Author Topic: 029 fuel line and fuel filter  (Read 1269 times)
Offline tstex
« on: December 02, 2010, 08:34:13 PM »
Gentlemen,
Wanted to know if there are any special tools needed to pull and replace both the fuel-line and fuel filter for my 029?
If you have any "tricks-of-the-trade" or recommendations regarding anything in removing or re-installing these parts, I am ALL EARS. This is the first time I have been into my 029 before so I wanted to proceed with both good advice and caution.
Thank you very much & pls let me know if you have any questions.
Appreciate all your help and advice.
Regards,
tstex
Offline pineywoods
Re: 029 fuel line and fuel filter
« Reply #1 on: December 02, 2010, 09:21:45 PM »
You have to pull the line loose from the carb and pull the whole works out through the fuel filler opening. I use a surgical tool called a hemo stat, looks like a long skinny pair of long nose pliers. Coat the new line with waterless hand soap, otherwise you will probably damage it trying to pull it through the little hole in the tank. It ain't an easy job, helps if you have small hands.
Offline joe_indi
  • The older I get the more I learn
« Reply #2 on: December 03, 2010, 12:14:42 AM »
To remove the old fuel line, push it into the fuel tank from the top.
To install a new line, lightly grease or soap the grommet edge of the line and push it into the tank  from the top.Align the straight portion of the grommet with the corresponding area on the body.Push the grommet in using an angled clip pliers(no sharp edges). Or a screwdriver with a taped end.
To install the fuel filter onto the line you will need the best available tools anywhere in the world, your fingers!! :D  :D
Joe
Offline ErikC
    • Erik Cordtz Enterprises
« Reply #3 on: December 03, 2010, 11:38:18 PM »
 I replaced mine pretty recently, I just used a pair of needlenose and a small flat screwdriver, both with a wrap of tape, as described above. The lines are pretty soft, be careful with sharp edges.
Offline tstex
« Reply #4 on: December 13, 2010, 09:33:18 AM »
Thanks guys - I will give it a try.
Wishing everyone a safe and healthy holiday season.
Merry Christmas, tstex
Clean up and new fuel line, doesn't seem to pull fuel?
Started by fairlaniac on Chainsaws
Last post October 19, 2013, 06:51:51 AM
by Al_Smith
a odd fuel filter problem
Started by snowstorm on Forestry and Logging
Last post October 22, 2016, 10:59:42 AM
by Ox
Bubbling fuel filter
Last post September 27, 2019, 04:40:07 AM
by jcbrotz
Use a substitute fuel filter?
Started by Oldylocks on Chainsaws
Last post September 13, 2015, 09:58:53 AM
by fossil
