Rough cut milliing.
Started by SwampDonkey, May 04, 2011, 02:46:06 PM
Today was too wet and cold for the woods, so attention was focused on this little job. Well last fall a windstorm took down a white spruce in the back yard. The but blew out, but the tree was sound after a short distance up the trunk. So, I had talked about milling it out into cants. Well one cant anyway, an 8 x 8" by 16 foot cant. I had lopped it off last fall around  18 feet. I had thought I left it 32 feet, but alas I had chunked it up after the 18 feet. Anyhow, here is how it went.
I found a piece of spruce strapping in the barn and tacked it on here.
Did same on the opposite side to serve as my first flat face down the log.
I put my new Forum Efco chainsaw to work and got this.
Looks like it snowed with all that nice white spruce sawdust. ;D
I had to trim off some of the fist sized (or bigger) swelled knots off the edges to make it easier to strap that board on the next face.
I went to work and carved off two more faces and then I was left with the final cut to make after making the saw guides with the board and marked with the saw.
Now I'm left with my roughed out 8x8" timber. The Efco worked like a champ, but don't anyone dare call me for any chainsaw milling jobs. :D ;)
As the title says, rough cut milling. ;)
With all the gathering of tools, setting up each cut, putting stuff away I was probably busy for 4 hours. It took around a tank of gas for each face, to cut.
Park bench seats anyone (from slabs)?
Enjoy. ;D
I was beginning to wonder when you were going to get that chainsaw out.  8)
terrifictimbersllc
Better keep the benches to sit on between cuts. :D :D :D
Nomad
     I'm with TT.  Chainsaw milling will get the job done and I've done some big logs that way, but that's a rough row to hoe.
     On the other hand, looks to me like you did a pretty good job!
WoodMizer LT50HDD51-WR
Lucas DSM23-19
You definitely won't find my shingle out for chain saw milling. I had a log, a chainsaw, and now a cant for 4 tanks of gas. ;D
isawlogs
Good job the Donk !
You can shave the beam with the saw by sweeping the surface with the saw at a compound angle making a side to side motion. Can almost do a nice finish like this .  ;) :)
   Marcel
Do you charge by the foot or by the week  :D.
jdtuttle
I had an alaskan chainsaw mill. Milled a couple logs, gave it to my nephew, & bought a woodmiser. My back feels alot better :D
jim
Have a great day
isawlogs
Danny , I think he could charge by the yard ....  of sawdust he makes. ;D
   Marcel
Brad_S.
You could have saved the 4 tanks of gas if you had just hewed it with an axe. Just sayin'.....
tyb525
And to think some people make lumber that way!
Quote from: WDH on May 04, 2011, 08:31:15 PM
By the pound, 260 lbs at $0.50 a pound. That sucker didn't dry much over winter, the fella behind the peavey grunted just as hard rolling her over as he did last fall. :D
Just judging by eye and straight edge on the photo I'd say I kept a fairly straight line down the beam. A few shallow dips, but not bad. ;)
terrifictimbersllc
Quote from: jdtuttle on May 04, 2011, 09:26:34 PM
jim
Bandsaw manufacturers should give out free chainsaw mills to prospective customers.
isawlogs
Sd , you did as good a job as I have seen done with some bandsaws  ;) :)   Now get a longer handle on the cant hook peavy or give it to someone that can handle the grunting. ;D
   Marcel
It's got a quite beefy handle on that Logrite, I actually have two identical ones. ;D It's actually longer than any traditional peavey you see in anyone's shed or barn around these parts. Provided the wooden handle still is in tact. Afterall, the log was 18', wet, and about 22" at a ways above breast height (maybe 6 feet from ground) and about 14" on the top, and I was working in a  brush pile of limbs. ;D That might help explain it. Remember it's a lot lighter with the sides shaved off, the 260 lbs is the cant. I gotta roll/skid the sucker out  to the barn a couple hundred feet away. Not a long ways, but work enough. I can handle the grunt work pretty good, just any bystanders should stand back some distance. :D
Who was it that said it around these parts? "If there is work involved, no one will be found in sight of it" :D :D
isawlogs
Excuses !!!  ::)  ::)  ::)   :D
   Marcel
I had a one-man buck saw stolen one time.  ???
Well, anyway I had a long day at First Aid class, so just about ready to call it a day. My head hurts. :D
isawlogs
 Is it flat enough , da ground where it sits , to put rollers under it to help out some in getting moved ???
   Marcel
I'll probably use some of them slabs to get out of the brush and use some fence posts or something to get it to the back door. Those slabs, with all the rain water on them, are slippery as ice to a flat surface like that on a face of the cant. I do have a smaller spruce laying there I could buck up, because it was all red rot inside it, which I was very surprised about. It wasn't even a suppressed tree and was growing quite nicely unlit this monster came down and snapped off the top.  :-X
But before I do this I have to do some house cleaning in there to put some lumber and short pieces up in the loft out of the way and clean the floor up. I have two sleds  ::) I need to find a place for, a super sized  :D wood splitter and soon a new lawn mower, plus my shop firewood to make room for. :D I would like to put that lawn mower in my garage during the summer instead.  ::)
isawlogs
Quote from: SwampDonkey on May 06, 2011, 05:57:16 AM
  I think that you should of cut 2x4's and built a shed/garage/storage area instead of a beam,. Just saying.....  ;D :D
   Marcel
Well I cleaned house down in the barn, and lets just say it needed it.  ::)
Then I fetched these cedar rails we cut up for kindling 20 years ago, bark still on most of'm by the way.  ;D
Makes for good rollers when you have 20 or 30 at your disposal. ;D
Grabbed my peavey and pulp hook and started man-skidding to the barn. Landed the timber in the right spot, for now. ;D
Got'r done, with life and limb still sound. :D
That 6x6 timber you see as a prop is all hand cut as are the others propped down the support beam you can't see. ;)
I left extra wood on that cant, so after it dries a fellow could true it up better on a mill some day.
isawlogs
 Good job dere sonny !!! ;D
   Marcel
sprucebunny
What are you going to make out of it ???
Can't think of anything at the moment. :D
