Arborwear
Author Topic: Jd 440 Steering problem  (Read 8853 times)
Offline redprospector
Re: Jd 440 Steering problem
« Reply #20 on: April 08, 2014, 01:48:06 AM »
you dont need that fancy blade valve. replace it with a closed center spool valve. back in the 80's deere sold a conversion kit to replace the blade valve. it was a simple spool valve
[/quote]
Hmm. Now you tell me.  :D
Offline snowstorm
« Reply #21 on: April 08, 2014, 05:36:10 AM »
[/quote] you didnt ask before
« Reply #22 on: April 08, 2014, 10:58:57 PM »
Ok, I guess that's a pretty good reason.  smiley_beertoast
Offline Old Iron nut
« Reply #23 on: April 09, 2014, 09:58:52 PM »
Back in the late 70's or earlier 80's I worked for a chap that had a 440 JD skidder and every now and the the hydraulic system would screw up. It acted like it ran out of oil. We replaced some check valves in the front pump which we found later that wasn't necessary. There is a little oil pump in the rear of the transmission at the top that keeps the front pump primed. It finally got so bad that we could't use the machine. It turned the machine off to one side so that I had access to the rear of the tranny, drained off the oil in a washtub, and pulled the rear cover off the tranny. The suction line to the small pump was only held in by an oil ring and the line had fell out partially, allowing the pump to such air. I brazed the line back in place (totally around the line) and added a clamp to hold the line so that it could not vibrate out in case it broke again. Installed the cover, added the oil, and we never had any more trouble. This arrangement only shows how stupid some of these engineers are. Why couldn't they have the pump down lower in the oil so one couldn't have this problem. The oil line was only about a half inch in diameter or so as I recollect, it might have been a little larger, that was 30 plus years ago. Cheers, Old Iron nut.
Steering problem
Started by loggerman1959 on Forestry and Logging
Last post October 25, 2016, 08:40:59 PM
by loggerman1959
Garrett Skidder steering problem
Started by treetech on Forestry and Logging
Last post February 05, 2011, 08:12:31 PM
by redlaker1
Differential Steering
Started by Scott on Forestry and Logging
Last post March 07, 2003, 09:05:00 PM
by Mark M
Steering wheel shake
Started by ElectricAl on General Board
Last post December 05, 2005, 08:51:11 PM
by ElectricAl
