Author Topic: Kiln Chamber  (Read 1053 times)
Offline jdtuttle
  • If it's worth doin, it's worth doin right
Kiln Chamber
« on: December 17, 2010, 08:11:59 AM »
Has anyone built a kiln chamber either using factory built SIP panels (Structural Insulated Panels) or making your own panels. I would have to add metal sheathing but it would make a tight kiln chamber. Kiln direct has similar kilns but they are expensive.
jim
Have a great day
Offline Doug_D
    • Log cabin rental business startup
Re: Kiln Chamber
« Reply #1 on: December 17, 2010, 12:50:57 PM »
Not yet - but I have a bunch of SIPs left over from a project that will eventually become my kiln  ;D  I am hoping 8" of foam will really help with the electrical consumption.
I've got what is called "nail base" sips.  They are nothing more than foam with osb on them.   It's my plan to simply build a frame and cover it with the SIPS.  I think you will find that most infiltration problems happen around structure openings such as access doors and building joints.
Our adventure in Building a Log Cabin Rental Business!
www.cabinstartup.com
question
Kiln Chamber
Started by Stump Jumper on Drying and Processing
Last post October 18, 2018, 10:40:32 AM
by K-Guy
Kiln Chamber
Started by K-Guy on Nyle Systems
Last post February 01, 2019, 09:41:34 AM
by jimbarry
Kiln chamber?
Started by Kevin_H. on General Board
Last post October 06, 2003, 05:39:39 PM
by Kevin_H.
Kiln chamber?
Started by Kevin_H. on Sawmills and Milling
by Kevin_H.
