Author Topic: timberking wiring diagram  (Read 5418 times)
Offline pnhigg
« on: November 16, 2010, 01:45:21 PM »
I searched and could not find anything, but if this has been brought up previously, recently, and/or often, my apologies from the start.
I have a timberking b20 that was recently purchased used.  After some refurbishing it seems to be sawing very well, but we are having some minor electrical issues with the blade up/down electric motor.  It appears the previous owner has replaced some of the solenoids, and the wiring has been manipulated some.
Does anyone have an electrical wiring diagram for the saw?  I have spoken with timberking, but have not had a lot of luck there.
Any help would be greatly appreciated.
Thanks,
Patrick
Offline Mark Webb
    • farmandwoodlandservices
Re: timberking wiring diagram
« Reply #1 on: November 16, 2010, 05:17:14 PM »
If you will give me email address I will scan mine and send it to you.
The Lord made enough time in each day to do what we need to do "graciously".
Offline redbeard
    • whidbeysawmill.comwww.whidbeysawmill.com
« Reply #2 on: November 16, 2010, 10:39:48 PM »
Hello pnhigg welcome, Do you have setworks and what year do you have? sometimes its cord reel cleaning to  loose pins in the connector plugs my 2006 had a bad connection on the wires brian was talking about they plug into a junction the pins eventually vibrate loose. Don't get fustrated with TK techs they will work with you I threw my hands up first couple of times its best to do your homework and ask specific questions about your problem at hand. A manual is something you will need right away
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
Offline paul case
  • Original wearer of the PCM.
« Reply #3 on: November 16, 2010, 10:46:46 PM »
cant even offer any kinda help except to say
''welcome to the forum'' ;D    pc
pc
Offline ladylake
« Reply #4 on: November 17, 2010, 05:54:18 AM »
 It's the green ground wire in the TK cord reel that messes up the setworks. Anyone ever figure out how that goes through the cord reel.   Steve
Timberking B20 14000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Suffolk  setter Volvo MCT125c skid loader
Offline pnhigg
« Reply #5 on: November 17, 2010, 09:53:45 AM »
thanks guys.
TK has been ok, no terrible frustration, but we (my dad and I) were told they never printed a manual for that model saw.
The saw is a 1997 model, and it does not have setworks.
I don't know if there is a way to tell if it ever did have or not.  The saw was bought at a farm auction so we don't know what its original setup included.
We bought the saw cheap enough, that we expected there to be some issues, but so far it has done great with some minor refurbishing, we just can't seem to work out the wiring gremlins.  It will only be used for our own use.
The spcific problem we are having, and I have discussed withi ladylake some (thanks again for the help) is that the electric up/down motor often stops after it has been on for more than a few seconds.  We replaced the circuit breaker, but no change.  The soleniods are new, and the motor has been checked out and is ok.  It seems like we are pulling too much current and triping the breaker, but we can't figure out why.
Sorry for the ignorance, we are both new to this saw, having only used manual bandmills in the past, but I really appreciate all your help.
email: pnhigg@yahoo.com
Thanks,
Patrick
Offline ronwood
  • Enjoy Making Sawdust !!
« Reply #6 on: November 17, 2010, 12:07:28 PM »
Patrick,
Do have you anything that may be binding or needs lubrication? Is the motor big enough for the job?
I had issue with my Woodmizer once on the up/down motor and it was associated with rust on the vertical supports were the head moves up and down. Remove the rust and have kept it lubricated and have not had a problem since.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline pnhigg
« Reply #7 on: November 17, 2010, 01:05:55 PM »
Thanks,
We did clean the vertical supports as they has some very minor rust.  They are shiny now, and have been lubed.
The motor is the one that came with the machine, and we were working under the assumption that it was correctly sized, but I suppose it is possible that it is too small.
It's 1/4 horse d/c motor.
Offline ronwood
« Reply #8 on: November 17, 2010, 06:43:02 PM »
Paterick,
Have you looked at all the connections going to the motor to verify that they are good. Poor connections can cause voltage drops that in turn can cause a large current draw causing the breaker to trip.
Ron
Offline ladylake
« Reply #9 on: November 17, 2010, 07:50:27 PM »
 Do you keep  the lead screws lubed good , I used 80-90 in the summer and a little lighter in the cold. I cut a little slit in the accordian boots about 3 folds up and oil 7 or 8 pumps 2 or 3 times a day. Make sure the plastic slides aren't too tight.  Also the breaker TK put on is a little undersized, when I first got my mill the up-down worked good untill cold weather came , then it was tripping the breaker all the time. I bypassed the breaker with no ill effects in 8000 hours but one could fry something with no breaker. I think they come with a 30 amp breaker, maybe a 40 or 50 would work and still offer some protection.    Steve
Offline ladylake
« Reply #10 on: November 17, 2010, 08:05:04 PM »
 Just checked , a 1/4 hp 12v dc motor draws 21 amp at full load so in theory a 30 amp breaker should work if everything is working good. What kind of shape are your lead screws in, they should have some flat surface on the outside of the threads . If worn to a sharp edge they will cause a lot of drag. Check  the bearings at thwe toop of the lead screws, if not greased good or shot that would cause more drag.   Steve
Offline Tom the Sawyer
  • Converting your logs to lumber at my home or yours
    • Tom the Sawyer Portable Sawmill Service
« Reply #11 on: November 17, 2010, 09:43:42 PM »
I had a problem with my B-20 bogging down and not going to the highest cut position.  Talked to Mike at TK and he offered this check which immediately resolved my problem.  Note:  my B-20 is a late 2007 model that had only about 10 hours on it at the time.
