Author Topic: Band Blade Grinder  (Read 1904 times)
Offline Tom_Averwater
  • Semi- retired Carpenter
Band Blade Grinder
« on: November 12, 2003, 06:04:53 PM »
I am in the need for a new band blade grinder.I have looked at the Dino ,Baker,Hudson and Cook's grinders. Are there any other grinders out there that I have not mentioned ?
  What brands are you do it yourself guys using ?
       Thanks Tom
He who dies with the most toys wins .
Re: Band Blade Grinder
« Reply #1 on: November 12, 2003, 06:05:59 PM »
Wood Mizer.
I like Cooks too.
Offline SawInIt CA
  • I need to eat sawdust
    • Logs to Lumber
« Reply #2 on: November 12, 2003, 06:17:25 PM »
I send mine out but Suffolk is good I am told
Offline Ed_K
« Reply #3 on: November 12, 2003, 06:25:26 PM »
 I have the dino, works good, after I learned to set it up  :D.
Ed
Ed K
Offline Neil_B
« Reply #4 on: November 12, 2003, 06:48:40 PM »
I'm with Ed, using Dino. Infinitly adjustable but not easy to figure out ???
Neil
Timberwolf / TimberPro sawmill, Woodmizer edger, both with Kubota diesels. '92 Massey Ferguson 50H backhoe, '92 Ford F450 with 14' dump/ flatbed and of course an '88 GMC 3500 pickup.
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #5 on: November 13, 2003, 04:45:39 AM »
I sharpen blades for customers, I use Cooks Cat Claw with Timberwolf Dual Tooth Setter.
I considered the Dino, but too many people said it was a little complicated to set-up.
JIM
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
Offline MrMoo
  • Do you have a spare log dar
« Reply #6 on: November 13, 2003, 06:37:56 AM »
Tom,
I use a grinder made by Wright Tool. It works well. For setting I use a Cooks Catclaw and that works very well.
I also know that Logmaster resells the Wright grinder, and a setter setup on their own table.
http://www.wrightools.com/w37abg.htm
http://www.logmaster.com
Grinder Head Angles on a TECOMEC chain saw grinder--Same grinder as Oregon 511
Started by hydro2 on Chainsaws
Last post November 29, 2005, 01:15:23 PM
by rickk
Jockey grinder for doublecut band
Started by shenandoahsawmill on Sawmills and Milling
Last post September 28, 2011, 01:53:32 AM
by Woodchuck53
Bought a Band Grinder Today
Started by Tom_Averwater on Sawmills and Milling
Last post September 14, 2004, 03:53:11 PM
by jgoodhart
Jones Saw tools blade grinder
Started by scsmith42 on Sawmills and Milling
Last post April 06, 2011, 07:15:18 AM
by scsmith42
