Author Topic: Deer Stand my Norwood Built  (Read 8529 times)
Offline Planman1954
« on: September 30, 2010, 06:13:49 PM »
Hi all:
Just thought I'd post a few pictures (everybody likes pictures, ya know) of a deer stand I built near my house, all with SYP cut on my Lumbermate. It took about 4 half days to saw out the boards and put it together.
This is a close up photo of the whole stand.
This is a view of the stand as you approach it from my house.
This is a view from inside the stand looking down the pipeline to where Bambi will be.
This is a view from inside looking up at the wood shingles (What else did you think I would use?)
This is a close up with the door open.
I hinged the openings on the 4 sides so that I can lock it up to keep out varmints. I can't wait to break it in next month! God bless.
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Offline fishpharmer
Re: Deer Stand my Norwood Built
« Reply #1 on: September 30, 2010, 06:39:45 PM »
Looks good.  Did you dry the lumber, or is it "green?"
Also, what are the dimensions?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline jdtuttle
  • If it's worth doin, it's worth doin right
« Reply #2 on: September 30, 2010, 06:55:53 PM »
Deer Stand? Looks to nice ;D I'd probably get to comfortable & fall asleep while the deer are grazing next to it ;)
Nice job
jim
Have a great day
Offline Bibbyman
    • Warden Sawmill
« Reply #3 on: September 30, 2010, 07:18:28 PM »
Looks great but how are the deer going to climb up in it?   :)
Sawing since '94
Offline pasbuild
« Reply #4 on: September 30, 2010, 07:29:17 PM »
I'd show ya pic of my camp/blind that I sawed on my Norwood but its still just a couple of stacks of boards  :D they should be good and dry when I get the time to build
If it can't be nailed or glued then screw it
Offline Planman1954
« Reply #5 on: September 30, 2010, 08:18:02 PM »
Some of the lumber is green...I think the siding had dried for a few weeks stacked. The thing is 6'x6' square. I made enough head clearance to stand up inside because I ALWAYS hit my head on low joists! I wanted enough elbow room for 2 to be comfortable. My wife said she would go with me some. Oh yeah, and I'm not going to paint it until the end of the season so the deer won't be put off by the smell. By that time, it'll have all its creaks and cracks exposed, and then I'll caulk it and paint it camo or somethin'.
Offline Bibbyman
    • Warden Sawmill
« Reply #6 on: September 30, 2010, 08:37:38 PM »
The guy that wired our mill was paid off in lumber.  He used it to build a deer stand for his dad.  His dad is not in good physical condition so he built stair steps up into it.  I think it was something like 10x12 with insulation, drywall, heat and all.  They put in an old recliner for him to set in.  I never got to see it but heard a lot about it.
I got to tour another deer stand made from a small grain bin.  It was built on a platform about 12 off the ground.
My deer stand is the sawmill.  I just lean the old 45/70 against a post out of the way and keep watching around as I saw.
Sawing since '94
Offline pineywoods
« Reply #7 on: September 30, 2010, 08:45:07 PM »
Nice, almost too nice. You guys should see the house planman built, and the furniture he has built. Makes my stuff look downright crude.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #8 on: September 30, 2010, 09:05:53 PM »
I could live in that.  Single, I might add  :).
Offline gary
« Reply #9 on: September 30, 2010, 10:13:17 PM »
If you could live in that. I can see why your single.
Offline pigman
« Reply #10 on: September 30, 2010, 10:31:58 PM »
Planman1954, pineywoods gave you a hint to post some pictures of your house and furniture. I am not going to hint. Please post a few pictures of your house and furniture. ;D
Offline paul case
  • Original wearer of the PCM.
« Reply #11 on: September 30, 2010, 10:36:03 PM »
he must be afraid to since you guys already want to ''live'' in his wifes dear stand! :D pc
pc
Offline StephenRice
  • "Pure gold fears no fire." - (Old Chinese proverb)
« Reply #12 on: October 01, 2010, 03:00:53 AM »
Looks really nice.  I KNOW I would fall asleep in it.  I am sure that you have a little heater to put in there as well, don't you?  I really like the recliner idea (especially with a little gas burner or stove to make coffee, tea, or hot chocolate), but am sure I would be sawing more logs than your Norwood!
"Pure gold fears no fire!" - (Ancient Chinese proverb)  What do you fear?
Offline Planman1954
« Reply #13 on: October 01, 2010, 08:57:11 PM »
Ya'll are a hoot! I love reading the comments as they ramble and build on one another. I'll try to post some photos later...probably in the general woodworking section. My degree is in industrial arts from CSULB. I majored in drafting and furniture making. When i graduated, I started drawing houses (been doing it for 32 years now) and building furniture for the family. I've got over 100 books on measured drawings of furniture. I've built a lot of pieces, but they are scattered around the country now with family. I'll try to dig up some old pics and post next week. The front of the house I'm still building (been on it 5 years now) is at the  beginning of "Making and Installing wood shingles" thread, or in my photos.
Offline pineywoods
« Reply #14 on: October 01, 2010, 09:04:05 PM »
Planman did it all backwards. He built a house and a bunch of nice furniture, and THEN bought a sawmill. Oh well, he's using the norwood to build a barn and a deer stand. I keep waiting for him to move the mill into the barn and kick the goats out in the cold. If all this isn't enough, he is one heck of a musician.
Offline pigman
« Reply #15 on: October 01, 2010, 10:20:39 PM »
I did think that was a funny looking sawmill in front of him in his avatar picture. ;)
Offline johncinquo
  • Oh Boy A place to cut up!
    • My Pictures
« Reply #16 on: October 06, 2010, 12:42:39 PM »
Looks great.  From my experience I would say to move the hinges from the bottom of the windows to the top, swing them up to stay open and hold them up with a wire or latch or nail.   They stay out of the way of guns, knees, foot rests on the barca lounger.   :D    Add a couple small shelves for calls, shells, gloves, binoculars, coffee cups, cookies, scents.
I usually live in my blind for several weeks out of the year.  Comfort and ease of use is key.  I also line the whole thing with old carpeting.  Keeps it real quiet and no banging around on the walls or floors.
To be one, Ask one
Masons and Shriners
Offline Planman1954
« Reply #17 on: October 30, 2010, 12:18:47 PM »
OK...here's a picture of a walnut colonial bed I built about 1980. In the background is a Queen Anne highboy from one of Franklin Gottshall's books that I built a little before the bed.
Here's a photo of the cabinet I made to store house plan original flat files.
That's all for now. Take care.
Offline pigman
« Reply #18 on: October 30, 2010, 04:31:03 PM »
Thanks for the pictures, it was worth the wait.
Offline Warbird
« Reply #19 on: October 30, 2010, 06:18:05 PM »
Yes, it was.  Beautiful work.
deer stand
Started by trapper on General Board
Last post August 12, 2018, 11:28:06 PM
by Southside
View from your deer stand.
Started by Bogue Chitto on The Outdoor Board
Last post Yesterday at 06:15:06 AM
by Bricklayer51
Deer Stand Woes plus Fix
Started by Magicman on The Outdoor Board
Last post September 10, 2015, 09:48:42 PM
by Magicman
4-Board Fence my Norwood Built.
Started by Planman1954 on General Board
Last post October 05, 2018, 09:40:49 PM
by Planman1954