Set up the mill and level it as perfectly as you can.  Then place your level on the exposed acme screw threads that raise and lower the saw head.  Check it on the inside of the screw and at the back (90 degrees apart).  My right one was dead on, the left one was off.  If either one is off you have to loosen the bolts on the bearing at the top of the screw, just below the chain gear.  Mine was moved outward 1/8" and forward about 3/16" to get the screw perfectly plumb and retightened.  Problem solved.
07 Timberking B-20, Custom-made log arch, 20' trailer w/ log loading arch, F350 SD flatbed dump.  Princeton piggy-back forklift.  Bobcat S250, Stihl 025C 16" and a Husqvarna 372XP 24/30" bars, Grizzly 20" planer, Nyle L200M DH kiln.
If you call and my wife says "He's sawin logs", I ain't snorin'.
Offline pnhigg
« Reply #12 on: November 18, 2010, 09:22:51 AM »
Mark;
Thanks for emailing the wiring diagram
Tom:
We just wondered about that.  One of the acme screws does appear out of plumb slightly, so we will try that next along with making sure the wiring is correct.
Thanks as well to everyone else who has offered suggestions.
Offline pnhigg
« Reply #13 on: November 23, 2010, 11:50:45 AM »
FWIW, I think we have everything in order now.  Sawed quite a bit yesterday, and everthing worked great, all day, no issues, electrical or otherwise.
One of the screws was enough out of plumb that the saw was binding before it raised the the final up position, as Tom described.
Appreciate all the help guys.
Offline eireog68
  • From the Auld sod to the Big Woods
« Reply #14 on: January 21, 2011, 10:58:06 PM »
hey tom the sawyer nice pics could you do me a favor and give me the make and model of the selector valve for the toe boards.
Back to Basics with new age tools
If we all had desk jobs who would make the desks
Buy American and give your children job,s
or buy imported and have to support them for life.
« Reply #15 on: January 22, 2011, 01:29:14 PM »
eirog68,
The only name on the control is "Hydraforce" and it is stamped with the following numbers;
JEM960926-A,  04/34.
Offline Itsoktowin
« Reply #16 on: May 10, 2019, 08:19:18 PM »
I bought a 1997 all electric B20 at an auction the hydraulic motor runs everything functions. I have good power everywhere but cant get anything else to turn on. If anyone were too have a wiring diagram Timberking does not.
 I can push the switch in manually for the mill motor(15hp) but it wont start the motor and the push button control doesnt seem to function.
« Reply #17 on: May 10, 2019, 08:58:56 PM »
Sorry, the only schematic I have is for the control box.  My B20 is gas and 10 years newer.
Try to clarify your question.  You say that everything functions, and then list things that don't work.  If you have a meter, it shouldn't be too difficult to track down where the power stops.  Once you have that, Mike or Jason at TK should be able to walk you through.
Offline Itsoktowin
« Reply #18 on: May 10, 2019, 09:33:00 PM »
Thanks, yes I should clarify everything run by the hydraulic pump functions. I have power clear to every motor... but can only engage the motor that runs the hydraulic pump.
I can push the starter manually with a screw driver and the mill motor tries to start but wont turn .
Offline tacks Y
« Reply #19 on: May 11, 2019, 08:18:36 AM »
Have you tried to turn the motor by hand? Not froze up and kicking out the overload heaters? Is this single or 3 phase? May just be a bad switch on the starter? Know any one around with electric motor smarts? Motor starter not doing any thing when you push on?  Good luck
wiring diagram for Timberking TK350
Started by JACK STRAW on Forestry and Logging
Last post November 17, 2013, 10:05:24 AM
by kiko
grin
Timberking 2000 Kohler 38hp wiring diagram
Started by tmdffy on Sawmills and Milling
Last post December 09, 2014, 11:50:02 PM
by PC-Urban-Sawyer
Wiring Diagram
Started by woodhaven on Drying and Processing
Last post September 17, 2004, 03:28:38 PM
by Den Socling
Leeson wiring diagram --HELP
Started by BBTom on Sawmills and Milling
Last post August 12, 2006, 10:08:21 PM
by Bibbyman
