Arborwear
Author Topic: One of those weekends..  (Read 1076 times)
Offline tyb525
  • Always learning.
« on: May 29, 2011, 09:18:07 PM »
Since I am off Friday through Memorial day, I figured this weekend would be a great time to get stuff done.
Saturday I mow the pasture and other various places with the big tractor and bush hog. As I am about to open the gate to get out of the pasture, the tractor sputters and dies. Out of gas, and the battery quickly dies after I try to turn it over a few times (it was going bad anyways). Off to get a new battery. I get back home, wrong battery, somehow I ended up with a 6 volt when I need 12 ??? ??? It wasn't marked anywhere on the battery. Another trip, I finally have the right one, it starts pouring. I get soaked by the time I get in my truck. When I get home, I figure what the heck, I'm already soaked so I put it in the tractor, put some gas in it, and all's well.
Until around 10:30, when the cows decide to bust through the hotwire and break down the gate. So I had to chase them down (black cows) in a muddy field, well they got back in the pasture, but not the way I wanted. They decided the easiest route was right through the fence. Trying to fix fence in the dark and the rain isn't much fun.
So today I check the fence real well to make sure all is well. Whoosh goes the tire on the quad, what the heck?! ::) Hidden in the grass was the remainder of a broken off fence post, 4 ft from the existing fence (how'd that get there?). It's sunday, can't get it fixed till tuesday.
So I try something else, and I put a log on the mill with the tractor. As I am backing up to the mill, I press the righthand brake. SNAP goes the rod connecting the pedal to the brake >:(
I decided to quit before I break anything else :D
Offline Warbird
Re: One of those weekends..
« Reply #1 on: May 29, 2011, 10:00:49 PM »
Yikes.  Time to take a day off!
Offline JohnG28
« Reply #2 on: May 29, 2011, 10:10:28 PM »
Sorry to hear you had a rough weekend.  I think something was telling you to take some time to relax and skip the work.
Offline paul case
  • Original wearer of the PCM.
« Reply #3 on: May 29, 2011, 10:14:33 PM »
mom said there would be days like this.
dont worry  about it. if you had never used the tractor or the quad then you wouldnt have ever discovered the bad battery nor the bad air in the tire! things only break when you use them.
btw if you didnt run over the sawmill everythings going to be ok! ;D  pc
pc
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #4 on: May 29, 2011, 11:40:17 PM »
It happens sometimes... Cheer up, it'll get worse...
hopefully helpful hint... if the battery has the screw on caps,  one row of caps equals six volt, two rows of caps equals twelve volt.
Scott
[Magicman]
Offline tyb525
  • Always learning.
« Reply #5 on: May 29, 2011, 11:46:18 PM »
I learned you can tell by the group size. But since I wasn't looking for a specific group size (who knows what it is, the tractor is a '69), I just picked the cheapest one that had a similar amp rating to the old one. Now I know! Thanks Scott, I didn't know that was a way to tell.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: May 29, 2011, 11:47:06 PM »
Time to take a break and stay in the house!
Offline Carpenter
    • Niobrara Timber and Woodworks
« Reply #7 on: May 30, 2011, 12:53:22 AM »
     Just fix what you can and move on.  Don't sweat the small stuff.  You didn't run into the mill when the brakes failed right?  Even if you did that's fixeable.  I hope the rest of your weekend goes better.
Offline tyb525
  • Always learning.
« Reply #8 on: May 30, 2011, 01:09:15 AM »
Nah the mill's fine, I was using the brake to turn sharper, not to slow down. Thankfully nothing major broke, just a lot of pain-in-the-butt things. Tomorrow I'm just gonna take it easy. And see what it will take to fix that connecting rod.
Offline JV
  • Live - love - laugh a lot today.
« Reply #9 on: May 30, 2011, 08:36:22 AM »
An old co-worker of mine used to put it best in his slow, easy drawl,
"Some days ya just can't lay up a dime."
John
'05 Wood-mizer LT40HDG28-RA, Lucas 613 Swing Mill, Stihl 170, 260 Pro, 660, 084 w/56" Alaskan Mill, 041 w/Lewis Winch, Case 970 w/Farmi Winch, Case 850 Crawler Loader, Case 90XT Skidloader, Logrite tools
Offline paul case
« Reply #10 on: May 30, 2011, 11:01:31 AM »
that is 3 individual caps( small round ones) is 6 volt and 6 caps is 12 v. some have row caps  that have 3 holes under each cap. same thing goes 3 holes = 6v .
that tractor of yours has one of those long thin batteries right?
i never had any luck with those. they had a 90 day warranty when we were using those and at day 93 they would die. they cost just a little more than a car battery too. i bent the lip on the edge of the box down and put a car battery in and no more trooubles. that was on a gas 706 farmall. i eventually did build a box for it but it was a lot easier to keep up with when a battery out of anything would fit. pc
pc
Offline trapper
« Reply #11 on: May 30, 2011, 12:43:30 PM »
The long thin battery is what my lt30 takes also.  Last one I got reconditioned at a battery shop.  Two years now but dont use the mill much.
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several logrite tools woodmizer LT30
This weekends pile 2
Started by jwilly3879 on Forestry and Logging
Last post February 23, 2014, 06:39:17 PM
by jwilly3879
