Author Topic: advice on repowering my timber harvester sawmill  (Read 5452 times)
Offline clint
« on: February 15, 2011, 06:39:05 PM »
Howdy fellas,
I have a Timber Harvester 36hte band sawmill.  It is powered by a 30 hp siemens electric motor.  It has been sitting up for a couple of years now because I moved to a new property that does not have 3-phase service.  I have been toying with the idea of a 3-phase converter, but I think that I might actually get more use out of it if I repowered it with a diesel engine.  I also have an edger that runs on 3-phase (20 hp siemens).  I need to make a decision on it soon,  my wife is starting to throw a fit about the logs I have slowly been stacking up on the back of my property.  I would be interested in hearing from anyone who has used both kinds of power before - what u liked or disliked about one or the other.  Also anyone who converted power sources -- any pitfalls I might need to watch out for.
Offline laffs
Re: advice on repowering my timber harvester sawmill
« Reply #1 on: February 15, 2011, 06:44:28 PM »
they came witha dutze diesle if that helps
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Online pineywoods
« Reply #2 on: February 15, 2011, 06:46:47 PM »
Been quite a few go the other way, gas to electric. I swapped out the gas burner on my mizer, removed a briggs and installed a liquid cooled kawasaki. It's fine. Wanted to go with a small diesel, couldn't find anything that wasn't too heavy and too expensive. Another option you might consider is a big 3 phase gen set. That would run the saw and the edger. used 3 phase gen sets are usually quite a bit cheaper than a single phase of comparable power.
Offline bandmiller2
« Reply #3 on: February 15, 2011, 08:10:15 PM »
Clint, good advice given,for what you would spend to buy and mount a diesel on your mill you could find a used 3 phase genset and run everything and the homested when the power fails.Does your 3 phase mill have a seperate motor for the hydraulics or do they drive the pump from the main motor with the festooned hoses?,that may weigh on your decision.
Offline Just Me
« Reply #4 on: February 16, 2011, 06:43:20 AM »
http://www.govliquidation.com/auction/endecaSearch?Ntt=generator&Ntk=P_Lot_Title&Ntx=mode+matchall&N=0&Nty=1&Ns=P_Lot_Number|0&words=generator&cmd=keyword
Here is a source for large gen sets, quite often cheap/
I run my wood shop off of a 50hp Rotary converter, no problems. I paid about 2600 for it new.
Offline junkorgem
« Reply #5 on: February 18, 2011, 07:50:18 PM »
I would defineatly consider a diesel genset. You should look into your total load requirement before shopping though. After you determine what you need you should be able to find one at a surplus site. It would be favorable, but more expensive to the phase converter option. I believe that it would be far more effecient price per kwh though.  If I remember, Groban Supply Company has a website with large military type portable gensets.
Offline bandmiller2
« Reply #6 on: February 18, 2011, 08:11:22 PM »
Clint,if your not into large gensets you can make a rotory phase converter reasonally cheap if you have heavy enough single phase service coming on the place.Of course if you want to go mobile you need an engine.Electric is best especially in a closed/ heated shed.Frank C.
Offline jesse
« Reply #7 on: February 18, 2011, 11:52:35 PM »
i changed from gas to deutz diesel 30ht25 timber harvester
Offline clint
« Reply #8 on: March 01, 2011, 04:50:40 AM »
Thanks for the helpful advice guys -- I am looking into a gen set now.
Offline cubdriver55
« Reply #9 on: March 15, 2011, 08:38:37 PM »
I bought a Timber Harvester with a 25 HP electric and I was going to switch it to diesel before talking to people on this forum. I ended up buying a phase converter and I will never saw with diesel again. I used to saw with a circle mill and listen to a power plant run all day and suck down huge amounts of diesel. Diesel is now about $3.50 a gallon so it is not that cheap to saw. I am amazed how cheap it is to saw with electric. I ran the mill with nothing else on and found out I am sawing for less than $1.00 an hour. I had even bought a big gen set and ended up selling it. If you are not moving the mill around just get a phase converter. If you are sawing some away from home buy a gen set and a phase converter for sawing at home. It will pay for its self in no time with fuel savings. I did not saw a huge amount last month but I sawed a fair amount. My entire electric bill for the whole month was $23.00. That would not be much more than a 5 gal can of diesel
Offline clousert
    • Clouser Farm - Lion Country Bandsaws
« Reply #10 on: March 22, 2011, 12:52:25 PM »
We now build and repair the Timber Harvester brand mills.  For ease of use and best power/torque, the electric motor is the way to go, unless you need to be portable.  Have your local electric shop build you a "rotary phase converter" from a used electric motor, 25 hp unit.  You'll need 100 amp single phase with #2 wire to feed the converter.
