Author Topic: shake  (Read 1547 times)
Offline laffs
shake
« on: October 27, 2010, 07:56:52 PM »
ive been cutting some hemlock from my neighbors lot(yes he knows) this is for my sawmill. so far ive cut around 5000 feet id say more than half has shake. i want to cut more but i dont want the shake. is there any tell tail sign to look for. other than seames in the trees
Brent
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
Re: shake
« Reply #1 on: October 27, 2010, 10:48:16 PM »
Ring shake is a well known defect in hemlock in my area.  Maybe somebody else knows, but to my knowledge, there is no known way to tell if a tree has it or not.  The local millers here just accept that it occurs and buy very little hemlock and pay very little for it because of this.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Exiled from Sawdust Land--plotting a return
Re: shake
« Reply #2 on: October 27, 2010, 11:20:27 PM »
I looked in the dictionary for a definition of shake, and didn't find it there. Can someone please define it, and maybe we can add it to the dictionary, too?
Hemlocks were my favorite climbing tree as a kid-- lots of nice, horizontal, nicely spaced branches with no sticky pitch. The big ones were often some of the tallest trees around there in my part of central Maine (along with big white pines, and so on, where they weren't all logged out). I would like to climb the taller hemlocks around our place and I could see out over the green blanket of trees for miles-- from the old railroad feed mill in the east (defunct by that time) to the SD Warren Scott Paper plant's exhaust plume in the west. My sisters never knew where I was and I could be alone with my thoughts for hours until the branches started being uncomfortable.
My dad considered hemlocks to be the biggest weeds known to mankind (only bigger in size than the even more loathed popple). But he did find it useful as a structural timber wood and so on. Sometimes we burned it for firewood, though it was certainly not our first choice.
Oh, sorry to go sentimental and tangental on you when the real issue here is shake. What is shake?
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Reduced to Uber Driver and a broken MS290 Stihl
Genesis Hardwood Lumber
Online beenthere
Re: shake
« Reply #3 on: October 28, 2010, 12:33:50 AM »
 Shake. A separation along the grain, the greater part of which occurs between the rings of annual growth.
Similar to how an onion separates.
Offline jdtuttle
  • If it's worth doin, it's worth doin right
Re: shake
« Reply #4 on: October 28, 2010, 06:40:23 AM »
Have a great day
Offline thecfarm
Re: shake
« Reply #5 on: October 28, 2010, 08:36:12 AM »
You have got into some bad hemlock.Hemlock has really got a bad name for shake.I've cut quite a bit of it on my own land.Some I've sold and some I've cut on my mill.When I do see shake,I just start to butt it about 4 feet.I don't recall ever going more than 2 cuts on the ones that looked good standing.There was some trees that did not look good and it went as pulp.I feel you should be able to see it as soon as you can see the end of the tree.The rings will look like they are separating.Some of these trees were 70 years old too.I'm really only guessing here,but if I've cut 100 trees only 10 had to be cut 8 feet to rid of the shake.That's not counting the once I knew was no good.
Offline Ron Scott
Re: shake
« Reply #6 on: October 28, 2010, 11:03:54 AM »
From The SAF Dictionary of Forestry
shake
1. a fissure or crack in a log or stem that follows a growth ring for some distance 2. a longitudinal fissure or crack in lumber resulting from stresses that caused the wood fibers to separate along the grain and not extending in the converted piece from one surface to another —see growth stress 3. a thin section split from a bolt used for roofing or weatherboarding —see shingle —see windshake
This definition last updated 08/04/2008
~Ron
Offline laffs
Re: shake
« Reply #7 on: October 28, 2010, 06:38:45 PM »
jay if they even take it now it has to be cut to 8' now. i dont know of any mill that takes tree length now.
a lot of this stuff im cutting now is over 27" so they wont take it for pulp anyway. most of them average about 500bf each.
theres just a ton of shake in the area im cutting now.he has about 50 acres of it, hope its not all like that.
Brent
Shake, ring shake, wind shake in timber
Started by pine on Sawmills and Milling
Last post June 13, 2014, 02:08:45 PM
by Ron Wenrich
Shake
Started by Magicman on Forestry and Logging
Last post July 10, 2010, 05:26:47 PM
by woodmills1
Is this shake
Started by brdmkr on Sawmills and Milling
Last post May 04, 2007, 04:48:58 PM
by inspectorwoody
Shake Rat
Started by Gilman on Sawmills and Milling
Last post October 20, 2004, 10:56:07 PM
by Gilman
