Author Topic: want to recommend a setup?  (Read 2056 times)
Offline 1270d
« on: March 06, 2011, 06:02:02 PM »
Thinking about building a camp with some large white pine logs.   would probably saw them into 6 x whatever cants and just stack them for walls   the some of the pine logs would be 30 plus inches  in diameter and 24 foot long.
I know basically nothing about sawmilling and would like some ideas.  What type of mill will handle this type of wood?   what is the availability of such a mill and where could i see one.  (on the web or a dealer)
thank you
Offline Ianab
Re: want to recommend a setup?
« Reply #1 on: March 06, 2011, 06:17:40 PM »
Because of the size and length of the logs I would be looking at a swing blade mill.
Standard lengths are usually around 20ft, but extensions are available. The Peterson WPF is easy to extend as the rails simply sit on the ground. With the swing blade system the log also sits on the ground and you just start sawing off boards or beams. No need to turn the log while sawing, which is a big issue on those big ones.
Have a look at the Peterson, Lucas Mill and Turbo-Saw links over on the left, they have pics and videos there and several of us have various models if you have more questions.
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #2 on: March 06, 2011, 06:50:26 PM »
     Ian might have the right idea.  Look for a swingmill with enough extensions.  The 30" diameter shouldn't be a big deal.  But the 24' length could be a deal-breaker.  Most portable sawmills can't cut anything that long.  You ought to consider support equipment, too.  I don't think you're gonna pick up a green 24' 6x6 anything and go strollin around with it!
WoodMizer LT50HDD51-WR
Lucas DSM
Offline 1270d
« Reply #3 on: March 06, 2011, 08:34:16 PM »
thanks guys, ill look at these links
as for moving the stuff around we'll have a forwarder there to move things about.   not planning on sawing all six by six rather whatever i can get out of the log    6x26 two 6x16's and as many othe 6x as possible      VERY heavy im sure    most of this will be done in winter to make moving them around slightly easier.   also they will be milled on the site of the building. this is also where the trees will be felled.
Offline carykong
  • Installing my roof ridge metal
    • Have Mill Will Travel
« Reply #4 on: March 06, 2011, 09:22:54 PM »
Stay in touch with your build. 6Xwhatever will be heavy and will go faster with a loader.  Would a lighter frame like 6x6 cants and conventional framing lumber have interest for you?  Ya won't need as many trees and the heavy lifting will be spared. Just wondering.
Offline 1270d
« Reply #5 on: March 06, 2011, 09:38:56 PM »
this all is still a dream although   with a direction.   we have the land and the trees, now just need the mill and the time.   considered a chainsaw mill until we contacted some people that have run them.   way too slow.   we'll need to sawsomewhere around 20,000 bf total for a camp and sauna.  The other option would be vertical log walls, but these pines have to be cleared to make room for the building site.
we might consider going down to 4 inch cants but 6 has so much better insulatating value.
will post pics whenever we get going
Offline Meadows Miller
  • Location: Find a Job You Love & You Will Never Work Another Day In Your Life
  • The Walkabout Sawyer
« Reply #6 on: March 07, 2011, 03:10:40 AM »
Gday
And Welcome to The Forum 1270d I take it your a Timberjack Man Mate  ;) ;D ;D 8) 8)
With Mill Selection everyone has given good advice like afew have said and I agree with them that a swing mill would most likely be the best choice and are the chepest to extend also Mate  ;)
Ill add I will be in the States from Mid July and will have acess to a 10-30 Lucas mill and Lucas mills and Baileys Pickup for 3 months in exchange for doing a couple of shows including the Shootout just call Me Lucky   :) :) ;) :D ;D 8) 8) 8) I would be interested in doing the sawmilling for you but would have to organize a 6' ext kit for your job Mate  ;)
Regards Chris
4TH Generation Timbergetter
Offline weisyboy
  • sawmiller & logger
    • Weiss Sawmilling and Property Maintenance
« Reply #7 on: March 07, 2011, 06:49:27 AM »
lucas mills can easyly be extended to cut 28-30' with the 2m extensions.
it will use up a lot of log. is tehre a way to do it without using so mutch timber.
on a side note how would sawdust work as insulation insode a wall?
Please recommend a screenhouse
Started by sprucebunny on General Board
Last post July 22, 2008, 07:08:47 AM
by thecfarm
Recommend me a chainsaw
Started by matariki on Chainsaws
Last post November 26, 2018, 11:51:48 AM
by mike_belben
Need a sawyer to recommend in SC
Started by MemphisLogger on General Board
Last post January 13, 2005, 05:10:58 PM
by DanG
353 Detroit oil recommend
Started by Timbercruiser on Forestry and Logging
Last post February 04, 2017, 06:24:16 PM
by dgdrls
