water on the blade. His hose is broken. He says it works fine without it.
Timberking 2200
Offline weisyboy
  • sawmiller & logger
    • Weiss Sawmilling and Property Maintenance
Re: Wavy Cuts
« Reply #7 on: September 03, 2010, 04:35:08 PM »
dosent sound like it works fine to me.
Offline paul case
  • Original wearer of the PCM.
Re: Wavy Cuts
« Reply #8 on: September 03, 2010, 04:45:50 PM »
i  almost said that, thanks for posting it so i didnt have to.
my exp.  dull blade  pushing to fast. no lube can do it too if the sap builds up on the blade like noble said.   pc
pc
Offline Tom Sawyer
    • Tom Sawyer Sawmill
Re: Wavy Cuts
« Reply #9 on: September 03, 2010, 05:07:39 PM »
One other factor would be the kind of wood he is cutting.  Spruce will sometimes give me fits no matter how sharp or well set my blades are.  I always make sure the customer knows that wavy wood is not acceptable to me as the sawyer, and on the one occasion that I couldn't cut a customer's spruce straight no matter how hard I tried, his bill was discounted significantly.
Amen to weisyboy and Paul Case.
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
Re: Wavy Cuts
« Reply #10 on: September 03, 2010, 08:30:47 PM »
The saw tracking to far back on the wheel will take the set right out of a new saw.
Worn guides will not hold the blade flat in the cut.
Not having enough tension on the saw will allow the saw to wander.
Get the water flowing even if that mean using a garden hose on the saw or the sawyer. :-X
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Wavy Cuts
« Reply #11 on: September 03, 2010, 09:15:26 PM »
"Folks" that saw wavy lumber are good for my business.  Their former customers are my future customers.  Notice that I didn't call him a "sawyer".
He has a sawmill and saws logs, but a sawmill don't a sawyer make.
Offline tazz
Re: Wavy Cuts
« Reply #12 on: September 03, 2010, 09:49:28 PM »
I have noticed everytime I let my water tank run empty my cuts get wavy, even with a new blade on. You should let him know, this could cause him to lose a lot of business. I know if it were me I would want to know.
Offline sgschwend
  • My new Brand X sawmill
    • Brideck Enterprises Portable Sawmill Service, Washington
Re: Wavy Cuts
« Reply #13 on: September 04, 2010, 12:08:21 AM »
Wavy where?  At the beginning of the cut, around the knots, on the edges of the board, only on the large knots, or anywhere on the board?
All of those places have their own cause and effect.
Re: Wavy Cuts
« Reply #14 on: September 04, 2010, 05:17:28 AM »
When a band is made, the teeth tips are alternately bent left and right so that the band cuts wider than the thickness of the band material. This is called the "set" of the tooth. On the bands that I use the set pattern is Left - Right - None, so every third tooth tip is bent (set) the same way. When a tooth tip is bent too far (over-set), the kerf in the cant is wider than it needs to be and extra energy and wood are wasted making sawdust that could be a board. When a tooth tip is not bent over far enough (under-set), the result is often a wavy cut accompanied by a band that runs warm and builds up pitch.
FYI : I'm no expert.....not even close to being one......this is just my experience so far.
cheers
John
Stihl MS361
Stihl 026
Offline gator gar
Re: Wavy Cuts
« Reply #15 on: September 04, 2010, 05:34:28 AM »
If he has been cutting for 15 years, he has it figured out by now. My opinion is that he just don't care and has little or no pride in his work. I'd find another person to saw for me in the future.
Offline bandmiller2
Re: Wavy Cuts
« Reply #16 on: September 04, 2010, 07:16:21 AM »
Woodman,perfect excuse to get your own mill.Frank C.
Offline ladylake
Re: Wavy Cuts
« Reply #17 on: September 04, 2010, 07:44:45 AM »
  We all get a wavy cut once in a while but should not get 2 in a row.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline barbender
Re: Wavy Cuts
« Reply #18 on: September 04, 2010, 10:08:59 AM »
If he's been doing this for 15 years and is sawing a large amount of wavy lumber, either he doesn't care about quality, or he doesn't know what he is doing. I'd say an occasional wavy cut is to be expected, but the situation should be fixed right away. Bottom line- I'd find someone else. ;)
Offline Chuck White
  • Sawing Mobile since 2005
Re: Wavy Cuts
« Reply #19 on: September 04, 2010, 10:28:53 AM »
Other than mill alignment, wavy cuts are caused by:
Dull blade.
Not enough lube (pitch build-up).
The set doesn't match the wood being cut.
Pushing a dull blade too hard/fast.
My money says that the other guy doesn't sharpen his own blades and/or have a good resharp service.
I found that once I got my own Sharpening/Setting equipment, I pull the blades off the mill at first sign of a wave or the engine laboring.
I have quite a few of those too Magicman.  ;D
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
wavy cuts
Started by revid on Sawmills and Milling
Last post August 20, 2015, 06:57:52 PM
by MSSawmill
Wavy Cuts
Started by millit on Sawmills and Milling
Last post March 11, 2008, 03:43:58 PM
by millit
Wavy cuts .
Started by shortlogger on Sawmills and Milling
Last post March 09, 2017, 11:17:58 PM
by gww
Wavy Cuts w/photos
Started by ssgerken on Sawmills and Milling
Last post March 30, 2012, 10:41:36 AM
by barbender
