Arborwear
Author Topic: bell feller buncher info  (Read 11369 times)
Offline treefarmer87
« on: May 13, 2011, 02:15:53 PM »
can anybody tell me about these machines? i know a little but, how often do you sharpen the chain? does the saw bar get bent alot? how big is it compared to my C5, and how much does it weigh and how wide is it? thanks :)
1990 Ford F-800
1974 Ford L 9000 Self Loader
1994 John Deere 648E
1985 Franklin 170 Forwarder
John Deere 440 B
1980 Treefarmer C6D grapple
Prentice 210
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline kiko
Re: bell feller buncher info
« Reply #1 on: May 13, 2011, 05:02:36 PM »
Not sure about weight, but a super T bell is about nine feet wide (outside of tires) and 16 feet end to end including head. The super T was a good machine. The ultra T had problems with hydraulic oil heating up. The Bell is best suited for large timber. How many bars get bent depends on the operator and if the nitrogen tank that returns the bar is properly charged. The trick to not bending the bar is to grap the tree and then load boom so rear tire comes off the ground before making the cut this will help lift the tree off the stump as it is cut and reduce likelyhood of damaging the bar as well as help with placement of felled tree. With the dangle head you can also run around and top the tree once it is on the ground.  Super t  has levers and two levers must be pulled when cutting. The ultra t has joysticks. Again chain sharpening freq. depends on how much dirt get cut. When dull or improperly sharpened it act just like a regular chains saw that is dull or not sharpened correctly. The bell also works well for blown down timber. Tire chains also help greatly. I like these machines but ther is a learning curve.
Offline amberwood
    • www.amberwood.com.au
« Reply #2 on: May 14, 2011, 05:05:40 AM »
Chain life is very much down to what you hit, type of bark, etc . In pine we get 1-2 days use before it is blunt, felling and processing. Sometimes you clip a rock and the chain is off an hour after you fit it. Bars get bent when things go wrong or with a learner driver. We use 34"GB bars with Oregon 3/4 chain on a dangle processor.
DTR
MS460 Magnum
MS250
DAF CF85-430
ASV RC-85 track loader
« Reply #3 on: May 14, 2011, 07:42:16 PM »
thanks i might be purchasing one june 1 or around that time along with a saw package on my loader :) how big of tree can it fell?
1990 Ford F-800
John Deere 440 B
Prentice 210
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline oldseabee
« Reply #4 on: May 15, 2011, 08:36:18 PM »
It's a 30 In. bar but you can use multi cuts for bigger trees but you have to see which way the tree is leaning or the wind is blowing so your 2nd cut doesn't get your bar pinched, the first cut should be on the side that the tree is leaning or the heavy side. It takes quite a bit of practice. Is this a super T, Ultra T, or Ultra C. ? I have some tech info on each.
« Reply #5 on: May 16, 2011, 04:48:13 PM »
its a super T. can the machine make leaners go the other way?
1990 Ford F-800
John Deere 440 B
Prentice 210
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline oldseabee
« Reply #6 on: May 16, 2011, 10:51:47 PM »
If it's a tree that you can get with one cut, you grab it, cut it off and back away from the stump quickly so you really pull the butt out from under the top. This will take practice, you won't have a lot of time to think about what you are doing, it almost has to be by reflex, just  practice on some straight up smaller trees until you get the hang of it.
You can't push a leaner the other way, the saw head only has a small cylinder to raise it up in position to grab the tree.
« Reply #7 on: May 17, 2011, 06:46:00 PM »
ok, i really like it. this machine has a new motor and barsaw head :)
1990 Ford F-800
John Deere 440 B
Prentice 210
FEC 1000 slasher
FEC 1550 slasher
Danzco Delimber
Sthil 660
Jonsered 2172
Jonsered 2255
Offline kslogger
  • Member*
« Reply #8 on: July 27, 2011, 07:25:55 PM »
this is for Oldseabee who offered tech info on the bell saws. I am looking at an Ultra T, and wanting to know if it has particular problems to watch out for. The air conditioning on this one does not work. Also how does it compare to the Super T for repair and cost of repair?
Offline Side loader
« Reply #9 on: August 24, 2011, 10:18:08 PM »
I think you will really like the super T .  The advice on this forum is excellent. I just purchased one this summer and really like it. I'm in the deep south in a 2nd thin of plantation pine.  Mine had the pincher head on it and that is what I have been using. It also came with a dangle head. One thing is for sure if yours has the air cooled dutz, be sure and blow out the fins around the head with an air hose about every 8 or 10 hours of use. Hope it works out.
Side loader log truck w/492 Detroit, bell super T feller buncher, Barko 160 with JD power, Kubota M4900 with brush raker grapple on front and shop built bunching grapple on back. JD 350B Dozer; JD 548D skidder;  and a couple of saws.
Offline oldseabee
« Reply #10 on: August 24, 2011, 10:42:44 PM »
Your biggest problem will be the learning curve on how to operate it efficiantly. Keep the hydraulic oil clean and keep the oil cooler and the engine cooling fins  blown out. Before starting out, make sure the pressures are all set right. Some wiring problems in the joy sticks and the harness's  have shown up, and in hot weather in high production hydraulic oil heating. As to the cost of repair, The Ultra T has rexroth hydrostats  and the system pump, quite a bit more expensive to repair then the Super T that has Sunstrand hydrostats and 2 gear pumps for the system hydraulics. The heads are basically the same. Check the lugs on the tail wheel occasionally, they have been known to work loose.
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #11 on: August 25, 2011, 01:33:02 PM »
Theres one advantage running a Bell , you don't have to go on any rides at the Fair. 8)
I think there a very good feller, when ran with its means, like anything
You have to be patient, it takes a while to get it under neath you.
Bell ultra T feller buncher tech info
Started by swvalogger on Forestry and Logging
Last post August 29, 2017, 09:40:37 PM
by swvalogger
bell feller buncher
Started by notchjohnson on Forestry and Logging
Last post May 13, 2017, 09:57:31 AM
by notchjohnson
Bell feller buncher
Started by TonyS319 on Wanted
Last post September 11, 2014, 07:00:04 PM
by Mooseherder
Bell Feller Buncher
Started by Mattgbank on Wanted
Last post December 27, 2014, 09:58:32 PM
by Mattgbank
