Author Topic: Leaky MS200T  (Read 3136 times)
Offline KB0NES
Leaky MS200T
« on: May 02, 2011, 02:38:16 PM »
I just recently purchased a new MS200T. I've gone through a couple tanks of fuel doing some light cutting/trimming to break it in.
It has sat for about a week now and I just noticed that it is puddling bar oil under the cases. This doesn't appear to be typical excess from the chain as the saw hasn't been run for a while and it was cleaned up well before I stored it. Also noteworthy is that this oil is CLEAN, none of the grunge that is in the usual bar leakage.
From what I see is the vertical crankcase gasket responsible for sealing the bar oil reservoir? If I had to pinpoint the leak it coming from the parting line in the cases...
Has anyone else seen this issue with one of these saws? I plan to get it back to the dealer this week but thought I'd post the question as well.
Thanks,
Phil
Burnsville, MN
Burnsville, MN
MS 261 & MS 200T
Offline Cut4fun
Re: Leaky MS200T
« Reply #1 on: May 02, 2011, 03:56:26 PM »
I had 2 084's do this. I just tightened the crankcase bolts and it stopped.
Being your under warranty and new, let the dealer take care of it for you.
Offline Al_Smith
Re: Leaky MS200T
« Reply #2 on: May 02, 2011, 08:12:00 PM »
About the only way it could leak would be because the cases are loose .There's one case bolt you have to take the bucking spike off to get to .
Coincidently I worked on two of those little gems within the last week .
Offline KB0NES
Re: Leaky MS200T
« Reply #3 on: May 03, 2011, 12:55:05 PM »
Thanks for the replies guys. I'll check out the case screws. I suppose with a few thermal cycles and a little vibration things could have changed a bit.
The dealer I bought it from is a bit out of the way, I'll take it in if re-torquing the screws doesn't do the trick.
Does Stihl have a torque spec for those screws? I'd love to have a copy of the service manual for the saw, I did manage to find an electronic copy of the IPL. Not familiar with how much more information Stihl publishes for their products.
Phil
Burnsville, MN
MS 261 & MS 200T
Offline Cut4fun
Re: Leaky MS200T
« Reply #4 on: May 03, 2011, 01:47:57 PM »
I have a 020T service manual and it shows crankcase Nm 5.5  LBF.ft 4.0
Leaky 460 magnum
Started by sfgjon on Chainsaws
Last post March 25, 2006, 07:50:25 AM
by sfgjon
MS880 / MS200t
Started by ktowne030311 on Chainsaws
Last post January 09, 2015, 10:40:37 PM
by DonT
ms200t parts...
Started by Cliniford on Chainsaws
Last post December 23, 2008, 07:12:50 PM
by Cliniford
Ms200t running issues
Started by Grimace71 on Chainsaws
Last post June 13, 2018, 05:36:35 AM
by ladylake
