Author Topic: 353 detroit vs mf perkins 4.248  (Read 1632 times)
Offline vtlogger1973
  • If it aint broke, fix it till it is
« on: October 26, 2010, 10:37:23 PM »
i am considering buying a78 230 TJ with a 4 cyl perkins engine, but i am unfamiliar with this motor.  I own a 230 with 353, and like it alot.  Is anyone out there able to compare the two for me.  Horsepower, fuel consumption; longevity, availability and cost of parts, cold weather starting, etc.  I wouldnt know a new one from one that was worn out (perkins). and that is my only hangup about this machine.  Any info would be greatly appreciated.  Also, if thr perkinws failed, could it easily be replaced with a detroit?     thanks
Offline fishpharmer
Re: 353 detroit vs mf perkins 4.248
« Reply #1 on: October 27, 2010, 05:40:05 AM »
Welcome to the Forestry Forum vtlogger1973! 8)
Not much skidder experience for me.  I can share my experience of owning a farm tractor with the 4 cylinder Perkins 248 engine.  At 3000 hours the engine has been trouble free.  Fuel consumption seems reasonable, I can run a 8-10 hour day on 21.7 gallons.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline Mark K
« Reply #2 on: October 27, 2010, 04:43:57 PM »
Welcome to the forum. I have a 225 with a 353 and have had good luck with it. One of the other loggers around here has a TJ with a 6cly 360 perkins in it. Been a real good machine for him. Pretty good on fuel and starts good as long as the glow plugs work. We have a couple of perkins engines on the farm in our Whites and Olivers. Held up very well and are fairly cheap to rebuild. Good luck
Husky 372's-385's,576, 2100
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Offline aksawyer
« Reply #3 on: October 28, 2010, 12:48:44 AM »
Am very familiar with both engines.Both, as you all know, have their individual advantages.The perkins are never having any catostophic failures,such as the other higher reving motors,(two stroke detriot).The perkins builds its power much slower than almost all the other engines.But once you own one it will be with you forever.They just dont blow-up....The detriots are strong running engines they last fairly long,cheaper to rebuild,at least up here,.If your machine is an auto tranny you should lean towards the detriot,as the quicker power is better for the hard to break loose turns.Aksawyer       12 degrees out today   still very little snow.
353 detroit vs 4248 perkins
Started by vtlogger1973 on Forestry and Logging
Last post October 31, 2010, 07:15:59 PM
by bushmechanic
Cat/Perkins 51 HP
Started by petefrom bearswamp on Sawmills and Milling
Last post March 15, 2015, 02:43:35 PM
by SawyerBrown
Perkins 248 Gone
Started by Ohio_Bill on For Sale
Last post February 10, 2018, 05:22:00 PM
by Ohio_Bill
Perkins turbo,
Started by bama20a on For Sale
Last post November 17, 2012, 03:39:27 PM
by tempforce
