DR wood chippers
Started by DaveP, November 14, 2010, 10:24:16 AM
DaveP
     Has anyone used he DR wood chippers?  I have a lot of buckthorn to clear and wonder how this chipper would work in a small wood lot.
Busy Beaver Lumber
I can not speak to the new style ones they offer with the 18hp engines, but I did have a 12hp one that was about 7 years old and in excellent condition. Nor am I familiar with buckthorn.
I can tell you this, it did a pretty good job on green, fresh cuttings up to about 2 inches in diameter and bush prunings and garden stalks. You had to be patient with it, but it cut through it pretty steadily and made nice small chips. Now hard, dry wood was another story. It was pretty much a joke to try to chip hard wood that had dried, even in the 1 to 2 inch range. The vibration of holding on to the limb and feeding it into the chipper was enough to tire anyone and it took forever. If you let go of the dry pieces, they would often bounce off the blade and shoot back out of the chute.
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
isawlogs
 I have an older verson , might be 15/20years old , it is a good little machine , but as said , soft wood is good for it , hardwood up to two inches it will take no problem , any thing over that and up to the trhee ich capacity is a chore. The vibration from holding the peice there to be chewed up gets old mighty quick, now it all depends on how much ones needs to do at a time, if you cut and chip , it goes well if you pile the limbs and  have half a mountain full and start chipping away at it .. well get something else .  ;) ;D
   Marcel
