(3) Different Scale(s) ~ Doyle, Scribner and Intl. < Why & Which One to Use ?
Started by H60 Hawk Pilot, October 18, 2010, 03:10:10 PM
H60 Hawk Pilot
I ran this Log through the different Scales (listed ^ above).
Log is 14.5 inches at the small end and 12 Ft. long.
Doyle =       83 b f
Scribner = 100  b f
Intl.        = 110 b f
I'm thinking that the Doyle Scale is used to purchase logs and a little on the low side but work's better for all grades
of wood, bowed, etc. .
I tried the Scribner last night and was real close to the 100 B F. I graphed the 14.5  inch log on graph paper and got 98 board feet. I took in account for 3/16" blade cuts and it all worked out on graph paper.
Also, this was a perfect log...  straight & good wood and all that.
My Question:
Use Doyle to buy wood, Use Scribner/ International Scale to scale nice logs for (expected) B F and make No mistake's when cutting ?
H P
Case 1150B & IHC TD-340 Dozer's, IHC 4WD 3800 & CAT 436B Hoe's, Franklin 170, Semi's: (1) Freightliner, (2) KW's, Marmon, Mack w/ Prentice Ldr., F-700 Crane Trk., (6) Mid Size Trk's. - Dumps, Flats, 1 Ton w/ 40 ft. 5th Whl. & (4) Semi Tlr's., LM 2000 Mill, (2) XL 12's., Solo 681, EFCO 152, Old Iron.
H P
You figured that out pretty well.  8)
Keep in mind, that all the scales allow for deductions for sweep, crook, rot, checks, etc that limit the lumber produced from a log.
Gary_C
Some parts of the country will set one as a standard measure. Here it's Scribner Decimal C. Other places it's Doyle but that is best used for buying, not selling as you figured.
