Author Topic: Help with 8 h.p. Briggs & stratton ?  (Read 742 times)
Offline bama20a
« on: April 27, 2011, 12:52:38 AM »
Hope this is the right place to post this.
I've got an old 8 hp,(garden tiller) It hasn't been run in years when I got it.I had to put a new float in the Carb, Checked the valve, I did have to file one down & they are set right.(think)I got it started up,But when I let it run for just a few min's I noticed the muffler got a red glow on it,So I shut it off.
 Can anyone give me any pointer's to look for? Thanks Mark,,,,,
It is better to ask forgiveness than permission
Offline trapper
Re: Help with 8 h.p. Briggs & stratton ?
« Reply #1 on: April 27, 2011, 03:46:37 AM »
carb set too lean or an air leak.  Others correct me if this is dangerous.  To find an air leak I start the engine.  I take a propane torch turn on the propane but do not light. I pass the nozzle past the gasket between the carb and block' also around the head gasket.  If the engine speeds up doing this you found the leak and need to replace gasket and maybe resurface the mating surfaces.I was taught to resurface on a surface plate using wet sandpaper in a figure 8 motion.  In a pinch use a piece of glass as a surface plate.  also others with more experence may tell you that it is normal for the muffler to turn red.
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
Offline beenthere
« Reply #2 on: April 27, 2011, 10:56:56 AM »
Or an exhaust valve that leaks ?
Offline red oaks lumber
« Reply #3 on: April 27, 2011, 01:05:37 PM »
is the muffler partially plugged?
Briggs & Stratton
Started by JBS 181 on Sawmills and Milling
Last post December 18, 2010, 07:42:19 PM
by Slabs
Briggs and Stratton won't run
Started by Tom on General Board
Last post November 26, 2007, 07:17:04 PM
by Polly
35 HP Briggs & Stratton Vanguard
Started by woodbowl on Sawmills and Milling
Last post June 21, 2006, 01:24:35 PM
by tcsmpsi
Has anyone else had problems with the 16hp briggs and stratton?
Started by JSwigga on Lucas Mill
Last post August 22, 2013, 11:15:16 AM
by logboy