If you need to be portable, the diesel motor provides excellent torques and more steady RPM's while sawing, which can mean straighter cuts, but the price of diesel motors and retrofit is pretty steep.
If you can get a rotary phase converter made for $1500, it's your cheapest deal and best power source.
Tom Clouser, farmer and sawmill operator in Pennsylvania, partner of CLOUSER FARM ENTERPRISES
Offline Wintergreen Mountain
« Reply #11 on: March 22, 2011, 02:27:07 PM »
clint:
   I powered my Turner Mill with a Volkswagon 40hp 1.6L diesel engine. It is driven buy a hydrastatic pump and motor. The hoses are 50ft long so the power unit can be away from the mill head and operator . They drag and tag on the ground with no problem. Very little noise and heat at the operators station.  I am improving it as i go. A couple of pictures below.
Leon
1920 Ford 4x4 tractor, forks & bucket.      2010  36" Turner Mills band mill.      Cat D3C crawler dozer. Cat 215c excavator.
Offline taluswood
« Reply #12 on: October 15, 2013, 08:17:19 PM »
I'm quite interested in how the hydraulic motor worked out for you. I have a turner with a small 5hp electric on it. We live off grid so i run a pto generator which powers the mill, and charges our batteries. I've been thinking to try and harness the power in a better way though. The Hydraulic looks like a good option
Offline mmartone
  • I'm new! but I'm old.
« Reply #13 on: October 15, 2013, 08:42:06 PM »
I would also like to have more info on the diesel and hydraulic. I have an izuzu 3 cyl diesel sitting and a parker hydraulic pump in the box. Any chance on a post and lotsa pics? Maybe a video of it running and cutting?
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #14 on: October 15, 2013, 09:15:33 PM »
     Interesting question, but old post guys.  Clint hasn't posted since 2011.  Wintergreen Mountain hasn't posted in 6 months.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline Cypress Man
« Reply #15 on: October 15, 2013, 09:35:00 PM »
This is a real no brainer. Stay electric!!!!!  I would go with a phase converter. No hauling tanks of diesel/gas every day, no oil changes, oil filters, air filters, spark plugs, radiator fluid levels, fuel filters, etc... etc... etc... Been there, done that, but never again.
LT70 wide head electric, IC5 Power conveyor, transfer table, Stop and Load Log Deck, Catapiller 360B Telehandler, Woodmizer twin blade edger, Logosol PH360 moulder, Extrema 26" Planner, Grizzly 16" dual conveyor resaw, Prentice 210D log loader
Offline thecfarm
« Reply #16 on: October 15, 2013, 09:45:09 PM »
Could use that motor to power a wood splitter too. use quick disconnects to move the lines from one to the other.
Offline bandmiller2
« Reply #17 on: October 16, 2013, 07:25:40 AM »
Electric solves the exhaust problem in a closed building.  You can hear the band cutting and have a conversation with coworkers. I've used boath and believe me electric is the premium mill power, unless of course your running a road show. Frank C.
Timber Harvester Portable Sawmill
Started by True North on Sawmills and Milling
Last post February 06, 2009, 05:49:37 PM
by True North
Offer made and accepted - Timber Harvester Sawmill
Started by warren46 on Sawmills and Milling
Last post October 04, 2013, 02:52:41 PM
by Magicman
Timber Harvester Sawmill, Nyle L200 Kiln and Baker Resaw for sale
Started by RalphV on For Sale
Last post January 08, 2016, 09:52:25 AM
by RalphV
MA. timber harvester's lic.
Started by Ed_K on Forestry and Logging
Last post August 09, 2014, 06:50:24 PM
by Holmes
