Author Topic: Briggs & Stratton  (Read 1115 times)
Offline JBS 181
Briggs & Stratton
« on: December 17, 2010, 03:47:54 PM »
I have a 16 hp OHV Briggs & Stratton on my mill. I should adjust the valves  for routine maintenance. What is the procedure for this? What kind of gap am I supposed to have? Thank You for your help.
Offline sawguy21
Re: Briggs & Stratton
« Reply #1 on: December 17, 2010, 10:02:19 PM »
Remove the valve covers and spark plugs. Start with cylinder #1, closest to the flywheel. Rotate the flywheel by hand until the piston is at top dead center on the compression stroke, both valves will be closed and you can watch the piston through the spark plug hole. You can also use a piece of stiff wire like a welding rod or coat hanger, drop it into the spark plug hole and watch until it stops rising.. Rotate the flywheel another 1/4 turn.
Loosen the lock nut on each rocker and move the adjuster until a .005" feeler gauge leaf will move between the rocker and valve with a slight drag. Without moving the adjuster, tighten the lock nut and re check. You may need to repeat the procedure a few times until the feeler gauge drags slightly with the lock nut tightened. Install the valve cover with a new gasket and you are good to go. Repeat on #2.
Offline JBS 181
« Reply #2 on: December 18, 2010, 10:29:19 AM »
Thank you for your help
Offline Slabs
  • It don't get no better than flyin' sawdust
« Reply #3 on: December 18, 2010, 07:42:19 PM »
How many hours on the engine?
I've never adjusted valves as routine maintenance unless the valve train had been serviced.
If it ain't broke..................................!!
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.  Woodshop, metal woorking shop and electronics shop.
Briggs and Stratton won't run
Started by Tom on General Board
Last post November 26, 2007, 07:17:04 PM
by Polly
Help with 8 h.p. Briggs & stratton ?
Started by bama20a on General Board
Last post April 27, 2011, 01:05:37 PM
by red oaks lumber
35 HP Briggs & Stratton Vanguard
Started by woodbowl on Sawmills and Milling
Last post June 21, 2006, 01:24:35 PM
by tcsmpsi
Has anyone else had problems with the 16hp briggs and stratton?
Started by JSwigga on Lucas Mill
Last post August 22, 2013, 11:15:16 AM
by logboy
