Arborwear
Author Topic: chainsaw bar got stuck - lesson learnt  (Read 18672 times)
Offline motif
« on: September 18, 2010, 03:58:41 PM »
I drove today to the bushes by the river and I was cutting almost 7-8 inch thick fallen tree lying on other trees and my chainsaw got stuck  :'( the end of that tree was supported on others and I was cutting somewhere in the middle from the top down instead from the bottom up and the bar with chain got squeezed in the middle, I couldn't  get it out.
I realized then I forgot to take second saw or hammer with wedge to get it out.   :(
It took me 20 minutes or so to get it finally out using force of my hands and moving the bar up and down.
After this operation the chain was loose and needed tightening. I was lucky the tree wasn't thicker and bigger because then I could not be able to succeed without a wedge or second saw.
Is there any way to do help yourself in situation like this without tools?   :P
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: chainsaw bar got stuck - lesson learnt
« Reply #1 on: September 18, 2010, 04:51:50 PM »
Always carry another bar and chain, plus axe and plastic wedges.
Offline Ianab
« Reply #2 on: September 18, 2010, 05:38:21 PM »
Been there, done that.
I always take two saws...
Now when you get 2 saws stuck in the same log, then you look a bit silly. Crazy thing is that it was about a 6" limb that had been twisted into a pretzel shape and was so full of tension that it grabbed the saw. Had to cut it out, and it also grabbed the 2nd saw, but no so tight that I couldn't work it loose.  :-[
Offline motif
« Reply #3 on: September 18, 2010, 06:29:05 PM »
that's really funny :) I imagine how you could feel.
Anyway "unfortunately" even doing such simple thing like logging we have to think about physics laws.
Offline pineywoods
« Reply #4 on: September 18, 2010, 06:37:52 PM »
It does make one feel rather silly. did it yesterday, stuck one saw cutting a 6 inch post oak limb. Went and got the second saw, cut up from underneath, DanG limb twisted sideways and pinched the second saw. Couldn't pull either one loose, finally got the forks on the tractor hooked into the limb and broke it off. Then tried to lift the log with the loader on the tractor. I could get it off the ground, but couldn't move, rear wheel off the ground. Had to drag the log out to smooth flat ground  to get it loaded on the trailer. 12 ft X 24 inch post oak, it will be cut into 4X4 for fence posts. What else is post oak good for?
100k bd ft club
Offline Frickman
  • Ouch, that hurt!
« Reply #5 on: September 18, 2010, 08:31:53 PM »
Not to one up you, but I've gotten three saws stuck in the same log, and I'm a professional logger. It happens to all of us. If I can reach it with the skidder winch I can get it unstuck. If I can't reach it with the skidder winch I probably wouldn't be cutting it anyway.
I keep spare bars and chains on the skidder and in the truck for this sort of situation. Usually every month or two I have to take off the powerhead and install another bar and chain. It happens. Almost always when I'm limbing or bucking twisted logs and limbs under tension.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: September 18, 2010, 09:02:50 PM »
I was felling a big old SYP when a wind came up.  Instead of falling, it just spun around and hung up in another tree.  I didn't have another saw or bar/chain.  I just removed the powerhead and went home.  I checked it a couple of days later.  The tree was on the ground and my bar/chain was lying on the stump.
Offline Frickman
  • Ouch, that hurt!
« Reply #7 on: September 18, 2010, 09:47:04 PM »
Magicman,
Grandpa knew a guy who did that regularly. If he couldn't get a tree wedged over he just walked away for the day and hoped it would fall by morning. Many times it did. He and grandpa worked together on some jobs and it always worried grandpa when he did this, as there is always the chance that someone could come by when it fell and get hurt.
Offline motif
« Reply #8 on: September 19, 2010, 03:57:05 AM »
but shouldn't we cut always making notches on the log first on the top and the bottom, especially when the logs are twisted and lying in difficult terrain so that way the bar couldn't be clinched anyway?  although that requres more cuting hence more fuel and time. I was cutting on the edge of the river on a pile twisted logs so it was not easy even to stand still so using other tools like wedge and hammer couldn't problematic anyway. Detaching the head would be even more
hard to do but I see a point now to have spare bar with chain with me...
Just reading about different techniques of cutting wood depending how they are supported or twisted.  :P
Offline northwoods1
« Reply #9 on: September 19, 2010, 07:36:42 AM »
Well I don't know about with no tools but with a small tree like that it would be pretty easy to just find a branch or pole lying nearby and with a fulcrum use it to pick the log up the fraction of an inch it would take for the saw to fall out. Also, maybe don't start cutting in the middle begin on an end where there is no risk of pinch and work down in to the tree relieving the pressure as you go.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: September 19, 2010, 07:54:22 AM »
Especially when a limby tree such as our Red Oak falls, there are many different forces, both upward and downward.  Each limb must be read in a different way.  Sometimes you are right and sometimes you miss something and figure wrong.  Just topping the fallen tree can cause problems because the trunk is providing downward pressure and the limbs are providing upward pressure.
