KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Cat/Perkins 51 HP  (Read 4092 times)
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Cat/Perkins 51 HP
« on: May 19, 2011, 06:30:03 PM »
Perhaps this has been addressed before, but I was only made aware of it on tuesday last when talking with my neighbor/friend who saws full time portably with a lt50shdd51 woodmizer.
We had talked about a month ago regarding the Sawmill exchange which lists a number of 51HP mills with (for example) 2500 hrs on mill, 800 hrs on engine. This raised a red flag.
He got checking RPM on his engine and found 3100 plus or minus, then got on line and found that the factory specs are 2800 RPM tops, stating higher RPM may result in engine failure.
I checked my engine and found 3095 RPM.
Both he and i have reduced our RPM, him to 2850 and me to 2795.
Anyone out there have info regarding this?
It seems to saw just fine at this setting.
I am wondering why WM mills come with the higher RPM setting.
Pete
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline ladylake
Re: Cat/Perkins 51 HP
« Reply #1 on: May 19, 2011, 06:56:51 PM »
 Sure could be that they upped the RPM some to raise the HP, my little Isuzu was on a Ingersol air compressor where they had it rated at 28.6 hp at 3400 RPM when most I've found were rated at 25 hp at 3200 RPM. I'm running mine at 3200 RPM and still using the same drive pulley as the old 3600 RPM Kohler so the blade speed is slower but it saws a lot faster than the 27 HP Kohler ever did, and straighter.   Steve
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #2 on: May 19, 2011, 08:07:28 PM »
I recall seeing the spec for that engine somewhere and was surprised to see it was so high. I'll have to check ours.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #3 on: May 19, 2011, 08:13:11 PM »
Sounds like a good way to sell more engines. FISHY? This is a great post!
Where's the Spoon?
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: May 19, 2011, 09:08:16 PM »
how do you check the rpm ?
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
« Reply #5 on: May 19, 2011, 09:50:09 PM »
Use a piece of chalk or magic marker to put a line on the drive pulley, then start it up, set it on cut, and count really, really fast- gives me a migraine so I've never actually gotten an rpm number I trust...  :)
No, really, there are a number of past threads dealing with this subject, using ingenious and inexpensive systems with off-the-shelf parts- can't remember where though....
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline sandhills
« Reply #6 on: May 20, 2011, 01:48:53 AM »
Definitely not the cheapest option I'm sure, but you can buy tachometers that have a rubber "shaft" (for lack of a better term) that you simply press against the end of the crankshaft.  We have one that dad got for checking rpm on irrigation power units, we checked it against the tachs on our tractors and it was very accurate, don't remember the price but do know it wasn't real cheap.
Offline r.man
« Reply #7 on: May 20, 2011, 08:46:17 AM »
I remember that thread and the cheap answer is a paper disk that can be printed off or bought. Affix it to the pulley and then look for the dashes that are not rotating when the pulley is turning at its full speed. Each series of dashes corresponds to an rpm so the one that is standing still like a carriage wheel is the rpm.
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #8 on: May 20, 2011, 06:04:41 PM »
Check the RPM with a tachometer after the first 20 hours of operation and every 200
hours thereafter. High-end RPM should be 2950 RPM and low-end RPM should be 1500
RPM.
Before checking the RPM, make sure belt and brake strap tensions are correct (See Sawmill
Maintenance). Also check oil, fuel, and coolant levels.
Make sure the throttle solenoid linkage is adjusted properly. With the clutch disengaged,
the throttle linkage should rest against the idle adjustment screw. With the clutch
engaged, the linkage should rest against the high-end adjustment screw and leave 0 to
1/32 of play in the linkage.
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
« Reply #9 on: May 20, 2011, 06:23:59 PM »
Thanks Marty.
I respect your posts and info.\ which are very helpful.
However, 2950 is still higher than Perkins/Cat says.
How about the service interval of 300 Hrs.
Seems high to me.
Oil and filters even at todays high prices are still cheaper than engines.
As an aside, Here in Central NY in the winter I have to "boost" the starting Idle speed with a thin piece of scrap or whatever is handy when starting or the engine will stall at idle.
This is even after cycling the glow plugs.
Pete
LT40SHDD51
Kubota 900 RTV
« Reply #10 on: May 20, 2011, 10:05:10 PM »
Hello,
I checked the Cat manual I had here at the shop and it said rpm 3000 max. Most of these engines failed due to crank shaft failure. The argument is, customer tightening the drive belt to tight or weak cranks. We educate the owners as much as possible when we do the new mill training. It is also in the engine auto clutch book and the maintenance manual.
Spec for a 51 hp Cat is 18 lbs force with 7/16 movement. Check your manual for the proper procedure.
