Arborwear
Author Topic: Check out the skidder on NH craigslist  (Read 6643 times)
Offline logman81
« on: March 22, 2011, 05:49:35 AM »
Was doing some craigslist surfing and cam across a nice c5d tree farmer skidder. Looks like a nice little skidder, they say it needs a little tlc gear for winch and some brake work. Might be a possible replacement for my tractor. :) Check it out and let me know what you all think of it and any info you might be able to give me. 8)
Precision Firewood & Logging
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
Re: Check out the skidder on NH craigslist
« Reply #1 on: March 22, 2011, 11:18:36 AM »
I think that's a C4, with a 353, it was called the pulpwood special, it has the light frame, and the small rear ends, i had one just like it.
The biggest problem is it has the old Branden wench on it, i couldn't get parts 25 yrs ago, you would have to find a good 9, 20, or 119 Gearmatic for it.   [ i think i have Branden spell't wrong]
This cross breed c4/c5 is a axle breaker if you try to use it like a c5, it was to much power for the weight of the machine, i called it a wheel spinner.
logman this would make a nice skidder with a few changes and used right, its a fun machine, if i had one again i would put a little fluid in the tires, it would ride better, make it much smother machine.
« Reply #2 on: March 22, 2011, 12:50:47 PM »
Its a Branden mechanical winch, i didn't have the internet to look up parts, this opens it up, you might be able to find them.
 I can't see the wench real good, it might be a Hyd Tulsa winch, my dad had one on his c5, it was a very good winch.
Offline logman81
« Reply #3 on: March 22, 2011, 01:28:10 PM »
Thanks lumberjack48 I also think it might be a c4 not a c5. It's got the good engine in it though so it definitely is not underpowered. If it does have a mechanical winch do you think it would be better to swap it for a gearmatic for ease of finding parts and operation of it? It says it needs brake work what typically goes on them?
« Reply #4 on: March 22, 2011, 03:05:01 PM »
I would check it out, if winch is a cheap fix, run it on till you can't fix it, the Braden works good, just a little slower putting in gear and taking out  [ if it is a Braden ]
I would look for a 119 or a 20 gearmatic, 25 yrs ago a guy could pick one up for 1200., working order.
The brakes are not a big dollar idem, your a mechanic, I'm sure you would go with disk brakes, something not to get to concerned about when buying, non of these TF's had brakes.
Offline logman81
« Reply #5 on: March 22, 2011, 05:26:21 PM »
Sounds good lumberjack48. What is the machine capable of skidding without pushing it to hard? A cord or more? Seems like it would be a good machine for doing thinning work and small saw logs. I would probably do the disc brake conversion need those brakes around here. What do you think it weighs 12,000 or more? Price seems ok if it is a good runner with easy fixes.
« Reply #6 on: March 22, 2011, 07:05:06 PM »
Its call a pulpwood special because its fast and a puller, it wants to be pushed hard, a cord or more easy, its a big log skidder, don't take me wrong, this will pull a 1000 foot Pine on a straight pull.
I liked the one i had, i didn't like the 18.4x34 tires on it, way to tipsy.
I would run 16.9x30's or 18.4x26's , my dad had 16.9x30's on his c5, they worked good.
I had that skidder for a 1 year, broke 1 axle, this wasn't the skidders fault, it was the operator, he was making to much of a right angle turn with about 2 cords behind him, it was walking on one rear tire, if the axle wouldn't have broke i think it would have powered it self right over, probably killing him, [ It was the last day he worked]
Not sure on the weight, probably a little lighter than 12,000
Offline logman81
« Reply #7 on: March 23, 2011, 07:17:22 AM »
Good info lumberjack48 I didn't think it was that light I figured 12,000 or a little over. Sounds to me like it would be the perfect machine for what I do. Now it will be a mad rush to finish the job I'm on to get the money up for it before it's gone. ;D
« Reply #8 on: March 23, 2011, 06:14:32 PM »
logman check out the C4 on Bemidji craigslist, this is nice, a little bit high, but if everything has been gone though i'm sure he has a lot of time and money in it.
 May be its just been painted, to make it look new, this is the same machine i payed 9500. for new
Offline treefarmer87
« Reply #9 on: March 23, 2011, 08:59:47 PM »
they are good little machines :)
1990 Ford F-800
1974 Ford L 9000 Self Loader
1994 John Deere 648E
1985 Franklin 170 Forwarder
John Deere 440 B
1980 Treefarmer C6D grapple
Prentice 210
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline logman81
« Reply #10 on: March 24, 2011, 08:29:36 AM »
Found another one even closer to me on ct craigslist. It has a Isuzu 80 hp diesel, I think that it might be a repower in it. It's a c4bd long chassis with Rockwell axles. Problem is he is asking way to much for it. :( I'm not sure how much they went for new but I think they went for less.
JD Skidder on craigslist.
Started by luvmexfood on Forestry and Logging
Last post April 27, 2014, 06:38:39 AM
by timberlinetree
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post September 17, 2016, 08:19:54 PM
by ScottAR
grin
craigslist comes through again!
Started by old 030 on Chainsaws
Last post October 21, 2011, 04:49:30 PM
by Cut4fun
Craigslist
Started by Howdy on General Board
Last post December 14, 2014, 07:38:03 AM
by Magicman