Bottom line is, if you saw, you will eventually get pinched.  Better have a backup.
Offline JDeere
« Reply #11 on: September 19, 2010, 10:04:10 AM »
Your incident reminds me of something that happened to me 25+ years ago. I was cutting my first job with a 17HP Kubota tractor with a Farmi winch. The landowner wanted every 6" plus hardwood tree on the 5+ acres logged for firewood. I always carried 2 saws and felt pretty foolish after getting the second saw stuck trying to get the first one out. I thought what am I going to do now when I realized I could get a third saw from my neighbor's shed. I went and got the saw and finally got my 2 saws un-stuck. Not wanting to waste a trip I put his saw in the bucket and pulled a twitch of logs out to the landing area. When I got there I dropped the logs and pushed then up on the pile with the loader bucket. As I backed up the pieces of my neighbor's saw fell onto the ground. That ended my day as I went home to call around to find parts for a Poulan. I finally found a distributor down in Portland, Maine (4-hour drive) who had the parts. Lesson learned!
2013 Western Star, 2012 Pelletier trailer, Serco 7500 crane, 2007 Volvo EC 140, 2009 John Deere 6115D, 2002 Cat 938G, 1997 John Deere 540G, 1996 Cat D-3C, 1995 Cat 416B, 2013 Cat 305.5E
Offline ibseeker
  • Location: Imperial Beach, CA now; Maryville, East TN soon
« Reply #12 on: September 19, 2010, 12:46:09 PM »
It's interesting to read that other guys have this problem too, even the professionals. If the FF ran a poll about experience, skill and knowledge I'd probably be in the top 2 for lack of all. After reading this though I can see that it can happen to anyone. In the future I'll have more tools available and follow your suggestions. The bonus is that I learned something here and won't feel so foolish for making these mistakes. I always read the posts about using a chainsaw, falling trees and working safely because it's very apparent how dangerous this kind of work is. There have been numerous times that I'm concerned about what I'm doing. I've got some trees that I won't cut and will have to get some professional help with, they're just too dangerous for a guy with my level of experience. Thanks for sharing your experiences, I appreciate it because every little bit helps me learn to work safely (is that a word?).
Chuck
worn out poulan, Stihl 250SC, old machete and a bag of clues with a hole in the bottom
Offline beenthere
« Reply #13 on: September 19, 2010, 01:02:59 PM »
Talking about getting stuck with a bar in wood (happens to me too) brings to mind two things.
If possible, get into a couple of the courses of the Game of Logging (at least #1 and 2) and,
go into the woods with a buddy.
I often go in alone but it isn't the best game plan, especially for the inexperienced. Too many things can happen, as we often find out. I was just in the woods mowing and clearing trails, and a 4" limb flipped on top of me, missing my hardhat-less head by inches.  ::) ::)  Just being in the woods without a hardhat is probably not wise, even when not cutting.
Wear the protective gear too, especially the chaps.
Offline jimparamedic
« Reply #14 on: September 19, 2010, 04:25:44 PM »
I've used a car jack to lift the log and get the saw out works on big logs too
Offline Emajsh
« Reply #15 on: September 19, 2010, 06:47:48 PM »
I usually take two saws with me in the woods, but i never go without an axe and wedges. You cant go wrong with an axe, if its a limb just cut it off with it and if its a log then drive a wedge. The axe always starts and never runs out of gas! :)
JD 340D  HUSKY 385XP 372XP
Offline motif
« Reply #16 on: September 20, 2010, 06:48:41 AM »
gush, from what you're guys saying even a 3 chainsaws could be not enough... ;D
I need a axe and a wedge then with me all the time that for sure.
Offline Buck
  • Another "traveling man"
« Reply #17 on: September 20, 2010, 07:09:44 AM »
Murphys law will prevail.... ;)
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
Offline Nate Surveyor
  • If you like work, you will always be happy!
« Reply #18 on: September 20, 2010, 08:09:49 AM »
I found an old rusty bar, with chain, stuck in a standing tree, one time!
N :D
I know less than I used to.
Offline submarinesailor
  • LT15 and a wife of 45 yrs
« Reply #19 on: September 20, 2010, 06:25:37 PM »
I found an old rusty bar, with chain, stuck in a standing tree, one time!:)N :D
Nate,  Can I have my bar back.  I meant to go and get, but I forgot. ::) ::) ::) ::)
Bruce
Chainsaw stuck in tree (#%^*+#)
Started by Firewoodking on Firewood and Wood Heating
Last post April 07, 2013, 08:36:30 PM
by Busy Beaver Lumber
Removing a chainsaw stuck in a tree-the wrong way!
Started by fritz423 on Forestry and Logging
Last post September 23, 2016, 01:45:07 PM
by BurkettvilleBob
Milled a big old pine today & learnt a little!
Started by JoeyLowe on Sawmills and Milling
Last post March 21, 2002, 09:46:33 PM
by Cedar Eater
Lessons I learnt the hard way during my Stihl 044C rebuild...
Started by Andy171361 on Chainsaws
Last post January 15, 2016, 07:55:26 PM
by Al_Smith
