Arborwear
Author Topic: Cut some big wood today  (Read 6102 times)
Offline Peder McElroy
  • New LT 35 and 6 Grandkids , What could be better
« on: September 17, 2010, 11:42:46 AM »
Had a great today . Needed some logs for the mills so I went to my forest and picked out a nice 150' redwood. The 12' butt log weighed 8000 lbs. Here are some photo's,If I can load them,If not they will be on my photo gallery.G
Online Chuck White
  • Sawing Mobile since 2005
Re: Cut some big wood today
« Reply #1 on: September 17, 2010, 11:52:56 AM »
Hey Peder;
You already did the hard part with your photos.  I haven't quite got that down myself yet.
But, open a new post or edit the one you already have.
Go to your galery and click on a photo.
Once the photo enlarges, scroll down to the white box and hight the info there and rt click and select copy.
Then go to your post and click paste.  then your photo will be in the post.
~Chuck~
I LOVE MY SAWMILL
Offline bandmiller2
« Reply #2 on: September 17, 2010, 08:22:23 PM »
Peder,is that you half way up that redwood,you've got some real timber.Back east we don't have anything quite that large.Do you have equipment to handle that size log?? Frank C.
Offline SwampDonkey
  • Large Tooth
« Reply #3 on: September 17, 2010, 08:40:21 PM »
Yes, nice timber. When do we get to see some lumber? ;D
Dirty Harry
Offline pitotshock
  • Cheap Assed
« Reply #4 on: September 17, 2010, 08:49:45 PM »
Truly some inspiring sized trees. Don't think that I would have the kahunas to scale and cut the top off from way up there...
Stihl MS361, Makita DCS340
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Avast! Here appeareth some sweetgummery about....
« Reply #5 on: September 17, 2010, 09:49:06 PM »
Very few. We have some trees in the 140-150 foot range here in South Carolina, and others here and there in the other eastern states. He said this one was about 150'. Beyond that, we don;t have anything to speak of, and of course the mature redwoods get to be more than twice the size of his.
My boss owns some land on a mountain here in SC and he had a massive red oak blow down a year or so ago. It is way back on the property and we can't currently get any of our heavy equipment to it due to terrain-- it is 4-5' in diameter, and measures 140' long on the ground.
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Turbosawmill 8" cut GX390 Warrior Sawmill, 13hp Honda
MS290 Stihl
Genesis Hardwood Lumber
Offline SwampDonkey
  • Large Tooth
« Reply #6 on: September 17, 2010, 10:13:42 PM »
Even white pine probably max out at about 130 feet around here, they always are above the main canopy by several feet. Hardwood around here max out around 80 feet, mostly 60-70 feet. Spruce can sometimes be found around 110 feet or so, I measured a red spruce one time at 102 feet.
Dirty Harry
Offline Okrafarmer
« Reply #7 on: September 17, 2010, 10:51:10 PM »
I wish I knew the height of the massive old white pine at my great-great-uncle's house in Belgrade, Maine, It was over 5' in diameter. A few miles away my grandfather had the biggest cedar (red, I think?) I've ever seen and it was between 3-4 ft abh and about 60' tall more or less, with massive leaders-- a very bushy tree at the end of his house. I've also seen some stunningly huge white pines along the Belgrade Lakes and by Unity Pond in Waldo County-- don't know how tall they were.
MS290 Stihl
Offline Okrafarmer
« Reply #8 on: September 17, 2010, 11:37:02 PM »
Anyway, if he'd said he cut down a 175' redwood I guess I just would have kept quiet!  :D I look forward to visiting the redwood groves sometime-- that will be very awesome. We can't match the redwood as a species with anything we have here, of course.
MS290 Stihl
Offline bandmiller2
« Reply #9 on: September 18, 2010, 06:39:44 AM »
Peder, I checked out your photos nice Belsaw setup.That redwood is going to be a pretty big mouthfull for the belsaw,what system do you use to turn the logs on the carriage.? Frank C.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: September 18, 2010, 07:27:01 AM »
That is sooo different from anything here.  Thanks for sharing some of what happens on your side of the world.   ;)
Offline paul case
  • Original wearer of the PCM.
« Reply #11 on: September 18, 2010, 09:47:55 AM »
most of the trees(oak and hickory) in my neck of the woods are almost big enough to get 3 - 10' logs out of. pc
pc
« Reply #12 on: September 18, 2010, 10:15:35 AM »
Frank C . I will mostly be using my Lucas mill on the big stuff. The belsaw is used on the smaller trees and I have to turn them by hand. I hire a crane for the big trees as the logs weigh between 4000 to 8000 lbs and my forklift won't lift them,my fork lift is good to about 4000 lbs. Peder
Offline northwoods1
« Reply #13 on: September 18, 2010, 10:49:37 AM »
I like the 4 post corner setup in your garage that gives me some ideas.
Offline Birk-man
« Reply #14 on: September 18, 2010, 10:54:34 AM »
Peder
How did you get the log to fly?
Peter
Offline StephenRice
  • "Pure gold fears no fire." - (Old Chinese proverb)
« Reply #15 on: September 18, 2010, 03:00:38 PM »
Peder
Peter
I imagine someone used a BiG DanG Crane!
"Pure gold fears no fire!" - (Ancient Chinese proverb)  What do you fear?
Offline bill m
« Reply #16 on: September 18, 2010, 03:25:43 PM »
What was the reason for using the crane for the log sections? In another picture it shows the climber just jumping the top out of the tree. If there was enough room and with nothing to get damaged by the top couldn't you just have let the logs fall? With the right notch and back cut the logs would flip one time and land flat.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #17 on: September 18, 2010, 04:00:20 PM »
I also like the 4 post set up for the garage. why? is that a mastercraft I see stored in there?
LT40HD, 742b Bobcat, Sthil v170,038, 461. 1952 TEA Fergusan Tractor
Offline Okrafarmer
« Reply #18 on: September 18, 2010, 05:45:48 PM »
Peter
He just gave it one DanG big push. Haven't you ever seen anybody do that?
MS290 Stihl
Offline StephenRice
« Reply #19 on: September 18, 2010, 07:32:30 PM »
Peter
Hey, anyone to climb up that far in a tree like that and do what he was doing has got to be a stud, so why not?
Got some wood hauled today
Started by jwilly3879 on Forestry and Logging
Last post February 08, 2014, 06:49:24 AM
by nedly05
Sawed some Tom wood today.
Started by nomad on Sawmills and Milling
Last post October 26, 2014, 10:17:50 AM
by Chuck White
Picked up the Wood-Mizer today!
Started by JCam on Sawmills and Milling
Last post September 16, 2006, 06:27:34 AM
by sawman
Today's Project, Table Wood
Started by Andy White on Sawmills and Milling
Last post June 16, 2014, 08:17:53 PM
by Sixacresand
