Arborwear
Author Topic: band blade flatness  (Read 1353 times)
Offline paul case
  • Original wearer of the PCM.
band blade flatness
« on: September 15, 2010, 06:01:21 PM »
is this something that deserves looking at?
i bought some cookssaw blades and i get their magazine. this months issue has 1 article and it is all about blade flatness. that is from gullet to back. do any of you guys/gals have a blade roller from cooks? can you tell it makes a diference?
 the funny thing is the new cookssaw magazine is the first one without the band roller listed for sale in it.   pc
pc
Offline ladylake
Re: band blade flatness
« Reply #1 on: September 15, 2010, 06:58:17 PM »
 My 1-1/4" blades cut good untill they die, A roller might help 1-1/2" blades.    Steve
Offline sgschwend
  • My new Brand X sawmill
    • Brideck Enterprises Portable Sawmill Service, Washington
« Reply #2 on: September 16, 2010, 11:31:14 AM »
From my experience the saws need to be flat.  They are when I purchase them and will stay that way if I use them correctly.  Otherwise in my view I have abused the saw.
My sharpen service will throw away a saw with too much damage which I suppose would include a none flat saw.  So the roller might fix/recover that saw.  But to tell you the truth I knew I sent them a iffy blade because I remember some bone head error I made that messed it up.
I can't speak for other bandmill brands but the one I used will not distort a saw to be out of flatness (assuming it is setup with the proper tension and blade guides adjusted).
Offline backwoods sawyer
  • LT70-Cooks AC-36 edger-boom truck-oliver crawler
    • Backwoods Custom Milling Inc.
« Reply #3 on: September 16, 2010, 08:44:08 PM »
When sharpening a 12 wide saw part of the process is to bench the saw by taking a straight edge and looking for light that comes under it, these areas are then hammered to flatten the band. You can do the same thing at home with a set of wheels that allow the saw to roll around as you work over a flat steel plate with a good light. I will bench a saw when I wreck a saw and it dose helps. Rolling the saw is less accurate then benching the saw as it just puts even pressure on the saw as it goes around.
Flatness?
Started by Satamax on Sawmills and Milling
Last post November 27, 2011, 08:17:57 PM
by Brucer
my acme band saw blade (captive needle bearing )roller blade guide
Started by buildthisfixthat on Sawmills and Milling
Last post January 16, 2012, 09:34:15 AM
by 5quarter
Band Blade Selection
Started by Shawn on Sawmills and Milling
Last post February 24, 2006, 09:27:14 PM
by LeeB
Horsepower on a band blade
Started by Randy88 on Sawmills and Milling
Last post January 19, 2017, 11:56:16 PM
by sandsawmill14
