Arborwear
Author Topic: Idler pulley clutch and multiple belts.  (Read 1543 times)
Offline pyrocasto
« on: September 22, 2010, 12:58:56 PM »
Hey yall, finally joined after doing a ton of reading. 24 year old cabinet builder in the process of building my first bandmill now and it's going to be a BEAST.
I'm finding it's very popular on here that people use an idler pulley and a lever to engage and disengage their blades. I've heard alot about these "pins" that keep the belt off the drive pulley so there's no friction when disengaged but I cant seem to find any pictures seeing how that works. For those of you just using a idler pulley alone, do you find you have problems with friction heating your belt or spinning your blade when disengaged?
Also I'll be running a 30hp Wisconsin and figured I'd need dual belts/pulleys but wasnt sure. Any suggestions?
Offline ladylake
Re: Idler pulley clutch and multiple belts.
« Reply #1 on: September 22, 2010, 03:01:56 PM »
On my mill the pins stick out maybe a couple inches from the outside of the pulley.. I'd make some kind of clamp on pins that you could move around to see what works the best for your setup. If that a old 30hp Wis you might need 3 belts.   Steve
Offline dovetails
« Reply #2 on: September 22, 2010, 03:10:09 PM »
Welcome to the group!
 My old stump grinder has a 25 hp on it, set up for 5 belts, but I've only ever
used 3, and most times only 2 on it, and it's turning a 400lb 3 foot dia wheel,with the teeth that grind the stumps. If the teeth grap, it will stall out the motor,so I would say you should be fine with 1-2 at the most on a bandsaw.  Love them old wisconsin motors! Mine sets for months at a time, but when I need it, it fires right up.
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
Offline bandmiller2
« Reply #3 on: September 23, 2010, 07:18:24 AM »
Pyro welcome,alot depends on your belts but usally burning and excessive wear of the belts is not a problem.I've had the same dual belts on my bandmill for a long time.Belt idler systems are quite forgiving and can be either over center or spring loaded.Don't worry about pins or outher belt constraints unless you find you need them. Frank C.
Baker 18HD failed idler pulley
Started by caver on Sawmills and Milling
Last post October 18, 2010, 10:09:09 PM
by caver
Homebuilt band mill motor mount to engage the belt or an idler pulley need input
Started by HOGFARMER on Sawmills and Milling
Last post January 22, 2006, 09:09:05 AM
by highpockets
Need Info on LM 2000 > Clutch Shaft Size, Pulley Size, V-Belt Size for 23 HP BS
Started by H60 Hawk Pilot on Sawmills and Milling
Last post October 17, 2009, 07:57:09 PM
by Ironwood
gripnotch belts versu smoth belts
Started by Polly on Sawmills and Milling
Last post November 17, 2008, 06:19:57 PM
by pineywoods