I have seen a few drive belts overtightened. I have even seen one Kohler engine with a rear pulley off ( the crank end was still in the pulley) and no auto clutch. I think the owner had big guns!
We have not seen this reciently.
I dont think any manufacture would design a failure so they could sell more parts. IMHO
Yes filters and oil are less expensive than engine parts and labor.
Thanks!
Marty
Offline tyb525
  • Always learning.
« Reply #11 on: May 20, 2011, 10:17:45 PM »
With today's oils and engine technology, you can really go a bit longer than most specified intervals. The only reason service shop's still say every 3000mi is because they make more money that way. You can easily go 5-7k or more, especially with semi or full synthetic oils. Most manufacturers have changed their spec's to reflect this, and many service shops have not.
Offline hunz
    • jeter mountain farm
« Reply #12 on: March 03, 2015, 10:43:42 PM »
I know this thread is quite old, but to me it seems there is mixed information without a verdict. First, from what I gather, Perkins made the engine, so they built the engine to operate a certain way. Is this where the 2850/3000 rpm question possibly arose from? I actually reset my idle rpm yesterday on my CAT as per my manual, and a verification call to Wood-Mizer Indiana. Both said/say 1500 low, 3100 high.
 Marty,
 Any idea why the discrepancy? Makes a guy feel a little uneasy running his $5,000 engine possibly out of its recommended rpm range. In order to achieve a 1500rpm idle speed, the high end came out at 3025. My engine has a tamper resistent set screw on the high end, so how is a guy supposed to adjust the WOT rpm? Possibly remove the tamper resistent screw, and install my own setup?
FYI, I also just installed the extra crankshaft support kit. Anyone else have one on their CAT?
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
Offline hunz
« Reply #13 on: March 14, 2015, 11:23:54 PM »
Anyone with a definitive answer? Marty?
   Otto, the head engine man no longer works at Wood-Mizer, as per someone in tech support. It was somewhat made out to me, that all anyone knows is what's written in manuals.... which happens to be varying information depending on what revision # you have. No real hard evidence.
Offline schmism
« Reply #14 on: March 15, 2015, 02:53:15 AM »
There is a metal tag on the side of the engine with the serial number.... send me the number and ill have my perkins guys look up the official high idle spec.   it might also list it on the plate.  fyi its its a perkins its 2 letters some numbers likely a U and some more numbers, if its CAT its 3 letters and some numbers.
as for extending oil service, unless your takeing SOS samples,  its ill advised.
039 Stihl 010AV  NH TC33D FEL, with toys
Offline SawyerBrown
  • If you're gonna be stupid, ya gotta be tough!
    • Saw It There
« Reply #15 on: March 15, 2015, 07:17:11 AM »
Well, the other thing to consider is that high idle is at high IDLE, ie without any load whatsoever (which is the way they'd be set in the factory), and warmed up to operating temp.  So even an alternator load can affect the speed they turn in the "overrun" (above rated speed at rated power).  Seems to me if you're going change the high idle setting, the alternator belt should be removed. (And maybe this is already in the manual?). Then when reconnected the speed will be slightly lower, and lower yet with blade engaged.
Offline hunz
« Reply #16 on: March 15, 2015, 09:03:24 AM »
Sawyerbrown,
  Good point about the high end rpm set being with no load, I suppose even if a guy sets it at say 3025, it probably is actually turning somewhere in the 29s or 28s when cutting with debarker on.
Schmism,
  I appreciate that offer. I'll have to run down to the barn and check the tag, and get back with you. One thing I can tell you is it has a Perkins steel tag on the engine with "void" written all over it. The first owner recorded the idle rpm at 1373 when brand hammer new. Wonder if that is any indicator of where it should be.
    • A&P Saw mill LLC
« Reply #17 on: March 15, 2015, 11:03:22 AM »
It went well for me and no trouble. I did take the shield back off and left it that way.
Sawing since 1987
Offline hunz
« Reply #18 on: March 15, 2015, 12:36:32 PM »
Peter,
  Let's hope that crank support kit is worth the coin we dropped on it. Have you ever checked your engine's rpm? Any insight to give?
    • A&P Saw mill LLC
« Reply #19 on: March 15, 2015, 12:49:24 PM »
Peter,
No, The mill runs good the way it is. ;D
Sawing since 1987
Perkins 248 Gone
Started by Ohio_Bill on For Sale
Last post February 10, 2018, 05:22:00 PM
by Ohio_Bill
Perkins 3 cylinder
Started by Dana on Wanted
Last post January 22, 2017, 06:38:37 AM
by Dana
Perkins turbo,
Started by bama20a on For Sale
Last post November 17, 2012, 03:39:27 PM
by tempforce
353 detroit vs mf perkins 4.248
Started by vtlogger1973 on General Board
Last post October 28, 2010, 12:48:44 AM
by aksawyer
