Author Topic: How do you match old ER cedar with new?  (Read 1689 times)
Offline fishpharmer
« on: February 04, 2011, 11:27:58 AM »
I am repairing a cedar jewelry box. It is old and dark colored.  The new base piece I made is bright and pink.  The original finish that will remain is probably varnish. Is there any type finish that will "age" or darken the new cedar base, so it matches?
I appreciate any suggestions.
Thanks,
fish
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline ronwood
  • Enjoy Making Sawdust !!
Re: How do you match old ER cedar with new?
« Reply #1 on: February 04, 2011, 11:53:46 AM »
I am have the same issue. One of the woodworkers that I cut for suggested that I put the piece out in the sun to darken it. The ERC that I cut will brown after some time in the sun. Will let you know how it works.   In the case of the cedar chest I am repairing I  am removing all the finish and sanding down. The color of the cedar is a light brown.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #2 on: February 04, 2011, 01:18:38 PM »
Can ya sand the old brown off and get back to the pink
Chainsaw Carver
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #3 on: February 04, 2011, 01:40:29 PM »
You can place it out in sun light for a few hours and it will fade like it is aged.  Also if you sand the whole thing it will be about the same color.
ARKANSAWYER
Offline ronwood
« Reply #4 on: February 04, 2011, 01:47:08 PM »
In my case the folks want it to looked aged.
Offline fishpharmer
« Reply #5 on: February 04, 2011, 02:07:47 PM »
Thanks, for the replies.  The piece I am working on is a simple  6 inch by 12 inch box (owned by a female friend).  I think it was dropped (or thrown :o) ).  The top and sides are engraved on the outside.  It seperated on the lap joint corners.  It was easy enough to glue and clamp the joints together.  The bottom was a glued on thin ply.  The feet are cedar.  Only two feet remain.  I decided to just use a solid piece of cedar with a half inch overhang that has a routed edge.  The interior part of the new piece can remain unfinished.  The outside needs to match.  I have some scraps of cedar in the slab pile that had turned brown in the sun (not the right size).  So I will put the new peice on the dash of a parked truck for a couple weeks to see if the sun ages it.
Thanks again.
 Any suggestions on brand or type of varnish to use?  Most finishes at the big "L" owe store are polyurathane.  Only two types of varnish compared to what looks like hundreds of polyurathanes and stains.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #6 on: February 04, 2011, 08:03:12 PM »
James, not all ERC is the same.  Some trees will be lighter pink and some will be very dark almost purple.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: February 04, 2011, 09:25:54 PM »
James,
I like Minwax Fast Drying Polyurethane in the Satin sheen.
Offline fishpharmer
« Reply #8 on: February 04, 2011, 11:06:11 PM »
Thank you.
Offline Tullivor
« Reply #9 on: February 05, 2011, 12:05:08 AM »
Is it not surprising the cedar is varnished?  I thought you wanted cedar to breathe?  It smells too good to cover up with varnish!!  But if you have to you have to.  I use minwax polyurethane semi gloss and it puts on a real nice finish, and would darken it up a bit.  What about an option of using a completely different type of wood for the base, something contrasting??  Maybe wouldn't work but just tossing ideas out there!
mix & match stickers
Started by rmack on Sawmills and Milling
Last post July 29, 2013, 09:51:55 AM
by qbilder
big bore kit match up???
Started by husky fan 500 on Chainsaws
Last post October 07, 2013, 10:04:51 PM
by tlandrum
Ploughing match
Started by sawguy21 on General Board
Last post September 21, 2015, 07:44:41 AM
by thecfarm
K & M Match Case
Started by pappy19 on The Outdoor Board
Last post May 23, 2013, 01:54:21 PM
by Magicman
