Tally-I/O
Author Topic: Logosol PH260  (Read 1447 times)
Offline logloper
Logosol PH260
« on: December 03, 2010, 09:21:59 PM »
Hi All
            I am fixing to start running 1x6 aspen through this machine to make TxG paneling. Some of the boards are bowed. Will this machine pull them through? I heard I might need to run them through a rip saw first, to straighten the edges. Would an edger work for this? Bought this new last spring and have been to busy logging to get it out of the crate. Pretty excited and will have more questions
Offline beenthere
Re: Logosol PH260
« Reply #1 on: December 03, 2010, 11:06:34 PM »
Bow is warp on the flat face, so they should go through ok. If bowed too much, then cut their length in half (or where the worst bow is at).
Crook is warp at the edge, so either make the boards narrower to straighten, or again cut them in length.
A straight edge will help, as the edge cutter will only cut so deep. An edger will make the blanks the right width and produce the needed straight edge (pretty much).
Paneling is best with end joints, IMO, and uses up short boards. And is best utilization of the wood.
Enjoy. :)
Offline logloper
Re: Logosol PH260
« Reply #2 on: December 04, 2010, 08:10:50 PM »
Will this machine do end joints? If so, how?
Offline beenthere
Re: Logosol PH260
« Reply #3 on: December 04, 2010, 08:20:39 PM »
Can't imagine how it could do end joints (refered to as end matching).
It usually takes a machine that will cross transfer stock past the cutter heads for one end, then shoots the board to mould the other end to match.
I find for paneling, that a square cross cut and then a 45 relief makes a good looking job. If wider than 6", I'd use a biscuit to the ends.
Logosol PH260
Started by logloper on Drying and Processing
Last post February 17, 2011, 09:10:54 PM
by AvT
Logosol PH260
Started by boardmaker on Drying and Processing
Last post September 25, 2014, 10:05:51 PM
by scsmith42
First run on logosol ph260
Started by MikeH on Drying and Processing
Last post July 16, 2007, 02:27:58 PM
by Dodgy Loner
Logosol PH260 repair help
Started by crosscutlumber on Drying and Processing
Last post November 12, 2013, 03:45:15 PM
by Litrvodki
