EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: JD 440 c clutch issue  (Read 1285 times)
Offline jon440c
  • Member*
« on: January 02, 2011, 05:44:54 PM »
My JD 440c skidder is loosing power, it cannot get out of its own way.  I can only move in low gear, tires will not spin if I'm up against a rock.  Does not move when I push too hard on the accelerator, if I throttle back it starts moving.  When it stops, I move the wheel back and forth and suddenly it starts moving again.
Please tell me it's my clutch, I heard if it's a transmission I'm screwed.  Also, can the clutch be worked on without pulling the engine?
Offline Mark K
Re: JD 440 c clutch issue
« Reply #1 on: January 02, 2011, 06:11:04 PM »
Is it a powershift or a standard transmission? Do you have any freeplay in the clutch? Could be anything from a rear main leaking on the clutch to a clutch or powershift. If it's just the clutch it's not to expensive. I have a 540D in the shop that the powershift is slipping bad. We're thinking about parting it once we found out the cost of a rebuild.
Husky 372's-385's,576, 2100
Treefarmer C7D
Franklin 405
Belsaw m-14 sawmill
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #2 on: January 02, 2011, 06:47:25 PM »
Clutch inexpensive repair , Power-shift 5 to $8000.00 to rebuild, my Funk cost me 7200. to rebuild, a new one was $14000.00, this was 25 yrs ago.
I sure hope this isn't your case, best of luck
Offline snowstorm
« Reply #3 on: January 02, 2011, 07:08:50 PM »
you must pull the motor. isnt really as scarey as it sounds. clutch pressure plate throu out bearing check pliot bearing. may need flywheel resurfaced. also a good time to change rear main seal if a lot of hrs. on motor.
Offline Bobus2003
« Reply #4 on: January 02, 2011, 07:15:43 PM »
I dunno how much they have changed, but i can pull my engine in my late 60's 440 and have it sitting on the ground in just a few hours.. really pretty easy too do
Stihl 045 clutch issue
Started by bigads on Chainsaws
Last post September 22, 2010, 03:01:40 AM
by bigads
Husky 385XP Clutch Safety Issue
Started by jteneyck on Chainsaws
Last post September 06, 2009, 02:28:55 PM
by GASoline71
Clutch Assembly Spring, and separate idling issue
Started by jcates888 on Chainsaws
Last post August 10, 2016, 02:31:50 PM
by HuckFin
Woodland mills clutch upgrade ??? bigger engine, but what clutch?
Started by mattyo5 on Sawmills and Milling
Last post August 23, 2016, 10:05:04 PM
by larrydown60
